Well used long enough to install it. Loaded with no drivers, Plugged in receiver let it sync with the mouse and up and running. With a flick of the wrist it moves the mouse pointer accurrately. You can use the windows mouse options to speed up and slow down the movement speed(I will try slowing it down a tad.) Installed the control software and it gives you the options to set the hotbuttons to control just about every aspect of windows except inputting keyboard qwerty keys. Rechargable battery with charging dock(really only downer so far, the dock is not designed to securely hold the mouse to charge. You would need to charge it while the car was stopped, or design a way to secure it to the dock better.) This can also be used as a traditional mouse for when you have someplace to sit it on. It also came bundled with a mini keyboard measuring about 14-16"(I will get an exact measurement later.) Keyboard has all the media, volume, and internet shortcut buttons and is wireless using the same receiver as the mouse so you only need one usb port for both. I am still hoping to get my ondigital keyboard working but this would be a nice backup in the trunk if ever needed.
LinkBack URL
About LinkBacks
I just seem to be so busy. Plus i dont want to do any more work on my truck. I need!!! to get a new car/truck this year. Then i will install everything.
