Results 1 to 5 of 5
Thread: Powermate or Nulooq, how to control multi-apps at once?
    Mar 2007
    Hi,
    I'm running Centrafuse and I have Skinbedder to embedd iGuidance within CF. Problem is, when I have iGuidance within CF, it's considered 2 windows, so I can only control one program only at a time. I have to keep tapping on the screen to go either.
    I wonder if there's a better to deal with this? Or is there any program I can use to use keyboard shortcuts to "get focus", so I can assign the buttons on the Nulooq to do just that.
    It's getting so close to finish off the project. Thanks guys.
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    You need CFiG
    http://www.fluxmedia.net/downloads.aspx
    Very last plugin on the page.
    It's a proper plugin to let you use iguidance embedded into to CF without having to use skinbedder etc
    I installed my carpc into my pet Kangaroo, mate.
    Mar 2007
    The only thing is I like the skinbedder so I have more screen for map, I wonder if "AutoIT" can do the trick? Not sure how to use that program though. Thanks for your suggestion.
    Nov 2006
    How much screen do you need for your map? You can click the box in the upper right corner (next to 'Trip') that will expand the map so that only the music controls at the bottom are visible.
    I haven't used AutoIT either, but from I've read/seen it could work. The problem there is that once you have the script ready to switch the windows, you still need to tell the script to execute and do the swap...
    Mar 2007
    Trying "AutoIT" right now, don't have a clue how it works. It maybe too complicated for me!
    Tried CFIG, still can't control Zoom In/Out of iGuidance. Maybe a mouse macro will work, just need to move the cursor to the right place and click.
  1. smaller than that powermate usb volume control
    By dim-8 in forum Input Devices
    Last Post: 08-21-2007, 09:07 AM
  2. CarPC Remote Control feature
    By liquid_smoke in forum PhoneControl
    Last Post: 04-06-2005, 03:21 AM
  3. Replies: 3
    Last Post: 05-26-2004, 05:08 AM
  4. Griffin Powermate volume control help
    By bklynkaos in forum Input Devices
    Last Post: 02-08-2004, 10:48 PM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
