I have the same problem and it turned out to be my ribbon cable from the front panel to the pcb behind it. The cable is difficult to source here are the places i found it, http://www.digitalww.com/store/prodd...asp?prod=RC001
http://www.alancomputech.com/ffc-40p-100mm.html
the one from digitalww is the best match, its 87mm long while the other is 100mm long the one installed in the t3 s 80mm long and 20mm wide with 40 pins. I figured it out by testing a cable that came with my 1.8 inch zif drive to usb converter.
LinkBack URL
About LinkBacks
