Results 1 to 4 of 4
Thread: sp13000 usb header compatibility
    Nov 2006
    I just want to know if this http://www.frontx.com/cpx108_2.html is compatible with my mobo. I'm planning to get 2 of these because It looks very easy to mount it on my dash.
    Elsewhere
    Yes.
    The headers for USB ports are pretty much universal.
    For future reference, you can compare the pin-out of the FrontX pieces to what is in your motherboard manul (or silkscreened on the board itself).
    How about the Wiki?
    Nov 2006
    Thanks for the quick reply, I'm ordering 2 of these now...
    Maximum Bitrate DeltaFX's Avatar
    France
    Beside the pseudo universality of usb pin header, the page you link is pretty clear and cover most of the possible cases you may enconter. It's mostly a matter of reading your mobo manual, and figuring what is the situation.
    And if the pinout is really different you always can rewire the plug :use a pin to lift gently the plastic tabs that hold the connectors in the plug, pul them out of the plastic part, replug where there suposed to be to suit your mobo pinout
    Now Galileo is real. Muhahahahaha :p
  1. HOWTO: Power a USB Hub for the G4
    By god_of_cpu in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 06-05-2010, 10:17 PM
  2. A couple questions about wiring up USB.
    By gthing in forum Power Supplies
    Last Post: 09-06-2007, 06:32 PM
  3. Help: VIA EPIA MII10000 Onboard USB Header
    By m1c4a37 in forum General Hardware Discussion
    Last Post: 02-13-2007, 02:06 AM
  4. SP13000 USB problem, won't recognize anything
    By Diewlay Lowmo in forum General Hardware Discussion
    Last Post: 06-04-2006, 01:16 PM
  5. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
