Help required with Infill T3 - power up
Hi everyone,
I've just acquired a secondhand Infill T3 and am having trouble getting it to fire up on a Molex supply.
I have to 'fiddle', plugging and unplugging the 2 unit's power cables and the large black connector that links the units whilst pushing the PC unit's power button. Every once in a while I get lucky and it starts - I then plug in the screen and it opens to show the normal boot screen however the hard drive is not being found. I've tried swapping with a spare 40Gb HDD and still no luck.
Is this a problem with not enough power getting to the unit or something else?
I notice the fan on the back of the PC unit is running when the ignition wire is connected without the unit actually being on.
Also, I sometimes get continuous flashing LEDs on the PC unit?
The PSU is rated at 30A on the 12v rail and is 550W but a voltage tester shows 11.44volts.
Unfortunately I don't have any instructions apart from a wiring install I found on the 'net.
Any help would be very welcome!!
Thanks,
David
