Hello everyone, I need help trying to put an aux input in my 01 olds aurora using the cd changer cable. You see companies like peripheral and pac audio make adapters that will allow me to do this ( they list my car and year under the compatible cars). The problem I am having is that i can not locate the cd changer connection in my car.
It is a gm class 2 car and uses the 32 pin dock and lock connection and it is a bose system. Behind the factory deck there are only inputs for the 32 pin dock and lock connection as well as the ant. I have searched all over the trunk (that is where peripheral and pac audio say the factory connection is run) and am still not able to find a connection that might allow me to connect a cd player. It has a bose system but i looked by the bose amplifier and there are still no available connections.
All i need to know where the cd changer connection is in my car or if there even is one. Or where i would be able to find someone that can tell me where the connection is. And if you know any other options i might have in terms of adding an aux in other than an fm modulator or replacing the factory system.
Any help would be much appreciated as this is drving me crazy. I am just hoping someone will be able to help me out. Plzzzzz let there be someone out there.
