Never mind... solved it.
Thanks, Scot
I am not getting a video image from my backup camera within SD. Are there special drivers I need to install to enable this?
SD basically tells me that "video 0" is not configured. If I go to the video setup page, I see setup options for video 1-4 (no "o") and I can not select a input for any of them (no video source present).
Any thoughts or suggestions?
Thanks, Scot
Thanks, Scot
Scot,
I got the same issue with the backup camera within SD on my T3. Would you mind posting what you did to get it working?
Thanks!
Hi Spyder-
I didn't install the video capture drivers off the install CD. Once I did that, everything worked fine.
Scot
I also have the same problem with my T3. It's secondhand and i don't have any drivers, where should i get ones?
