Results 1 to 3 of 3
Thread: malfunctioning touchkit touchscreen
    Nov 2006
    I have begun moulding my 8" screen into the dash.
    everything was working fine, until i wired it into the car.
    On the test bench I just used a psu, but in the car I have the 12v line (m2atx) powering the screen and a regulator on this 12v line providing 5v for a slot load dvd drive.
    In the car - at first everything worked.
    Then the touch screen lost the y-axis - The cursor responded to touch but was stuck at the top of the screen.
    Then it stopped responding to touch at all.
    I pulled the bezel out to find the regulator scalding hot, so i disconnected it and cut it out (the dvd drive was not my greatest concern).
    Now - my question is this: What has failed?
    The USB touch controller board is recognised by the touchkit drivers. But touches are not picked up at all.
    Has my controller board failed?
    If so - why? The regulator ran on the 12v line, and is electrically isolated from the touch controller, save for the possibility of a short. (they were in close proximity).
    Or has the 4wire resistive overlay failed for some reason?
    My flat mate has the same screen so I will try to pilfer his touch controller.
    Its a real pain since my moulding is a first attempt, using flexible epoxy bumper repair stuff, and my touchscreen is not disassemble-able so it is moulded in permanently.
    Anyone know of a source for replacement controllers?
    Nov 2006
    smashed it apart (cheap glued together crap) and in the process found that the touch panel had seperated from its connector
    unfortunately a ribbon cable was torn in the process and a 5th of the screen was lost.
    one 8" screen successfully junked.
    FLAC Nomader's Avatar
    Apr 2006
    can't you fabricate it as a 7''
  1. Hardware Review: Provision 8" 16:9 VGA Touchscreen
    By lightman in forum The Review Palace
    Last Post: 06-15-2009, 09:02 AM
  2. Lilliput Touchscreen problem
    By eddiero in forum Input Devices
    Last Post: 10-13-2006, 11:19 PM
  3. Motherboard and Touchscreen don't love each other...
    By kevpriest in forum General MP3Car Discussion
    Last Post: 07-27-2006, 10:25 AM
  4. Touchkit problems
    By GnatGoSplat in forum LCD/Display
    Last Post: 05-02-2006, 04:43 PM
  5. USB Touchscreen Problem
    By skeeter007 in forum Input Devices
    Last Post: 10-07-2004, 03:49 PM
