Results 1 to 4 of 4
Thread: screen blinks
    Mar 2007
    screen blinks
    When endeder the lights of the car, the screen blinks and loses something of brightness. As I can solve this? The truth is that he is annoying when I lead at night.
    Mar 2006
    Colorado, but Canadian!
    what?!
    Are you trying to say that when you turn on your headlights, your screen blinks and dims? If so, your wiring is unsufficient. Run a better cable.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2007
    Hmm I think he is trying to say that when the headlights are turned on the display dims, and he doesn't like it?
    This is normal behavior when you have both the ILL wires hooked up to your car Harness. Not sure if there is a setting to stop it, or you could just disconnect the ILL wire from the TOP unit, if you leave the ILL wire from the bottom unit connected your button backlights will still work when turning on the car headlights
    Constant Bitrate sharpmat007's Avatar
    Nov 2006
    Washington, DC
    Dimmer lead incompatibility
    Your dimmer lead is not compatible with the infill. I had the same problem...connect to a lead that doesnt have varying voltage. I have two dimmer leads in mine, one is straight 12v the other is adjustable based on the dimmer knob. Use the one that is straight 12v...if you dont have a lead like that you can tap into your headlight switch/knob.
    Another option...which someone else has posted you can put a relay on the dimmer lead so that the lights on the infill will either be on or off, but not inbetween voltages.
    The other option you have is to have the lights come on all the time and hook your dimmer leads up to the accessory power. This will also dim the display though.
    Remember you can also hold the mode button to dim the display.
    Mitsubishi Eclipse 2006 GT
    Infill T3 running StreetDeck
  1. Replies: 14
    Last Post: 09-11-2008, 04:14 PM
  2. Constantly removing the screen 7" lilliput advice
    By steveb in forum LCD/Display
    Last Post: 04-17-2007, 11:56 AM
  3. Cracked Touch Screen!
    By bmather9 in forum LCD/Display
    Last Post: 04-17-2007, 05:31 AM
  4. Non-VGA screen to VGA
    By xxMIKExx in forum LCD/Display
    Last Post: 04-10-2007, 10:18 PM
  5. FAQ: LCD Technologies
    By dontpntpool in forum LCD/Display
    Last Post: 03-15-2007, 01:20 AM
