Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Infill T3 Questions
  1. #11
    Mar 2007
    I have one of these.. I can just use that can't I?
    https://secure4.vivid-design.com.au/...=&SUBCATID=381
  2. #12
    Constant Bitrate sharpmat007's Avatar
    Nov 2006
    Washington, DC
    I use an old power supply(from a laptop,lcd panel, etc)...its rated at 13v DC 1.2amp. I even tested with one that has less amps and it works. As long as you dont crank up the audio you are using nominal amps so any 12vdc supply with 750ma or more will work. If you use a supply that doesnt have enough power the unit will warn you that your battery is low and will attempt a shutdown.
    The power supply in the infill is made to run off of varying voltage/amp due to the fluctuations in a car so you dont have to worry too much. Just don't go over 14vdc for your test power supply and you should be good.
    Dont waste your money on a sofisticated power supply unless you have other use for it.
    Mitsubishi Eclipse 2006 GT
    Infill T3 running StreetDeck
  3. #13
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    Quote Originally Posted by jabz View Post
    that wont supply enough power for the T3
    I highly suggest checking out the FAQ's ... theres a lot of info in there on how to power your carpc in the house
  4. #14
    Mar 2007
    Quote Originally Posted by strohj View Post
    Are you sure? It's rated to output 8.5Amps @ 12V?!
  5. #15
    Aug 2004
    Pearland
    in that case I stand corrected... I somehow thought it needed at least a 150w power supply
  6. #16
    Nov 2006
    Washington, DC
    I just connect my infill to my old power supply that was 13vdc 1.2 amps and I did experience a lot of warnings of low voltage. Im guessing its just two much for it.
    I switched over to another supply rated at 14vdc 4amps...from an old dell flatpanel. It works like a charm and dont get any warnings...dimmer lights work, etc. Going to edit my comment above so I dont send anyone on the wrong track.
  7. #17
    Elsewhere
    Since this has nothing to do with StreetDeck, I'm moving it to the mp3car products forum.
    Carry on.
    How about the Wiki?
  8. #18
    Mar 2007
    Thanks, why not a Sub Forum under the G4? Since the T3 will be atleast supported till 2008
  9. #19
    Elsewhere
    ASk that question in the Suggestions/Comments forum.
    How about the Wiki?
  1. INFILL G4 - Australian and New Zealand Questions Answered
    By INFILLG4 in forum General MP3Car Discussion
    Last Post: 04-30-2008, 12:21 AM
  2. Infill T3
    By jabz in forum Infill T3
    Last Post: 04-15-2007, 06:47 PM
  3. Infill T3 in the UK: Some questions
    By discopanda in forum Newbie
    Last Post: 10-14-2006, 07:50 AM
  4. Infill T3 Questions (more)
    By apex52 in forum StreetDeck
    Last Post: 09-27-2006, 08:14 PM
  5. Infill T3 Questions
    By mtrydoc in forum StreetDeck
    Last Post: 07-07-2006, 12:52 AM
