Results 1 to 3 of 3
Thread: Problem with lilliput software
    May 2007
    Poland
    I have a lilliiput 7'' in dash touch screen. The monitors works fine but I have a problem with a sound when touching the panel. THe sound can not be turned off, I have tried advanced settings but it seems that it is not working, can not even change the pitch or anything, when I uncheck sound or it is checked there is no difference. For me it sounds like a software lilliput problem..any ideas? how to turn this off?
    thanks
    Media Engine Audi Skin running on Compaq Evo 1,6Ghz 512RAM 200HDD,Tv card, connected to lilliput 7'' touch screen
    Elsewhere
    1 - If you're not using the latest touchkit drivers, I suggest doing so: http://www.eeti.com.tw/web20/eg/drivers.htm
    2 - There is an option in there to turn off the beep on press option in the touchkit control panel. Is this where you're turning off the beep on press?
    How about the Wiki?
    May 2007
    Poland
    thanks for advice, I have changed the drivers and it works fine now
  1. Elmscan 5 w/bluetooth wireless obd scanner reviews
    By speedy007 in forum The Review Palace
    Last Post: 06-02-2008, 06:59 PM
  2. Lilliput Touchscreen Driver Problem.
    By gleinz in forum LCD/Display
    Last Post: 01-12-2007, 12:30 AM
  3. Lilliput Problem
    By Tightan7369 in forum LCD/Display
    Last Post: 10-04-2005, 03:03 PM
  4. Lilliput power supply problem
    By davinder in forum Power Supplies
    Last Post: 01-18-2005, 09:47 AM
  5. Lilliput Touchscreen Problem
    By BrUTaL in forum LCD/Display
    Last Post: 10-23-2004, 11:52 AM
