Results 1 to 3 of 3
Thread: External Hard Drive USB
    Aug 2006
    Looking for a External hard drive Specs have to match the following.
    Size: 300gb Or more
    Power: Any thing that i can power off the car battery (Hopefully DC not AC)
    Read Speed RPM: Any thing that will Stream Movies perfect.
    Low Bitrate Thelgord's Avatar
    Jan 2007
    Wahiawa, HI
    Size: 300gb Or more
    Size: Easy to find
    Power: Again not really a problem
    Read Spead RPM: Lets talk
    RPM is how fast the disk spins and while it is used for marketing, I have seen some SCSI HD's with a much lower RPM but amuch higher data transfer rate (DTR). This is really the number you should look at and is listed on the packaging of just about every HD made. Really though, as long as you use Firewire instead of USB just about any should work fine. WalMart actually has some that will suit your needs.
    CarPuter
    Planning....[||||||||||]60%
    Parts.......[||||||||||]20%
    Construction[||||||||||]0%
    Software....[||||||||||]0%
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Firewire is a happy thing since 6pin connections also provide power!
  1. External Hard Drive in car????
    By newboy in forum Newbie
    Last Post: 04-06-2007, 06:14 AM
  2. Can I use a USB 2.5 hard drive for OS?
    By GFridrich3 in forum General Hardware Discussion
    Last Post: 09-17-2006, 11:48 PM
  3. USB Hard Drive
    By jjazz in forum General Hardware Discussion
    Last Post: 08-08-2006, 01:16 PM
  4. annoying restart needed for laptop to detect external usb hard drive
    By minghi in forum General Hardware Discussion
    Last Post: 04-07-2005, 01:37 PM
  5. FS: USB hard drive enclosure
    By Alives in forum Classified Archive
    Last Post: 06-11-2002, 06:16 PM
