Since you have it torn apart, find where the touch controller connects to the main board and look for cold solder junctions on the 5 wire input and outputs (where the usb wires solder to the board and where the usb controller solders into the main board)...if they look iffy, just touch them with a soldering iron and reflow the connections. You'll probably have to reload the driver after. The only other thing to check is to make sure the LCD is not warping and causing a false touch when it's heating up.
LinkBack URL
About LinkBacks
