+ Reply to Thread
Page 16 of 40 FirstFirst ... 67891011121314151617181920212223242526 ... LastLast
Results 151 to 160 of 400
Thread: xbox360 chatpad, awsome backlit mini keyboard
  1. #151
    Nov 2007
    Quote Originally Posted by mungewell View Post
    My other projects have be GPL'ed licensed, which prevents commercial exploitation of 'our' work, but still allows openness for others to build on our combined knowledge. I would prefer to work under a similar license.
    This is a common misconception. GPL does not prevent commercial exploitation, it just requires commercial users to contribute back changes with similar licensing. There is absolutely no legal reason why I can't take any GPL'd project, change the name, and sell it. I just have to make the source available to those to whom I distribute the package, and those changes have to be GPL'd.
    That said, I've personally been going with the MIT license for stuff, because I think of it as more-free. It really is a "do what the hell you will" with it license. Personally, I'm either going to reserve all rights or give it all away without requirements.
  2. #152
    Nov 2007
    Quote Originally Posted by c0nsumer View Post
    You are assuming that I misunderstand the GPL. I am fully aware that a company can manufacture and sell my GPL projects, and I encourage them to do that as not everyone who might be interested will be able to produce the hardware themselves. I simply can't commit to manufacturing the projects myself.
    The GPL does (in theory) ensure that the improvements are fed back to the community and that is what I strive to achieve. Personally I prefer the hardwork (and fun) I've done on a project not to be simply 'taken from me'. The choice of a license is not a simple one....
    Mungewell.
  3. #153
    Nov 2007
    Another reason to choose the GPL is that a fair portion of the '2). Alternative Firmware' has already been done in the pic-key project (which itself is GPL'ed).
    See:
    http://mudlist.eorbit.net/~adam/pickey/
    Munge
  4. #154
    Nov 2007
    How about option 3: A USB driver that interprets the existing controller/chatpad messaging so no extra HW is required. Predicated on observing/deciphering the USB handshaking between PC and controller/chatpad.
  5. #155
    Nov 2007
    CrazyIvan, I agree.
    There is a large community of users who want to use the 360 controller + chatpad with a PC, no car involved. For those users, I think that a software only solution is the best choice.
    My company would like to use the controller + chatpad on OSX. We're willing to throw some money at this..
    It seems to me that the first step is to capture the USB conversation that happens between an XBOX 360 and the controller from when you first plug it in to when you type some stuff.
    I believe that a device such as this: http://www.getcatalyst.com/product-conquest.html could be used to capture that conversation.
    I've got an XBOX 360, and I've got a USB controller + chatpad. Can someone recommend a cheaper USB capture device? That one I linked to is like $1000... Or, does anybody want to buy a USB capture device next month? Used only once... $900!
    Mungewell,
    Good work. I'm considering starting a project as well--maybe we should work together. My resources include a wiki, project management site, subversion server, etc. I host those myself, but, sourceforge is good, too. If there is something that we'll need that sourceforge doesn't provide, I should be able to provide it.
    The only step I've mentioned so far is capturing the USB conversation between the XBOX and the controller + chatpad. After that, we'd want to hook it up to a PC and start throwing out own mimicked USB packets at it and see what happens. Then we can make a library of functions that do stuff for us, like, activate_chatpad() and switch_controller_light_on(int whichLight).
    I'm far more familiar with Linux than OSX, by the way. Anybody know if a Linux device driver (kernel module) is similar to an OSX device driver?
    I've configured my profile here on mp3car.com to forward messages to my email account, so please feel free to contact me! Let's get a wiki thrown up--it'll help the hardware-solution guys, too!
    Cheers,
    --Dave Loyall
    Omaha, Nebraska, USA
  6. #156
    Constant Bitrate thermoptic's Avatar
    Aug 2007
    @c0nsumer:
    Probing the test points will get you hotter signals that are TTL friendly. Refer to my previous schematic. TP1 connects to pin 18 RX/DT (via next to C2 connects to via above R15 silkscreen). TP2 connects to pin 17 TX/CK (via near TP8 silkscreen to via at end of TP2 trace). Earlier NULs were sampling glitches. I don't see any traffic with XBOX absent. I won't spend anymore time here without new information.
    @mungewell:
    Have you traced the signals for the JP1 connector? I see you popped the PIC in your PCB posts. Thanks for tracing the keypad matrix. I think you are on the most deterministic path to success with a new PIC running custom code. I suppose you own a PIC interface kit? Is it possible to run in-system debug without destroying environment (i.e. JTAG)? If so, we can dump the EUSART registers and get the skinny on the link settings. I think a separate project is a great idea. For something as simple as this project, I would opt for MIT or BSD license.
    @CrazyIvan:
    The purely software approach is definitely much harder; probably impossible without inside help. If you were successfully in reverse-engineering the USB link and controller access, I would worry about D |\/| C 4 issues (sshhh ). Microsoft is making money on the controller and accessories. I suppose decoding the UART interface would enable competitor chatpads, so even this may be an issue. Re-purposing the chatpad with complete PIC rewrite for a non-XBOX task should be OK since Microsoft still makes money on the Messenger Kit sales with no controller interface details divulged. For the lawyers following this thread, this is the option that I am choosing since I want to help Microsoft grow their sales! Oh, and BTW, a PC driver would also help boost sales.
    We'll that's enough chatpad for this week Time to grab a cold one and enjoy the four-day weekend.
  7. #157
    fka - Nextabyte_Matt ioi8's Avatar
    Apr 2006
    Cleveland
    nice matrix
    Hey, nice job on figuring out the matrix.
    I wouldnt mind putting it on the website, could be for the better. But would microsoft aprrove of it if someone their people found out about the project. Dont you think they check that website to see if people are modifing there stuff they are not supposed too?
    So, how do you guys wanna go about this? Im all for trying not trying to reprogram the pic. I would rather convert the uart signal to something the computer can use and transfer that data to something like a keyboard input.
    This way, if we cant figure out how to do it, at least the chatpad is still functional.
    I think im soon gonna buy me a chatpad and the the uart (3.3v) to usb convetor cable. Hopefully, i will be able to create a small program to trasfer that data to keyboard input.
  8. #158
    Nov 2007
    Too obvious...
    Hi,
    New member here, well sorta, been on ages ago, before you could even buy a handheld MP3 player...
    Anyways, I visited again recently, as when I used to frequent this was a superb site, glad to see the community is as strong as ever with some amazing projects and a wealth of information and brilliant ideas...
    My background is I've been putting PCs in cars since PCs were small enough to be stealthy, and I've progammed Computer Games all my life, and have fiddled lots with electronics and PIC stuff as a hobbiest, and done plenty of Pro ICE installs comps...
    Anyway, not to detract from this thread, I have a couple of ideas that will work and get this nice little keypad usable...
    It's been touched upon but not explored, I've read the whole thread and no-one seems to have pointed this out, forgive me if I missed it, but here goes...
    Another way instead of trying to reverse engineer, or reprogram this little device...
    Simply use the keypad and it's matrix alone, ditch all the electronics then use one of the two following ways to interfeace it...
    1. Buy a cheap USB keyboard, rip out the electronics, attach it to the matrix from the keypad you've dismantled and you have a USB keyboard.
    Equally use the same method with a PS2 keyboard, and you have a PS2 version...
    2. If from reading the first page from a post about the similar device for the Playstation 2
    this device actually does just work in XP without additional drivers. Then rip this appart, use it's electronics, and match it to the Xbox KB Matrix and hey presto...
    If I'm wrong, or I've missed somethinhg dead obvious, my apologies in advance... But would this do the job without the hard reverse enngineering neccessary to get it to work...?
    Some amazing project on this site, I've got lots of reading to do before I decide on what to add to my car....
    Keep up the amazing work guys, love this site, and all the people willing to get theirs hands dirty and share their hard work...
    N1
    Frank...
  9. #159
    Apr 2006
    Cleveland
    Hmmmmm
    Besides the smallness and backlit of this keypad..... are there any other pros to converting this keypad?
    Are there any other keyboards like this? I cant find anything on the net that is this small that connects to a pc port.
    Does anyone else know of a keyboard this small or slightly larger? It doesnt have be backlit, but it would be a great feature.
    And after seeing the matrix of the keypad.... im kinda thinking about trying to reprogram the controller. Although the chip is probably a burn once only chip. Your gonna have to replace the whole chip.
  10. #160
    Nov 2007
    Quote Originally Posted by ioi8 View Post
    Yes, it'll definitely annoy old Billie boy ;-)
    I think the smallness of the this keyboard is the key (excuse the pun) feature. It is a good size for in car, but also for embedded and wearable applications. With the use of a dremell you even get a fairly nice bezel.
    The hardware does have limitations though, as there are no diodes in the matrix the keyboard will not cope well with multiple keys pressed at once - it's intended as a thumb keypad rather than touch typing.
    I am in the process of registering a new project with Sourceforge, and will let everyone one know the details once that's up and running. I thought 'Gnatpad' would be a good name. Combining the 'small as a gnat' keyboard and the 'GNU' (assuming people are happy contributing to GPL code) connection. The re-use the Pic-Key code will speed up development considerably.
    I believe that reprogramming will be the way forward (at least to start with). PICs are cheap to get hold of and fairly easy to code with, and with my previous projects I have enjoyed the aspect of teaching people a new skill...
    I don't think that the 16F833 comes in a OTP part, it isn't mentioned in the datasheet. It does support Debug port and Low Voltage Programming, however these may be disabled with the M$ firmware. Who knows perhaps they have been slack and not set the security bits so that we can have a snoop at what they've done.
    @thermoptic - unfortunately I don't have any fancy PIC tools, I've just used home built programmers and the like....
    I'm going to try to get the component side trace out, but I'm swamped with other things at the moment.
    Cheers,
    Mungewell.
+ Reply to Thread
  1. PDA Mini Keyboard
    By BriansNSane in forum Input Devices
    Last Post: 02-08-2006, 08:17 PM
  2. FS....Super Mini Electron luminescent Keyboard
    By Letsride in forum Classified Archive
    Last Post: 06-13-2005, 03:18 AM
  3. Industrial mini keyboard -ebay
    By g60 in forum Classified Archive
    Last Post: 04-18-2001, 07:51 PM
  4. Backlit Keyboard
    By Caviar in forum General Hardware Discussion
    Last Post: 04-03-2001, 10:35 PM
  5. backlit keyboard
    By blkdragon6 in forum General Hardware Discussion
    Last Post: 12-04-1999, 12:47 AM
