No one knows?
I have received my T3 and have installed WIN XP and service pack 2, & all the drivers given on the CD, however device manager is showing still one device with exclamation marks.
1. InFill DFU&COM
what is this remaining device and where are the drivers for it?
Also where can I download the english manual for the T3?
How can I change the front mini LCD language to English?
Finally how come the mini display and buttons blue back light is not lighting up? I currently have the T3 powered on my desk via a benchtop power supply, it does upto 15Volts and 10amps, so low power is not an issue.
I can see the blue backlights flicker when the unit is switched on.
thanks
No one knows?
Do you have StreetDeck DVD? Infill T3 drivers are supposed to be in there. Here's a repost.
I'm in the process of reinstalling Windows on my upgraded HDD, so I've been searching for T3 drivers as well. I haven't started the reinstall yet, but it seems like the drivers by god_of_cpu are not the original drivers used by Infill. I went to infill.co.kr and downloaded all the drivers from that website.
According to Infill website, DFU&COM is supposed to be for the front panel. I haven't tried it yet, but hopefully it works as I'll have to use it later. Let me know if it works.
Infill T3 with Infill Station
2007 Hyundai Sonata
All drivers recommend by god_of_cpu worked for me...none missing in device manager after a brand new hardrive and clean install.
The only issue I had was the rez wouldnt display the native 800x480 until I modified the registry. I believe you just have to set the graphics adapter to display all resolutions though rather than modifying the registry.
Mitsubishi Eclipse 2006 GT
Infill T3 running StreetDeck
Thanks dude worked like a charm.
Still want to know why the blue backlights on the buttons don't light up during normal use, the unit is attached via my bench power supply right now.
I'm glad it worked.
The blue lights on the buttons only come on when there is a signal from the car's parking/headlinght to the illumination wire on the back of the T3.
I'm sure after illumination wire is connected to the car, they will come on with the parking/headlights. Also, the screen dims too.
After the initial install, when I first saw all the blue lights come on automatically with my auto headlight, I said to myself "Wow, that looks cool!"
2007 Hyundai Sonata
Thanks for the info, I'll wait to see when I connect it in car..
