Thread moved to the T3 sub forum.
Hi (first post!)-
I just received my new Infill T3 and the DVD eject button is very difficult to activate. Anyone seen this problem before?
Thanks, Scot
Jan Bennett
I noticed too that sometimes pressing the button doesn't eject. The button is so small, that I have to push with my finger tip very carefully. Or else, it woudn't react.
I just make sure that my finger tip is pressed firmly against it. I've had no problem using the eject button.
Infill T3 with Infill Station
2007 Hyundai Sonata
Thanks for the feedback.
I upgraded my system with a new hard drive and memory, so I am thinking that maybe the faceplate is not quite aligned properly. I am going to play with it a bit and see if I can improve the button response.
Scot
No, it was a *****, for sure. I actually figured the problem with my button (it was driving me nuts). Turns out one of the support tabs (where the upper board gel washer/bolt screw in) was bent slight downwards. I re-aligned it and everything works great now.
And that bottom board was a lot of fun getting out. I have to echo the comments about why the heck Infill didn't put a access door on the bottom for the memory?? Seems like a no-brainer.
Anyway, all is good... now if I could just get my ghost image to restore.![]()
Scot
