Page 32 of 40 FirstFirst ... 22232425262728293031323334353637383940 LastLast
Results 311 to 320 of 400
Thread: xbox360 chatpad, awsome backlit mini keyboard
  1. #311
    Jun 2008
    Quote Originally Posted by jeduars View Post
    yeah i'm curious as to why it only works for the wired
    The way the wired and the wireless controller transmit data is quite different. So having support for one doesn't help you much with the other. Another probably much bigger issue is that you can simply plug a USB protocol analyser between the controller and a real Xbox360 and then see how they communicate. With the wireless one on the other side you can't do that as its a proprietary wireless protocol. You could of course plug a USB protocol analyser between the wireless adapter and a Windows PC, but as Windows doesn't support the chatpad either, that won't give you much info.
  2. #312
    Dec 2008
    hey guys I got a hold of a mac, a wired controller, the chatpad, and the latest version of this
    driver
    http://tattiebogle.net/index.php/Pro...ller/OsxDriver
    and I can confirm the chatpad works, however i have not been able to find good USB analysis tools for OSX and i don't have a lot of experience with usb devices on osx, can anybody suggest a next step?
  3. #313
    Nov 2007
    driver
    You could try and find someone that has access to an external USB capture device that you could borrow. The other option is to talk to the author of the Mac driver and ask how they did it.
    I have access to Mac's, wireless controllers and USB capture devices. Where's the cheapest place to source a Chatpad from these days? I'm in Canada.
  4. #314
    Dec 2008
    I tried contacting the people behind the driver, but no luck. i never got a reply. I've been trying to figure out whatever i can from looking at apple's usbtracer and usb prober but frankly i'm not very good at this. the easiest way of getting a cheap chatpad is ebay, or craigslist.
  5. #315
    Jun 2008
    Could you post the logs somewhere, might provide some interesting info for others who don't have a Mac?
    My try to contact the author of the MacOSX driver hasn't been successful either.
  6. #316
    Dec 2008
    [CODE][CODE]ok, i have high hopes that someday someone will get a driver for windows.
    I'm not experienced with USB development, trying to reverse engineer this driver is probably a very complicated task , one that i wish i had time to do. but in hopes of someone being able to figure out as much as possible I'll post whatever you guys need.
    I have to spend some time trying to figure out the usbtracer program (it hard to isolate only the requests from the controller, since everything on my mac is usb and polls all the time)
    For starters I'm going to post the device information displayed by mac os x which is probably already well known (1 dev 4 interfaces, endpoints blabla)
    Code:
    Full Speed device @ 3 (0x1A200000): .............................................   Vendor-specific device: "Controller"
        Port Information:   0x001a
        Device Descriptor
            Descriptor Version Number:   0x0200
            Device Class:   255   (Vendor-specific)
            Device Subclass:   255   (Vendor-specific)
            Device Protocol:   255
            Device MaxPacketSize:   8
            Device VendorID/ProductID:   0x045E/0x028E   (Microsoft Corporation)
            Device Version Number:   0x0110
            Number of Configurations:   1
            Manufacturer String:   1 "\251Microsoft Corporation"
            Product String:   2 "Controller"
            Serial Number String:   3 "0D03587"
        Configuration Descriptor
            Length (and contents):   153
            Number of Interfaces:   4
            Configuration Value:   1
            Attributes:   0xA0 (bus-powered, remote wakeup)
            MaxPower:   500 ma
            Interface #0 - Vendor-specific
                Alternate Setting   0
                Number of Endpoints   2
                Interface Class:   255   (Vendor-specific)
                Interface Subclass;   93   (Vendor-specific)
                Interface Protocol:   1
                Raw Descriptor (hex)    0000: 11 21 00 01 01 25 81 14  00 00 00 00 13 02 08 00
                Raw Descriptor (hex)    0010: 00
                Endpoint 0x81 - Interrupt Input
                    Address:   0x81  (IN)
                    Attributes:   0x03  (Interrupt no synchronization data endpoint)
                    Max Packet Size:   32
                    Polling Interval:   4 ms
                Endpoint 0x02 - Interrupt Output
                    Address:   0x02  (OUT)
                    Max Packet Size:   32
                    Polling Interval:   8 ms
            Interface #1 - Vendor-specific
                Alternate Setting   0
                Number of Endpoints   4
                Interface Protocol:   3
                Raw Descriptor (hex)    0000: 1B 21 00 01 01 01 83 40  01 04 20 16 85 00 00 00
                Raw Descriptor (hex)    0010: 00 00 00 16 05 00 00 00  00 00 00
                Endpoint 0x83 - Interrupt Input
                    Address:   0x83  (IN)
                    Max Packet Size:   32
                    Polling Interval:   2 ms
                Endpoint 0x04 - Interrupt Output
                    Address:   0x04  (OUT)
                    Max Packet Size:   32
                Endpoint 0x85 - Interrupt Input
                    Address:   0x85  (IN)
                    Max Packet Size:   32
                    Polling Interval:   64 ms
                Endpoint 0x05 - Interrupt Output
                    Address:   0x05  (OUT)
                    Max Packet Size:   32
                    Polling Interval:   16 ms
            Interface #2 - Vendor-specific
                Alternate Setting   0
                Number of Endpoints   1
                Interface Protocol:   2
                Raw Descriptor (hex)   0000: 09 21 00 01 01 22 86 07  00
                Endpoint 0x86 - Interrupt Input
                    Address:   0x86  (IN)
                    Max Packet Size:   32
            Interface #3 - Vendor-specific ..............................................   "Xbox Security Method 3, Version 1.00, \251 2005 Microsoft Corporation. All rights reserved."
                Alternate Setting   0
                Number of Endpoints   0
                Interface Subclass;   253   (Vendor-specific)
                Interface Protocol:   19
            Raw Descriptor (hex)   0000: 06 41 00 01 01 03
    once i figure how to filter the usb activity i'll try and post ome chatpad keystrokes to see what's being sent.
  7. #317
    Dec 2008
    and to demonstrate goodfaith lol, i'll post a sample log file so you can se how painful is to try and figure out traffic (maybe if there's a genius out there they will figure it out with just this lol)
    Code:
    57680.845 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    57680.845 <-  Controller::Return Isoc Done Q End (0x0564c000)
    57680.846 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    57680.847 <-  Controller::Return Isoc Done Q End (0x0564c000)
    57839.291 -> Controller::Control Start      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0, (out)  bmRequestType: 0x41, bRequest: 0x00, wValue: 0x001f, wIndex: 0x0002, wLength: 0x0000
    57839.303     UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    57839.325 <-  Controller::Control End        (0x0564c000) error 0x0
    57841.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    57841.117 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    57841.118     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    57841.120 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    57841.120 <-   Controller::Return Isoc Done Q End (0x0564c000)
    57841.121 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    57841.121 <-   Controller::Return Isoc Done Q End (0x0564c000)
    57841.131     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    57841.132 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    57841.132 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x40 status 0x0
    57841.133     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    57841.133 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    57841.136      Controller::Complete           (0x0564c000) completion: 0x92199b, status:  0x0
    57841.146 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x0 status 0x0
    57841.150 <-  UHCI::End HandleInterrupt      (0x0564c000)
    57841.174    UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    57884.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    57884.104 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    57884.105     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    57884.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    57884.107 <-   Controller::Return Isoc Done Q End (0x0564c000)
    57884.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    57884.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    57884.118     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    57884.119     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    57884.122     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf0040007 0x07ff0000
    57884.123     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    57884.130 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    57884.137 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    57884.141 <-  UHCI::End HandleInterrupt      (0x0564c000)
    57932.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    57932.105 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    57932.106     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    57932.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    57932.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    57932.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    57932.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    57932.118     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    57932.120     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    57932.123     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf0040007 0x07ff0000
    57932.124     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    57932.131 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    57932.138 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    57932.142 <-  UHCI::End HandleInterrupt      (0x0564c000)
    57948.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    57948.102 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    57948.102     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    57948.104 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    57948.104 <-   Controller::Return Isoc Done Q End (0x0564c000)
    57948.105 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    57948.105 <-   Controller::Return Isoc Done Q End (0x0564c000)
    57948.110 <-  UHCI::End HandleInterrupt      (0x0564c000)
    58025.466    UHCI::FilterInterrupt          (0x05649000) active interrupts 0x0001
    58025.498 -> UHCI::Begin HandleInterrupt    (0x05649000)
    58025.499     UHCI::HandleInterrupt          (0x05649000) Processing interrupt USBSTS = 0x0000
    58025.505 <-  UHCI::End HandleInterrupt      (0x05649000)
    58054.330    EHCI::Primary Interrupt        (0x055cb000) enabledInterrupts 0x0000001f activeInterrupts 0x00000008, Frame: 8461312, microframe: 1
    58680.875 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    58680.875 <-  Controller::Return Isoc Done Q End (0x0564c000)
    58680.876 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    58680.876 <-  Controller::Return Isoc Done Q End (0x0564c000)
    58841.218 -> Controller::Control Start      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0, (out)  bmRequestType: 0x41, bRequest: 0x00, wValue: 0x001e, wIndex: 0x0002, wLength: 0x0000
    58841.236 <-  Controller::Control End        (0x0564c000) error 0x0
    58841.253    UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    58843.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    58843.117 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    58843.118     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    58843.120 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    58843.120 <-   Controller::Return Isoc Done Q End (0x0564c000)
    58843.121 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    58843.121 <-   Controller::Return Isoc Done Q End (0x0564c000)
    58843.131     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    58843.132 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    58843.133 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x40 status 0x0
    58843.133     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    58843.134 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    58843.137      Controller::Complete           (0x0564c000) completion: 0x92199b, status:  0x0
    58843.145 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x0 status 0x0
    58843.148 <-  UHCI::End HandleInterrupt      (0x0564c000)
    58843.172    UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    58860.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    58860.115 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    58860.118     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    58860.122 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    58860.122 <-   Controller::Return Isoc Done Q End (0x0564c000)
    58860.125 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    58860.126 <-   Controller::Return Isoc Done Q End (0x0564c000)
    58860.148     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    58860.152     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    58860.159     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf0040008 0x08ff0000
    58860.160     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    58860.176 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    58860.193 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    58860.200 <-  UHCI::End HandleInterrupt      (0x0564c000)
    58908.074    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    58908.108 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    58908.109     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    58908.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    58908.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    58908.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    58908.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    58908.122     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    58908.125     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    58908.128     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    58908.128     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    58908.205 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    58908.212 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    58908.216 <-  UHCI::End HandleInterrupt      (0x0564c000)
    58920.074    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    58920.091 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    58920.092     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    58920.094 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    58920.095 <-   Controller::Return Isoc Done Q End (0x0564c000)
    58920.096 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    58920.096 <-   Controller::Return Isoc Done Q End (0x0564c000)
    58920.106     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    58920.108     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 1, (in)  actual: 20, status: 0x0
    58920.111     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 1  (in)  length: 20, data: 0x00140000 0x0000f0fc
    58920.112     Controller::Complete           (0x0564c000) completion: 0xfd91d4, status:  0x0
    58920.130 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 1, (in)  reqCount: 32
    58920.137 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    58920.141 <-  UHCI::End HandleInterrupt      (0x0564c000)
    58940.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    58940.134 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    58940.136     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    58940.140 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    58940.141 <-   Controller::Return Isoc Done Q End (0x0564c000)
    58940.143 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    58940.143 <-   Controller::Return Isoc Done Q End (0x0564c000)
    58940.167     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    58940.171     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    58940.181     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    58940.181     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    58940.242 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    58940.249 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    58940.253 <-  UHCI::End HandleInterrupt      (0x0564c000)
    58972.074    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    58972.105 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    58972.106     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    58972.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    58972.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    58972.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    58972.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    58972.114 <-  UHCI::End HandleInterrupt      (0x0564c000)
    58988.107    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    58988.160 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    58988.163     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    58988.167 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    58988.167 <-   Controller::Return Isoc Done Q End (0x0564c000)
    58988.169 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    58988.170 <-   Controller::Return Isoc Done Q End (0x0564c000)
    58988.192     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    58988.195     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    58988.202     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf0048008 0x08ff0000
    58988.203     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    58988.219 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    58988.236 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    58988.242 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59049.469    UHCI::FilterInterrupt          (0x05649000) active interrupts 0x0001
    59049.502 -> UHCI::Begin HandleInterrupt    (0x05649000)
    59049.503     UHCI::HandleInterrupt          (0x05649000) Processing interrupt USBSTS = 0x0000
    59049.509 <-  UHCI::End HandleInterrupt      (0x05649000)
    59078.316    EHCI::Primary Interrupt        (0x055cb000) enabledInterrupts 0x0000001f activeInterrupts 0x00000008, Frame: 8460288, microframe: 1
    59100.080    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59100.146 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59100.148     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59100.152 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59100.153 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59100.155 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59100.156 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59100.179     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59100.184     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59100.190     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    59100.191     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59100.301 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59100.308 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59100.312 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59132.106    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59132.156 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59132.158     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59132.162 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59132.163 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59132.165 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59132.165 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59132.187     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59132.190     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59132.196     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    59132.197     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59132.344 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59132.361 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59132.367 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59180.075    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59180.211 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59180.212     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59180.214 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59180.214 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59180.215 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59180.215 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59180.225     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59180.228     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59180.231     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    59180.231     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59180.288 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59180.295 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59180.298 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59292.075    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59292.100 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59292.101     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59292.103 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59292.103 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59292.104 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59292.104 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59292.114     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59292.116     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59292.120     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    59292.120     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59292.200 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59292.207 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59292.211 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59340.075    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59340.107 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59340.108     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59340.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59340.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59340.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59340.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59340.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59340.123     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59340.125     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    59340.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59340.207 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59340.213 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59340.218 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59372.075    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59372.106 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59372.108     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59372.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59372.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59372.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59372.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59372.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59372.122     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59372.125     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    59372.125     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59372.182 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59372.189 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59372.193 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59452.109    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59452.166 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59452.168     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59452.173 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59452.173 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59452.175 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59452.176 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59452.199     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59452.202     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59452.209     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    59452.210     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59452.363 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59452.380 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59452.387 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59484.074    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59484.105 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59484.106     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59484.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59484.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59484.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59484.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59484.118     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59484.119     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59484.121     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    59484.121     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59484.172 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59484.178 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59484.182 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59532.075    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59532.108 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59532.110     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59532.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59532.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59532.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59532.113 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59532.122     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59532.124     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59532.127     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    59532.127     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59532.216 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59532.223 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59532.227 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59564.075    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59564.107 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59564.109     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59564.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59564.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59564.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59564.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59564.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59564.123     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59564.127     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    59564.127     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59564.185 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59564.192 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59564.196 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59644.080    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59644.136 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59644.138     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59644.142 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59644.142 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59644.144 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59644.145 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59644.168     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59644.171     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59644.177     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    59644.178     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59644.313 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59644.320 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59644.324 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59676.074    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59676.104 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59676.105     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59676.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59676.107 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59676.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59676.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59676.118     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59676.119     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59676.122     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    59676.122     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59676.195 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59676.202 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59676.206 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59680.946 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59680.947 <-  Controller::Return Isoc Done Q End (0x0564c000)
    59680.949 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59680.950 <-  Controller::Return Isoc Done Q End (0x0564c000)
    59724.075    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59724.107 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59724.108     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59724.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59724.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59724.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59724.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59724.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59724.123     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59724.126     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    59724.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59724.184 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59724.191 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59724.195 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59804.104    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59804.153 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59804.156     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59804.159 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59804.160 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59804.162 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59804.163 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59804.186     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59804.189     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59804.196     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    59804.197     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59804.339 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59804.356 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59804.363 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59836.109    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59836.163 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59836.165     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59836.169 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59836.170 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59836.172 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59836.173 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59836.195     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59836.199     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59836.206     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    59836.207     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59836.310 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59836.327 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59836.333 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59843.242 -> Controller::Control Start      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0, (out)  bmRequestType: 0x41, bRequest: 0x00, wValue: 0x001f, wIndex: 0x0002, wLength: 0x0000
    59843.279 <-  Controller::Control End        (0x0564c000) error 0x0
    59843.318    UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    59845.079    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59845.127 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59845.128     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59845.130 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59845.130 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59845.131 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59845.132 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59845.149     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    59845.150 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    59845.151 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x40 status 0x0
    59845.152     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    59845.153 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    59845.157      Controller::Complete           (0x0564c000) completion: 0x92199b, status:  0x0
    59845.173 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x0 status 0x0
    59845.177 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59845.219    UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    59884.075    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59884.106 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59884.107     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59884.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59884.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59884.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59884.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59884.119     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59884.121     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59884.123     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf0048009 0x09ff0000
    59884.123     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59884.131 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59884.138 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59884.141 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59916.091    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59916.107 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59916.108     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59916.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59916.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59916.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59916.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59916.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59916.122     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59916.125     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    59916.125     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59916.205 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59916.212 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59916.216 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59964.091    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59964.107 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59964.107     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59964.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59964.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59964.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59964.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59964.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59964.122     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59964.125     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    59964.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59964.206 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59964.213 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59964.217 <-  UHCI::End HandleInterrupt      (0x0564c000)
    59996.079    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    59996.133 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    59996.135     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    59996.138 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    59996.139 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59996.141 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    59996.142 <-   Controller::Return Isoc Done Q End (0x0564c000)
    59996.163     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    59996.166     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    59996.171     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    59996.172     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    59996.266 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    59996.283 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    59996.290 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00028.075    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00028.104 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00028.105     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00028.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00028.107 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00028.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00028.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00028.117     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00028.118     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00028.120     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    00028.121     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00028.190 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00028.196 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00028.200 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00073.470    UHCI::FilterInterrupt          (0x05649000) active interrupts 0x0001
    00073.501 -> UHCI::Begin HandleInterrupt    (0x05649000)
    00073.502     UHCI::HandleInterrupt          (0x05649000) Processing interrupt USBSTS = 0x0000
    00073.509 <-  UHCI::End HandleInterrupt      (0x05649000)
    00076.108    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00076.158 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00076.159     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00076.163 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00076.163 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00076.166 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00076.166 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00076.187     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00076.191     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00076.197     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    00076.198     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00076.303 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00076.320 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00076.327 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00102.317    EHCI::Primary Interrupt        (0x055cb000) enabledInterrupts 0x0000001f activeInterrupts 0x00000008, Frame: 8463360, microframe: 1
    00108.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00108.130 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00108.133     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00108.136 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00108.137 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00108.139 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00108.140 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00108.162     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00108.165     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00108.171     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf0048009 0x09ff0000
    00108.172     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00108.187 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00108.204 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00108.210 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00156.076    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00156.107 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00156.108     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00156.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00156.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00156.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00156.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00156.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00156.122     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00156.125     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    00156.125     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00156.201 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00156.207 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00156.211 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00188.076    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00188.109 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00188.110     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00188.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00188.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00188.113 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00188.113 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00188.122     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00188.124     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00188.127     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    00188.127     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00188.204 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00188.211 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00188.215 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00236.076    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00236.108 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00236.109     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00236.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00236.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00236.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00236.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00236.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00236.123     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00236.126     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    00236.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00236.182 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00236.190 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00236.193 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00300.091    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00300.107 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00300.108     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00300.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00300.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00300.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00300.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00300.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00300.123     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00300.127     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    00300.127     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00300.207 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00300.214 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00300.218 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00348.076    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00348.107 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00348.108     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00348.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00348.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00348.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00348.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00348.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00348.122     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00348.125     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    00348.125     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00348.182 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00348.190 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00348.194 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00380.080    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00380.122 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00380.123     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00380.125 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00380.126 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00380.126 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00380.136     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00380.137     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00380.140     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    00380.140     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00380.216 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00380.223 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00380.227 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00428.092    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00428.109 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00428.110     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00428.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00428.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00428.113 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00428.114 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00428.123     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00428.125     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00428.128     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    00428.129     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00428.186 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00428.193 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00428.197 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00508.076    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00508.108 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00508.109     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00508.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00508.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00508.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00508.113 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00508.122     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00508.124     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00508.127     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    00508.127     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00508.209 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00508.216 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00508.220 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00540.076    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00540.106 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00540.107     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00540.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00540.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00540.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00540.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00540.120     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00540.121     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00540.124     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    00540.124     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00540.204 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00540.211 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00540.215 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00588.077    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00588.110 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00588.112     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00588.114 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00588.114 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00588.115 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00588.115 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00588.125     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00588.128     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00588.132     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    00588.132     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00588.191 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00588.198 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00588.203 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00652.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00652.113 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00652.115     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00652.117 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00652.117 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00652.118 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00652.118 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00652.128     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00652.131     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00652.134     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    00652.135     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00652.218 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00652.226 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00652.230 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00680.966 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00680.966 <-  Controller::Return Isoc Done Q End (0x0564c000)
    00680.967 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00680.967 <-  Controller::Return Isoc Done Q End (0x0564c000)
    00700.076    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00700.107 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00700.108     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00700.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00700.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00700.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00700.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00700.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00700.122     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00700.126     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    00700.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00700.208 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00700.215 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00700.219 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00732.082    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00732.115 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00732.116     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00732.118 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00732.118 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00732.119 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00732.119 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00732.129     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00732.130     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00732.133     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    00732.133     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00732.190 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00732.197 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00732.201 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00812.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00812.118 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00812.119     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00812.121 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00812.121 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00812.123 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00812.123 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00812.136     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00812.138     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00812.141     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    00812.142     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00812.235 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00812.246 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00812.251 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00845.251 -> Controller::Control Start      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0, (out)  bmRequestType: 0x41, bRequest: 0x00, wValue: 0x001e, wIndex: 0x0002, wLength: 0x0000
    00845.268 <-  Controller::Control End        (0x0564c000) error 0x0
    00845.285    UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    00847.111    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00847.161 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00847.162     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00847.166 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00847.167 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00847.169 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00847.169 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00847.206     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    00847.208 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    00847.210 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x40 status 0x0
    00847.212     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    00847.212 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    00847.220      Controller::Complete           (0x0564c000) completion: 0x92199b, status:  0x0
    00847.226 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x0 status 0x0
    00847.231 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00847.278    UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    00860.077    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00860.106 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00860.107     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00860.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00860.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00860.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00860.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00860.119     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00860.120     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00860.123     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    00860.123     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00860.179 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00860.186 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00860.190 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00892.104    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00892.141 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00892.143     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00892.145 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00892.145 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00892.147 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00892.147 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00892.162     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00892.164     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00892.168     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf004800a 0x0aff0000
    00892.169     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00892.180 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00892.191 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00892.196 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00924.081    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00924.137 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00924.139     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00924.143 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00924.144 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00924.146 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00924.146 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00924.163     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00924.164     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00924.167     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    00924.167     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00924.245 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00924.252 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00924.256 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00972.077    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00972.109 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00972.110     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00972.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00972.113 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00972.113 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00972.114 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00972.123     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00972.125     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00972.128     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    00972.128     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00972.209 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00972.216 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00972.220 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01004.077    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01004.108 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01004.109     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01004.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01004.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01004.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01004.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01004.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01004.123     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01004.126     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    01004.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01004.180 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01004.187 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01004.191 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01020.077    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01020.095 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01020.096     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01020.098 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01020.098 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01020.099 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01020.099 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01020.104 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01052.093    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01052.127 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01052.128     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01052.129 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01052.130 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01052.130 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01052.131 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01052.140     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01052.141     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01052.144     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    01052.145     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01052.219 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01052.227 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01052.232 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01084.093    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01084.108 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01084.109     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01084.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01084.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01084.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01084.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01084.122     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01084.124     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01084.127     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    01084.127     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01084.213 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01084.220 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01084.224 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01097.471    UHCI::FilterInterrupt          (0x05649000) active interrupts 0x0001
    01097.502 -> UHCI::Begin HandleInterrupt    (0x05649000)
    01097.503     UHCI::HandleInterrupt          (0x05649000) Processing interrupt USBSTS = 0x0000
    01097.510 <-  UHCI::End HandleInterrupt      (0x05649000)
    01126.303    EHCI::Primary Interrupt        (0x055cb000) enabledInterrupts 0x0000001f activeInterrupts 0x00000008, Frame: 8462336, microframe: 1
    01132.108    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01132.166 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01132.168     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01132.172 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01132.173 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01132.175 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01132.176 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01132.199     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01132.202     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01132.209     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf004800a 0x0aff0000
    01132.210     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01132.227 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01132.244 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01132.250 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01164.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01164.109 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01164.110     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01164.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01164.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01164.113 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01164.114 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01164.122     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01164.124     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01164.127     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    01164.127     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01164.209 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01164.216 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01164.220 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01196.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01196.097 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01196.098     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01196.100 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01196.100 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01196.101 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01196.101 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01196.111     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01196.113     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01196.116     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    01196.116     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01196.172 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01196.178 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01196.182 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01244.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01244.108 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01244.109     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01244.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01244.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01244.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01244.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01244.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01244.123     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01244.126     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    01244.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01244.207 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01244.214 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01244.218 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01276.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01276.110 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01276.111     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01276.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01276.113 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01276.114 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01276.114 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01276.123     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01276.125     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01276.128     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    01276.128     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01276.185 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01276.191 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01276.195 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01324.079    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01324.109 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01324.110     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01324.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01324.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01324.113 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01324.113 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01324.123     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01324.126     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01324.129     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    01324.130     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01324.204 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01324.211 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01324.215 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01356.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01356.110 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01356.112     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01356.113 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01356.114 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01356.115 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01356.115 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01356.124     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01356.126     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01356.129     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    01356.130     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01356.209 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01356.216 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01356.220 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01404.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01404.113 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01404.114     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01404.116 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01404.117 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01404.118 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01404.118 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01404.128     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01404.130     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01404.134     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    01404.134     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01404.200 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01404.208 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01404.213 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01484.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01484.112 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01484.113     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01484.115 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01484.115 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01484.116 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01484.116 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01484.126     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01484.127     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01484.131     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    01484.131     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01484.209 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01484.216 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01484.219 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01516.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01516.108 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01516.109     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01516.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01516.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01516.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01516.113 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01516.122     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01516.124     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01516.127     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    01516.127     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01516.180 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01516.186 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01516.196 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01548.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01548.108 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01548.109     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01548.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01548.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01548.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01548.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01548.122     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01548.123     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01548.126     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    01548.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01548.201 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01548.208 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01548.211 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01596.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01596.108 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01596.109     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01596.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01596.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01596.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01596.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01596.122     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01596.123     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01596.126     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    01596.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01596.183 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01596.190 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01596.194 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01628.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01628.108 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01628.109     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01628.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01628.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01628.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01628.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01628.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01628.122     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01628.125     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    01628.125     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01628.207 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01628.214 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01628.218 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01676.079    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01676.109 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01676.110     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01676.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01676.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01676.113 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01676.114 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01676.123     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01676.125     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01676.128     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    01676.128     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01676.209 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01676.216 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01676.220 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01680.998 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01680.998 <-  Controller::Return Isoc Done Q End (0x0564c000)
    01680.999 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01680.999 <-  Controller::Return Isoc Done Q End (0x0564c000)
    01708.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01708.110 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01708.111     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01708.113 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01708.113 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01708.114 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01708.115 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01708.124     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01708.126     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01708.129     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    01708.129     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01708.185 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01708.192 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01708.196 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01788.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01788.109 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01788.110     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01788.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01788.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01788.113 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01788.113 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01788.122     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01788.123     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01788.126     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    01788.127     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01788.204 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01788.212 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01788.216 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01820.079    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01820.110 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01820.111     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01820.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01820.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01820.113 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01820.114 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01820.123     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01820.124     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01820.127     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    01820.127     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01820.183 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01820.190 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01820.194 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01847.317 -> Controller::Control Start      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0, (out)  bmRequestType: 0x41, bRequest: 0x00, wValue: 0x001f, wIndex: 0x0002, wLength: 0x0000
    01847.334 <-  Controller::Control End        (0x0564c000) error 0x0
    01847.351    UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    01849.079    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01849.109 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01849.110     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01849.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01849.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01849.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01849.113 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01849.123     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    01849.124 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    01849.124 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x40 status 0x0
    01849.125     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    01849.125 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    01849.128      Controller::Complete           (0x0564c000) completion: 0x92199b, status:  0x0
    01849.136 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x0 status 0x0
    01849.140 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01849.163    UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    01868.090    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01868.189 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01868.190     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01868.191 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01868.192 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01868.193 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01868.193 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01868.202     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01868.204     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01868.207     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    01868.207     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01868.285 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01868.292 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01868.296 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01900.079    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01900.110 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01900.111     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01900.113 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01900.113 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01900.114 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01900.114 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01900.124     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01900.126     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01900.129     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf004800b 0x0bff0000
    01900.129     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01900.136 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01900.143 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01900.147 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01948.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01948.111 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01948.111     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01948.114 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01948.114 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01948.115 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01948.115 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01948.126     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01948.127     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01948.131     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    01948.132     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01948.196 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01948.204 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01948.208 <-  UHCI::End HandleInterrupt      (0x0564c000)
    01980.071    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    01980.101 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    01980.101     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    01980.103 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    01980.103 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01980.104 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    01980.104 <-   Controller::Return Isoc Done Q End (0x0564c000)
    01980.114     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    01980.115     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    01980.118     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    01980.118     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    01980.196 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    01980.204 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    01980.208 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02028.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02028.104 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02028.105     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02028.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02028.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02028.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02028.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02028.118     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02028.120     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02028.123     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    02028.124     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02028.201 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02028.208 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02028.212 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02044.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02044.104 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02044.104     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02044.106 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02044.106 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02044.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02044.107 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02044.113 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02060.094    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02060.135 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02060.136     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02060.139 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02060.139 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02060.141 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02060.141 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02060.156     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02060.159     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02060.163     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    02060.164     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02060.237 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02060.249 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02060.254 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02092.104    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02092.160 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02092.162     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02092.166 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02092.167 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02092.169 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02092.169 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02092.192     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02092.196     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02092.203     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    02092.204     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02092.354 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02092.372 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02092.378 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02121.466    UHCI::FilterInterrupt          (0x05649000) active interrupts 0x0001
    02121.483 -> UHCI::Begin HandleInterrupt    (0x05649000)
    02121.484     UHCI::HandleInterrupt          (0x05649000) Processing interrupt USBSTS = 0x0000
    02121.490 <-  UHCI::End HandleInterrupt      (0x05649000)
    02140.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02140.103 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02140.104     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02140.105 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02140.106 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02140.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02140.107 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02140.116     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02140.117     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02140.121     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    02140.121     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02140.179 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02140.186 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02140.190 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02150.297    EHCI::Primary Interrupt        (0x055cb000) enabledInterrupts 0x0000001f activeInterrupts 0x00000008, Frame: 8465408, microframe: 1
    02172.086    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02172.101 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02172.102     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02172.104 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02172.104 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02172.105 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02172.105 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02172.115     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02172.116     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02172.118     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    02172.119     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02172.195 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02172.202 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02172.206 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02220.079    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02220.117 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02220.118     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02220.120 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02220.120 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02220.121 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02220.121 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02220.131     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02220.133     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02220.135     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    02220.136     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02220.191 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02220.198 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02220.202 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02252.107    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02252.165 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02252.168     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02252.171 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02252.172 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02252.174 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02252.175 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02252.197     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02252.201     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02252.208     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf004800b 0x0bff0000
    02252.209     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02252.224 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02252.241 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02252.248 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02300.077    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02300.133 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02300.135     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02300.139 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02300.140 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02300.142 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02300.142 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02300.164     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02300.167     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02300.174     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    02300.175     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02300.325 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02300.344 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02300.350 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02332.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02332.164 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02332.164     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02332.166 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02332.167 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02332.168 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02332.168 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02332.181     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02332.182     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02332.186     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    02332.186     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02332.277 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02332.287 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02332.292 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02380.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02380.103 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02380.104     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02380.106 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02380.106 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02380.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02380.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02380.117     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02380.119     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02380.122     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    02380.122     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02380.180 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02380.187 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02380.191 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02412.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02412.104 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02412.105     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02412.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02412.107 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02412.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02412.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02412.117     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02412.119     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02412.122     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    02412.122     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02412.200 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02412.208 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02412.211 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02444.103    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02444.161 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02444.164     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02444.167 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02444.168 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02444.170 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02444.170 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02444.193     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02444.196     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02444.203     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    02444.204     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02444.352 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02444.370 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02444.378 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02492.088    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02492.143 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02492.146     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02492.149 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02492.150 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02492.152 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02492.153 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02492.175     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02492.180     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02492.186     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    02492.187     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02492.291 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02492.309 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02492.316 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02524.104    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02524.158 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02524.161     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02524.165 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02524.166 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02524.168 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02524.168 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02524.190     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02524.195     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02524.202     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    02524.203     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02524.349 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02524.367 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02524.374 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02572.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02572.117 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02572.118     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02572.120 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02572.120 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02572.121 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02572.122 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02572.133     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02572.135     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02572.139     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    02572.139     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02572.226 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02572.235 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02572.240 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02604.109    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02604.164 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02604.166     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02604.170 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02604.170 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02604.172 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02604.173 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02604.195     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02604.199     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02604.206     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    02604.207     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02604.308 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02604.325 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02604.331 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02681.021 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02681.022 <-  Controller::Return Isoc Done Q End (0x0564c000)
    02681.023 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02681.023 <-  Controller::Return Isoc Done Q End (0x0564c000)
    02684.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02684.102 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02684.103     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02684.104 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02684.104 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02684.105 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02684.105 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02684.113     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02684.115     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02684.119     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    02684.120     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02684.205 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02684.213 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02684.216 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02732.103    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02732.153 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02732.156     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02732.159 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02732.160 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02732.163 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02732.163 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02732.185     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02732.189     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02732.195     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    02732.196     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02732.342 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02732.360 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02732.367 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02764.103    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02764.163 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02764.165     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02764.169 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02764.169 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02764.172 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02764.172 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02764.194     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02764.198     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02764.205     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    02764.205     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02764.307 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02764.324 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02764.331 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02796.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02796.105 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02796.107     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02796.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02796.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02796.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02796.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02796.119     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02796.122     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02796.126     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    02796.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02796.206 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02796.213 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02796.218 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02844.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02844.102 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02844.104     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02844.106 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02844.106 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02844.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02844.107 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02844.117     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02844.119     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02844.124     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    02844.124     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02844.182 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02844.189 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02844.193 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02849.210 -> Controller::Control Start      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0, (out)  bmRequestType: 0x41, bRequest: 0x00, wValue: 0x001e, wIndex: 0x0002, wLength: 0x0000
    02849.226 <-  Controller::Control End        (0x0564c000) error 0x0
    02849.280    UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    02851.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02851.110 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02851.111     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02851.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02851.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02851.113 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02851.113 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02851.151     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    02851.152 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    02851.153 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x40 status 0x0
    02851.154     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    02851.154 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    02851.174      Controller::Complete           (0x0564c000) completion: 0x92199b, status:  0x0
    02851.194 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x0 status 0x0
    02851.198 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02851.261    UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    02876.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02876.090 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02876.091     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02876.093 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02876.094 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02876.094 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02876.095 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02876.104     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02876.106     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02876.110     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf004800c 0x0cff0000
    02876.110     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02876.119 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02876.125 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02876.130 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02924.109    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02924.175 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02924.178     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02924.182 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02924.182 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02924.185 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02924.185 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02924.207     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02924.213     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02924.222     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    02924.223     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02924.334 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02924.344 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02924.349 <-  UHCI::End HandleInterrupt      (0x0564c000)
    02956.141    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    02956.218 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    02956.221     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    02956.224 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    02956.225 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02956.227 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    02956.227 <-   Controller::Return Isoc Done Q End (0x0564c000)
    02956.243     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    02956.247     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    02956.253     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    02956.254     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    02956.368 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    02956.379 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    02956.384 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03004.102    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03004.155 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03004.157     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03004.161 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03004.162 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03004.164 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03004.164 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03004.186     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03004.191     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03004.198     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    03004.198     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03004.311 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03004.327 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03004.334 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03036.106    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03036.161 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03036.163     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03036.167 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03036.168 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03036.169 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03036.170 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03036.191     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03036.196     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03036.203     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf004800c 0x0cff0000
    03036.203     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03036.218 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03036.235 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03036.241 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03068.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03068.104 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03068.105     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03068.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03068.107 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03068.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03068.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03068.113 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03116.106    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03116.166 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03116.169     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03116.173 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03116.174 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03116.176 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03116.177 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03116.199     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03116.204     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03116.213     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    03116.213     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03116.367 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03116.385 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03116.391 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03145.497    UHCI::FilterInterrupt          (0x05649000) active interrupts 0x0001
    03145.549 -> UHCI::Begin HandleInterrupt    (0x05649000)
    03145.551     UHCI::HandleInterrupt          (0x05649000) Processing interrupt USBSTS = 0x0000
    03145.561 <-  UHCI::End HandleInterrupt      (0x05649000)
    03148.107    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03148.159 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03148.160     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03148.164 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03148.165 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03148.167 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03148.167 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03148.188     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03148.192     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03148.199     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    03148.200     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03148.301 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03148.318 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03148.322 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03174.297    EHCI::Primary Interrupt        (0x055cb000) enabledInterrupts 0x0000001f activeInterrupts 0x00000008, Frame: 8464384, microframe: 1
    03196.103    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03196.157 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03196.160     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03196.164 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03196.164 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03196.166 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03196.167 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03196.189     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03196.193     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03196.200     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    03196.201     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03196.348 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03196.365 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03196.373 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03228.102    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03228.134 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03228.137     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03228.141 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03228.142 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03228.144 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03228.144 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03228.167     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03228.171     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03228.178     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    03228.178     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03228.281 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03228.299 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03228.305 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03260.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03260.104 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03260.105     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03260.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03260.107 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03260.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03260.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03260.118     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03260.120     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03260.123     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    03260.123     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03260.199 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03260.206 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03260.210 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03308.103    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03308.160 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03308.163     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03308.167 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03308.167 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03308.169 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03308.170 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03308.192     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03308.196     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03308.203     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    03308.203     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03308.307 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03308.324 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03308.330 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03340.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03340.097 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03340.098     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03340.101 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03340.101 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03340.102 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03340.103 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03340.116     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03340.120     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03340.125     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    03340.125     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03340.220 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03340.231 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03340.235 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03388.103    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03388.154 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03388.158     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03388.161 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03388.162 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03388.164 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03388.165 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03388.187     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03388.191     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03388.197     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    03388.198     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03388.299 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03388.317 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03388.323 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03420.074    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03420.094 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03420.096     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03420.098 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03420.098 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03420.099 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03420.099 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03420.109     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03420.111     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03420.115     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    03420.116     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03420.199 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03420.206 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03420.211 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03468.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03468.192 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03468.194     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03468.196 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03468.196 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03468.197 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03468.197 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03468.207     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03468.209     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03468.213     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    03468.214     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03468.277 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03468.284 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03468.288 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03548.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03548.105 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03548.106     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03548.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03548.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03548.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03548.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03548.119     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03548.121     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03548.124     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    03548.125     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03548.204 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03548.212 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03548.215 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03580.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03580.104 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03580.105     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03580.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03580.107 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03580.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03580.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03580.118     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03580.119     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03580.122     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    03580.122     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03580.199 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03580.206 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03580.210 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03612.077    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03612.133 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03612.136     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03612.140 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03612.141 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03612.143 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03612.144 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03612.166     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03612.171     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03612.178     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    03612.179     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03612.267 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03612.274 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03612.278 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03660.071    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03660.088 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03660.090     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03660.091 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03660.102 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03660.103 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03660.104 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03660.122     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03660.137     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03660.141     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    03660.141     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03660.217 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03660.224 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03660.228 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03681.048 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03681.048 <-  Controller::Return Isoc Done Q End (0x0564c000)
    03681.049 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03681.049 <-  Controller::Return Isoc Done Q End (0x0564c000)
    03692.074    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03692.107 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03692.108     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03692.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03692.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03692.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03692.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03692.119     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03692.122     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03692.125     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    03692.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03692.183 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03692.191 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03692.195 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03740.074    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03740.109 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03740.110     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03740.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03740.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03740.113 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03740.114 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03740.123     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03740.126     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03740.129     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    03740.130     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03740.208 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03740.215 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03740.219 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03772.097    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03772.139 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03772.141     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03772.144 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03772.144 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03772.146 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03772.146 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03772.162     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03772.165     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03772.170     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    03772.171     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03772.248 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03772.255 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03772.259 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03851.332 -> Controller::Control Start      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0, (out)  bmRequestType: 0x41, bRequest: 0x00, wValue: 0x001f, wIndex: 0x0002, wLength: 0x0000
    03851.350 <-  Controller::Control End        (0x0564c000) error 0x0
    03851.369    UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    03853.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03853.105 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03853.106     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03853.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03853.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03853.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03853.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03853.119     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    03853.120 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03853.121 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x40 status 0x0
    03853.121     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    03853.122 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03853.126      Controller::Complete           (0x0564c000) completion: 0x92199b, status:  0x0
    03853.135 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x0 status 0x0
    03853.139 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03853.164    UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    03900.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03900.103 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03900.104     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03900.106 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03900.106 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03900.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03900.107 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03900.117     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03900.119     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03900.122     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf004800d 0x0dff0000
    03900.123     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03900.131 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03900.138 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03900.141 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03932.094    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03932.137 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03932.140     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03932.143 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03932.143 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03932.145 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03932.145 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03932.160     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03932.163     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03932.168     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    03932.168     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03932.275 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03932.287 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03932.293 <-  UHCI::End HandleInterrupt      (0x0564c000)
    03964.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    03964.103 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    03964.104     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    03964.106 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    03964.106 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03964.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    03964.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    03964.117     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    03964.118     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    03964.121     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    03964.121     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    03964.190 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    03964.197 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03964.201 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04012.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04012.104 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04012.105     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04012.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04012.107 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04012.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04012.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04012.118     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04012.120     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04012.123     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    04012.123     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04012.183 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04012.191 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04012.195 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04044.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04044.109 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04044.110     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04044.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04044.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04044.113 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04044.113 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04044.122     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04044.125     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04044.128     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    04044.129     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04044.204 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04044.211 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04044.215 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04092.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04092.104 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04092.105     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04092.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04092.107 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04092.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04092.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04092.118     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04092.120     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04092.123     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    04092.123     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04092.179 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04092.186 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04092.190 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04124.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04124.093 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04124.094     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04124.097 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04124.097 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04124.098 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04124.098 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04124.108     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04124.111     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04124.115     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf004800d 0x0dff0000
    04124.115     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04124.125 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04124.132 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04124.135 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04169.467    UHCI::FilterInterrupt          (0x05649000) active interrupts 0x0001
    04169.512 -> UHCI::Begin HandleInterrupt    (0x05649000)
    04169.513     UHCI::HandleInterrupt          (0x05649000) Processing interrupt USBSTS = 0x0000
    04169.520 <-  UHCI::End HandleInterrupt      (0x05649000)
    04172.089    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04172.106 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04172.107     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04172.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04172.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04172.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04172.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04172.119     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04172.122     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04172.126     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    04172.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04172.208 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04172.216 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04172.220 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04198.297    EHCI::Primary Interrupt        (0x055cb000) enabledInterrupts 0x0000001f activeInterrupts 0x00000008, Frame: 8467456, microframe: 1
    04204.072    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04204.104 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04204.104     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04204.106 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04204.107 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04204.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04204.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04204.117     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04204.119     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04204.122     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    04204.122     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04204.199 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04204.206 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04204.209 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04236.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04236.106 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04236.106     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04236.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04236.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04236.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04236.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04236.119     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04236.121     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04236.125     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    04236.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04236.183 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04236.190 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04236.194 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04284.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04284.107 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04284.109     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04284.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04284.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04284.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04284.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04284.122     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04284.124     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04284.128     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    04284.128     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04284.207 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04284.214 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04284.218 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04316.074    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04316.107 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04316.109     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04316.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04316.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04316.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04316.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04316.122     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04316.124     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04316.129     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    04316.129     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04316.186 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04316.193 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04316.197 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04396.105    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04396.164 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04396.166     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04396.170 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04396.171 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04396.173 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04396.173 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04396.195     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04396.199     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04396.206     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    04396.206     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04396.352 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04396.370 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04396.377 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04444.103    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04444.160 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04444.163     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04444.167 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04444.168 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04444.170 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04444.170 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04444.193     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04444.197     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04444.204     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    04444.204     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04444.306 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04444.324 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04444.331 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04476.074    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04476.106 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04476.108     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04476.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04476.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04476.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04476.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04476.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04476.124     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04476.128     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    04476.128     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04476.213 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04476.221 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04476.225 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04508.074    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04508.105 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04508.107     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04508.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04508.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04508.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04508.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04508.119     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04508.122     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04508.125     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    04508.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04508.184 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04508.191 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04508.195 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04556.104    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04556.156 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04556.158     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04556.162 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04556.163 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04556.165 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04556.165 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04556.187     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04556.190     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04556.197     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    04556.197     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04556.347 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04556.364 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04556.371 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04588.091    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04588.108 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04588.109     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04588.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04588.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04588.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04588.113 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04588.122     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04588.124     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04588.129     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    04588.129     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04588.186 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04588.193 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04588.198 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04636.110    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04636.164 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04636.167     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04636.171 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04636.171 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04636.173 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04636.174 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04636.196     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04636.201     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04636.207     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    04636.208     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04636.355 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04636.374 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04636.381 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04668.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04668.105 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04668.107     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04668.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04668.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04668.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04668.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04668.120     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04668.122     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04668.126     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    04668.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04668.184 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04668.191 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04668.195 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04681.107 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04681.107 <-  Controller::Return Isoc Done Q End (0x0564c000)
    04681.109 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04681.110 <-  Controller::Return Isoc Done Q End (0x0564c000)
    04748.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04748.107 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04748.108     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04748.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04748.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04748.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04748.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04748.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04748.123     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04748.126     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    04748.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04748.210 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04748.218 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04748.223 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04796.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04796.104 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04796.105     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04796.107 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04796.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04796.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04796.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04796.118     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04796.121     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04796.125     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    04796.125     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04796.207 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04796.215 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04796.219 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04828.106    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04828.162 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04828.165     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04828.169 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04828.169 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04828.171 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04828.172 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04828.194     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04828.199     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04828.206     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    04828.207     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04828.309 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04828.326 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04828.333 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04853.204    UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    04853.210 -> Controller::Control Start      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0, (out)  bmRequestType: 0x41, bRequest: 0x00, wValue: 0x001e, wIndex: 0x0002, wLength: 0x0000
    04853.228 <-  Controller::Control End        (0x0564c000) error 0x0
    04855.074    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04855.105 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04855.106     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04855.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04855.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04855.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04855.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04855.119     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    04855.120 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04855.121 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x40 status 0x0
    04855.121     Controller::Complete           (0x0564c000) completion: 0x9255d2, status:  0x0
    04855.122 ->  Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04855.126      Controller::Complete           (0x0564c000) completion: 0x92199b, status:  0x0
    04855.136 <-   Controller::PacketHandler      (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 0 todo 0x0 status 0x0
    04855.139 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04855.166    UHCI::powerStateDidChangeTo    (0x0564c000) from state (4) to state (4)
    04908.073    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04908.105 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04908.106     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04908.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04908.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04908.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04908.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04908.119     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04908.121     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04908.125     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf004800e 0x0eff0000
    04908.125     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04908.134 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04908.141 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04908.145 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04940.077    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04940.133 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04940.135     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04940.139 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04940.139 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04940.141 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04940.142 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04940.164     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04940.168     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04940.174     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    04940.175     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04940.325 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04940.347 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04940.351 <-  UHCI::End HandleInterrupt      (0x0564c000)
    04988.076    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    04988.112 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    04988.113     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    04988.115 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    04988.116 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04988.117 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    04988.117 <-   Controller::Return Isoc Done Q End (0x0564c000)
    04988.126     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    04988.129     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    04988.134     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    04988.134     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    04988.223 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    04988.231 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04988.234 <-  UHCI::End HandleInterrupt      (0x0564c000)
    05020.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    05020.132 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    05020.135     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    05020.139 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    05020.140 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05020.142 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    05020.142 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05020.164     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    05020.168     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    05020.175     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    05020.175     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    05020.282 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    05020.289 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    05020.293 <-  UHCI::End HandleInterrupt      (0x0564c000)
    05068.074    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    05068.106 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    05068.107     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    05068.109 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    05068.109 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05068.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    05068.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05068.120     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    05068.121     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    05068.125     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    05068.125     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    05068.207 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    05068.215 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    05068.219 <-  UHCI::End HandleInterrupt      (0x0564c000)
    05100.090    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    05100.107 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    05100.108     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    05100.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    05100.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05100.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    05100.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05100.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    05100.123     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    05100.127     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    05100.127     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    05100.184 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    05100.191 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    05100.195 <-  UHCI::End HandleInterrupt      (0x0564c000)
    05116.074    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    05116.105 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    05116.106     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    05116.108 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    05116.108 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05116.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    05116.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05116.115 <-  UHCI::End HandleInterrupt      (0x0564c000)
    05148.090    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    05148.106 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    05148.108     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    05148.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    05148.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05148.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    05148.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05148.120     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    05148.123     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    05148.127     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    05148.127     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    05148.205 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    05148.213 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    05148.216 <-  UHCI::End HandleInterrupt      (0x0564c000)
    05180.091    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    05180.108 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    05180.109     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    05180.112 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    05180.112 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05180.113 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    05180.113 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05180.123     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    05180.125     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    05180.130     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    05180.130     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    05180.188 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    05180.196 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    05180.199 <-  UHCI::End HandleInterrupt      (0x0564c000)
    05193.483    UHCI::FilterInterrupt          (0x05649000) active interrupts 0x0001
    05193.501 -> UHCI::Begin HandleInterrupt    (0x05649000)
    05193.501     UHCI::HandleInterrupt          (0x05649000) Processing interrupt USBSTS = 0x0000
    05193.507 <-  UHCI::End HandleInterrupt      (0x05649000)
    05212.110    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    05212.164 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    05212.167     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    05212.170 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    05212.171 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05212.173 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    05212.173 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05212.195     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    05212.199     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    05212.206     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0xf004800e 0x0eff0000
    05212.207     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    05212.223 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    05212.240 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    05212.246 <-  UHCI::End HandleInterrupt      (0x0564c000)
    05222.302    EHCI::Primary Interrupt        (0x055cb000) enabledInterrupts 0x0000001f activeInterrupts 0x00000008, Frame: 8466432, microframe: 1
    05229.259 -> HID::PowerStateWillChangeTo Start (0x057cd200) capabilities 65536 stateNumber 3 whatDevice 0x57cd200
    05229.262 <-  HID::PowerStateWillChangeTo End (0x057cd200) stateNumber 3 PMState 0x0
    05229.311 -> HID::powerStateDidChangeTo start (0x057cd200) capabilities 65536 stateNumber 3 whatDevice 0x57cd200
    05229.311 <-  HID::powerStateDidChangeTo end (0x057cd200)
    05229.331 -> HID::powerChangeDone start     (0x057cd200) fromstate 4
    05229.331 <-  HID::powerChangeDone end       (0x057cd200)
    05229.384 -> HID::powerChangeDone start     (0x057cd200) fromstate 3
    05229.384 <-  HID::powerChangeDone end       (0x057cd200)
    05229.399 -> HID::powerChangeDone start     (0x058bf800) fromstate 3
    05229.399 <-  HID::powerChangeDone end       (0x058bf800)
    05229.449 -> Controller::Control Start      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0, (in)  bmRequestType: 0xa1, bRequest: 0x01, wValue: 0x0300, wIndex: 0x0000, wLength: 0x0008
    05229.475 <-  Controller::Control End        (0x05649000) error 0x0
    05229.489    UHCI::powerStateDidChangeTo    (0x05649000) from state (4) to state (4)
    05229.511 -> HID::powerChangeDone start     (0x058bf800) fromstate 3
    05229.511 <-  HID::powerChangeDone end       (0x058bf800)
    05230.469    UHCI::FilterInterrupt          (0x05649000) active interrupts 0x0001
    05230.502 -> UHCI::Begin HandleInterrupt    (0x05649000)
    05230.503     UHCI::HandleInterrupt          (0x05649000) Processing interrupt USBSTS = 0x0000
    05230.515     Controller::Complete           (0x05649000) completion: 0x9255d2, status:  0x0
    05230.516 ->  Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    05230.517 <-   Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 todo 0x60 status 0x0
    05230.518     Controller::Complete           (0x05649000) completion: 0x9255d2, status:  0x0
    05230.518 ->  Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    05230.519 <-   Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 todo 0x40 status 0x0
    05230.519     Controller::Complete           (0x05649000) completion: 0x9255d2, status:  0x0
    05230.519 ->  Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    05230.523      Controller::Packet Handler     (0x00000000) Bus: 0x5d, Address: 3, Endpoint: 0  (out)  length: 8, data: 0x04050000 0x00000000
    05230.526      Controller::Complete           (0x05649000) completion: 0x92199b, status:  0x0
    05230.535 <-   Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 todo 0x0 status 0x0
    05230.539 <-  UHCI::End HandleInterrupt      (0x05649000)
    05230.563 -> Controller::Control Start      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0, (in)  bmRequestType: 0xa1, bRequest: 0x01, wValue: 0x0300, wIndex: 0x0000, wLength: 0x0008
    05230.585 <-  Controller::Control End        (0x05649000) error 0x0
    05230.598    UHCI::powerStateDidChangeTo    (0x05649000) from state (4) to state (4)
    05230.617    UHCI::powerStateDidChangeTo    (0x05649000) from state (4) to state (4)
    05232.467    UHCI::FilterInterrupt          (0x05649000) active interrupts 0x0001
    05232.497 -> UHCI::Begin HandleInterrupt    (0x05649000)
    05232.498     UHCI::HandleInterrupt          (0x05649000) Processing interrupt USBSTS = 0x0000
    05232.510     Controller::Complete           (0x05649000) completion: 0x9255d2, status:  0x0
    05232.511 ->  Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    05232.512 <-   Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 todo 0x60 status 0x0
    05232.512     Controller::Complete           (0x05649000) completion: 0x9255d2, status:  0x0
    05232.513 ->  Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    05232.513 <-   Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 todo 0x40 status 0x0
    05232.513     Controller::Complete           (0x05649000) completion: 0x9255d2, status:  0x0
    05232.514 ->  Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    05232.517      Controller::Packet Handler     (0x00000000) Bus: 0x5d, Address: 3, Endpoint: 0  (out)  length: 8, data: 0x04050000 0x00000000
    05232.520      Controller::Complete           (0x05649000) completion: 0x92199b, status:  0x0
    05232.530 <-   Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 todo 0x0 status 0x0
    05232.534 <-  UHCI::End HandleInterrupt      (0x05649000)
    05232.558 -> Controller::Control Start      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0, (out)  bmRequestType: 0x21, bRequest: 0x09, wValue: 0x0300, wIndex: 0x0000, wLength: 0x0008
    05232.567     Controller::ControlTxction     (0x00000000) Bus: 0x5d, Address: 3, Endpoint: 0  (out) length: 8, data: 0x00050000 0x00000000
    05232.581 <-  Controller::Control End        (0x05649000) error 0x0
    05232.595    UHCI::powerStateDidChangeTo    (0x05649000) from state (4) to state (4)
    05232.614    UHCI::powerStateDidChangeTo    (0x05649000) from state (4) to state (4)
    05234.482    UHCI::FilterInterrupt          (0x05649000) active interrupts 0x0001
    05234.498 -> UHCI::Begin HandleInterrupt    (0x05649000)
    05234.498     UHCI::HandleInterrupt          (0x05649000) Processing interrupt USBSTS = 0x0000
    05234.509     Controller::Complete           (0x05649000) completion: 0x9255d2, status:  0x0
    05234.510 ->  Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    05234.511 <-   Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 todo 0x60 status 0x0
    05234.511     Controller::Complete           (0x05649000) completion: 0x9255d2, status:  0x0
    05234.512 ->  Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    05234.512 <-   Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 todo 0x40 status 0x0
    05234.513     Controller::Complete           (0x05649000) completion: 0x9255d2, status:  0x0
    05234.513 ->  Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    05234.517      Controller::Complete           (0x05649000) completion: 0x92199b, status:  0x0
    05234.526 <-   Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 todo 0x0 status 0x0
    05234.530 <-  UHCI::End HandleInterrupt      (0x05649000)
    05234.552    UHCI::powerStateDidChangeTo    (0x05649000) from state (4) to state (4)
    05235.568    Controller::Complete           (0x05649000) completion: 0x925106, status:  0xe0004050
    05235.569    Controller::Interrupt Complete (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 1, (in)  actual: 0, status: 0xe00002eb
    05235.571    Controller::Complete           (0x05649000) completion: 0x12c3374, status:  0xe00002eb
    05235.584 -> Controller::Control Start      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0, (out)  bmRequestType: 0x02, bRequest: 0x01, wValue: 0x0000, wIndex: 0x0081, wLength: 0x0000
    05235.598 <-  Controller::Control End        (0x05649000) error 0x0
    05235.606    UHCI::powerStateDidChangeTo    (0x05649000) from state (4) to state (4)
    05237.466    UHCI::FilterInterrupt          (0x05649000) active interrupts 0x0001
    05237.495 -> UHCI::Begin HandleInterrupt    (0x05649000)
    05237.496     UHCI::HandleInterrupt          (0x05649000) Processing interrupt USBSTS = 0x0000
    05237.504     Controller::Complete           (0x05649000) completion: 0x9255d2, status:  0x0
    05237.505 ->  Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    05237.505 <-   Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 todo 0x40 status 0x0
    05237.506     Controller::Complete           (0x05649000) completion: 0x9255d2, status:  0x0
    05237.506 ->  Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    05237.509      Controller::Complete           (0x05649000) completion: 0x92199b, status:  0x0
    05237.517 <-   Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 todo 0x0 status 0x0
    05237.521 <-  UHCI::End HandleInterrupt      (0x05649000)
    05237.545    UHCI::powerStateDidChangeTo    (0x05649000) from state (4) to state (4)
    05238.560    Controller::Complete           (0x05649000) completion: 0x925106, status:  0xe0004050
    05238.561    Controller::Interrupt Complete (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 3, (in)  actual: 0, status: 0xe00002eb
    05238.562    Controller::CompleteTS         (0x05649000) completion: 0x9b82be, status:  0xe00002eb
    05238.563    HID::InterruptRead             (0x057cd200) error: 0xe00002eb, _deviceHasBeenDisconnected = 0
    05238.564    HID::InterruptRead             (0x057cd200) error kIOReturnAborted. Expected.  Not rearming interrupt
    05238.564    HID::Interrupt Read Error      (0x057cd200) Abort received. Expected(true) Queuing Another(false)
    05238.575 -> Controller::Control Start      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0, (out)  bmRequestType: 0x02, bRequest: 0x01, wValue: 0x0000, wIndex: 0x0083, wLength: 0x0000
    05238.589 <-  Controller::Control End        (0x05649000) error 0x0
    05238.596    UHCI::powerStateDidChangeTo    (0x05649000) from state (4) to state (4)
    05240.467    UHCI::FilterInterrupt          (0x05649000) active interrupts 0x0001
    05240.498 -> UHCI::Begin HandleInterrupt    (0x05649000)
    05240.499     UHCI::HandleInterrupt          (0x05649000) Processing interrupt USBSTS = 0x0000
    05240.508     Controller::Complete           (0x05649000) completion: 0x9255d2, status:  0x0
    05240.509 ->  Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    05240.510 <-   Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 todo 0x40 status 0x0
    05240.510     Controller::Complete           (0x05649000) completion: 0x9255d2, status:  0x0
    05240.511 ->  Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    05240.514      Controller::Complete           (0x05649000) completion: 0x92199b, status:  0x0
    05240.524 <-   Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 todo 0x0 status 0x0
    05240.528 <-  UHCI::End HandleInterrupt      (0x05649000)
    05240.556    UHCI::powerStateDidChangeTo    (0x05649000) from state (4) to state (4)
    05241.571    Controller::Complete           (0x05649000) completion: 0x925106, status:  0xe0004050
    05241.572    Controller::Interrupt Complete (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 4, (in)  actual: 0, status: 0xe00002eb
    05241.573    Controller::CompleteTS         (0x05649000) completion: 0x9b82be, status:  0xe00002eb
    05241.575    HID::InterruptRead             (0x058bf800) error: 0xe00002eb, _deviceHasBeenDisconnected = 0
    05241.575    HID::InterruptRead             (0x058bf800) error kIOReturnAborted. Expected.  Not rearming interrupt
    05241.575    HID::Interrupt Read Error      (0x058bf800) Abort received. Expected(true) Queuing Another(false)
    05241.591 -> Controller::Control Start      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0, (out)  bmRequestType: 0x02, bRequest: 0x01, wValue: 0x0000, wIndex: 0x0084, wLength: 0x0000
    05241.605 <-  Controller::Control End        (0x05649000) error 0x0
    05241.616    UHCI::powerStateDidChangeTo    (0x05649000) from state (4) to state (4)
    05243.466    UHCI::FilterInterrupt          (0x05649000) active interrupts 0x0001
    05243.495 -> UHCI::Begin HandleInterrupt    (0x05649000)
    05243.495     UHCI::HandleInterrupt          (0x05649000) Processing interrupt USBSTS = 0x0000
    05243.504     Controller::Complete           (0x05649000) completion: 0x9255d2, status:  0x0
    05243.504 ->  Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    05243.505 <-   Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 todo 0x40 status 0x0
    05243.505     Controller::Complete           (0x05649000) completion: 0x9255d2, status:  0x0
    05243.506 ->  Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    05243.509      Controller::Complete           (0x05649000) completion: 0x92199b, status:  0x0
    05243.517 <-   Controller::PacketHandler      (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 0 todo 0x0 status 0x0
    05243.520 <-  UHCI::End HandleInterrupt      (0x05649000)
    05243.531    Device::Suspend Device         (0x05876c00) port 2, suspend
    05243.542    Hub::DoPortActionLock          (0x05712600) _doPortActionLock available without commandSleep
    05243.582    UHCI::powerStateDidChangeTo    (0x05649000) from state (4) to state (4)
    05249.630    OutstandingIO::HubIncrement    (0x05712600) IO: 2
    05249.630    Hub::DoPortActionLock          (0x05712600) setting _doPortActionLock to false and calling commandWakeup
    05249.632    OutstandingIO::HubDecrement    (0x05712600) serial #: 1454, IO: 1, needInterruptRead: no
    05249.639    Device::Suspend Device         (0x05876c00) port 2, sending message 0xe000400d to clients
    05249.640    Device::Suspend Device         (0x05876c00) port 2, returning 0x0
    05278.613    OutstandingIO::HubIncrement    (0x05712600) IO: 2
    05278.619    OutstandingIO::HubDecrement    (0x05712600) serial #: 1455, IO: 1, needInterruptRead: no
    05286.504    OutstandingIO::HubIncrement    (0x05712600) IO: 2
    05286.505    Controller::CheckForRootHubChanges (0x05649000) stopping timer and calling complete
    05286.507    Controller::RootHubStopTimer   (0x05649000)
    05286.512    Controller::Complete           (0x05649000) completion: 0x925106, status:  0x0
    05286.516    Controller::Interrupt Complete (0x05649000) Bus: 0x5d, Address: 1, Endpoint: 1, (in)  actual: 0, status: 0x0
    05286.517    Controller::Complete           (0x05649000) completion: 0x128838c, status:  0x0
    05286.518    Hub::InterruptReadHandler      (0x05712600) status: 0x0, bufferSizeRemaining: 0
    05286.529    OutstandingIO::HubIncrement    (0x05712600) IO: 3
    05286.531    OutstandingIO::HubIncrement    (0x05712600) IO: 4
    05286.534    OutstandingIO::HubDecrement    (0x05712600) serial #: 1456, IO: 3, needInterruptRead: no
    05286.538    OutstandingIO::HubDecrement    (0x05712600) serial #: 1457, IO: 2, needInterruptRead: no
    05286.560    OutstandingIO::HubIncrement    (0x05712600) IO: 3
    05286.560    Enumeration::ProcessStatusChanged (0x05712600) Bitmap 0x4
    05286.561    OutstandingIO::HubIncrement    (0x05712600) IO: 4
    05286.570    OutstandingIO::HubDecrement    (0x05712600) serial #: 1458, IO: 3, needInterruptRead: yes
    05286.571    OutstandingIO::HubDecrement    (0x05712600) serial #: 1459, IO: 2, needInterruptRead: yes
    05286.582    Enumeration::PortStatusChangeHandler (0x0574b200) Port 2:  Status: 0x0103, Change: 0x0004
    05288.575    OutstandingIO::HubDecrement    (0x05712600) serial #: 1460, IO: 1, needInterruptRead: yes
    05292.074    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    05292.090 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    05292.090     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    05292.092 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    05292.093 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05292.094 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    05292.094 <-   Controller::Return Isoc Done Q End (0x0564c000)
    05292.103     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    05292.105     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    05292.108     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    05292.108     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    05292.183 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    05292.190 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    05292.193 <-  UHCI::End HandleInterrupt      (0x0564c000)
    05296.640 -> Controller::Interrupt Start    (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 3, (in)  reqCount: 8
    05296.649 <-  Controller::Interrupt End      (0x05649000) error 0x0, (completion timeout: 0, noData timeout: 0)
    05296.649    HID::RearmInterruptRead        (0x057cd200) returning error 0x0
    05296.673 -> Controller::Interrupt Start    (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 4, (in)  reqCount: 1
    05296.679 <-  Controller::Interrupt End      (0x05649000) error 0x0, (completion timeout: 0, noData timeout: 0)
    05296.679    HID::RearmInterruptRead        (0x058bf800) returning error 0x0
    05296.693    OutstandingIO::HubDecrement    (0x05712600) serial #: 1461, IO: 0, needInterruptRead: yes
    05296.694    OutstandingIO::HubIncrement    (0x05712600) IO: 1
    05296.699 -> Controller::Interrupt Start    (0x05649000) Bus: 0x5d, Address: 1, Endpoint: 1, (in)  reqCount: 1
    05296.700 ->  Controller::RHQInterruptRead Start (0x05649000) buffer 574c180 bufferlength 1
    05296.701      Controller::RootHubStartTimer32 (0x05649000) Polling Rate: 32
    05296.702 <-   Controller::Interrupt End      (0x05649000) error 0x0, (completion timeout: 0, noData timeout: 0)
    05296.810 ->  Controller::Interrupt Start    (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 1, (in)  reqCount: 64
    05296.816 <-   Controller::Interrupt End      (0x05649000) error 0x0, (completion timeout: 0, noData timeout: 0)
    05296.863 ->  HID::PowerStateWillChangeTo Start (0x057cd200) capabilities 32768 stateNumber 4 whatDevice 0x57cd200
    05296.863 <-   HID::PowerStateWillChangeTo End (0x057cd200) stateNumber 4 PMState 0x0
    05296.877 ->  HID::PowerStateWillChangeTo Start (0x058bf800) capabilities 32768 stateNumber 4 whatDevice 0x58bf800
    05296.878 <-   HID::PowerStateWillChangeTo End (0x058bf800) stateNumber 4 PMState 0x0
    05296.912 ->  HID::powerStateDidChangeTo start (0x057cd200) capabilities 32768 stateNumber 4 whatDevice 0x57cd200
    05296.914 <-   HID::powerStateDidChangeTo end (0x057cd200)
    05296.923 ->  HID::powerStateDidChangeTo start (0x058bf800) capabilities 32768 stateNumber 4 whatDevice 0x58bf800
    05296.924 <-   HID::powerStateDidChangeTo end (0x058bf800)
    05296.938 ->  HID::powerChangeDone start     (0x057cd200) fromstate 3
    05296.939 <-   HID::powerChangeDone end       (0x057cd200)
    05296.946 ->  HID::powerChangeDone start     (0x058bf800) fromstate 3
    05296.946 <-   HID::powerChangeDone end       (0x058bf800)
    05305.483     UHCI::FilterInterrupt          (0x05649000) active interrupts 0x0001
    05305.502 ->  UHCI::Begin HandleInterrupt    (0x05649000)
    05305.503      UHCI::HandleInterrupt          (0x05649000) Processing interrupt USBSTS = 0x0000
    05305.517      Controller::Complete           (0x05649000) completion: 0x925106, status:  0x0
    05305.518      Controller::Interrupt Complete (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 1, (in)  actual: 64, status: 0x0
    05305.522      Controller::Interrupt Complete Data (0x00000000) Bus: 0x5d, Address: 3, Endpoint: 1  (in)  length: 64, data: 0x05776b72 0x777e7677
    05305.522      Controller::Complete           (0x05649000) completion: 0x12c3374, status:  0x0
    05305.532 ->   Controller::Interrupt Start    (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 1, (in)  reqCount: 64
    05305.538 <-    Controller::Interrupt End      (0x05649000) error 0x0, (completion timeout: 0, noData timeout: 0)
    05305.540      Controller::Complete           (0x05649000) completion: 0x925106, status:  0x0
    05305.541      Controller::Interrupt Complete (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 3, (in)  actual: 8, status: 0x0
    05305.542      Controller::Interrupt Complete Data (0x00000000) Bus: 0x5d, Address: 3, Endpoint: 3  (in)  length: 8, data: 0x01000000 0x00000000
    05305.542      Controller::CompleteTS         (0x05649000) completion: 0x9b82be, status:  0x0
    05305.544      HID::InterruptRead             (0x057cd200) bytes read: 8 (of 8)
    05305.644 <-   UHCI::End HandleInterrupt      (0x05649000)
    05305.657 ->  Controller::Interrupt Start    (0x05649000) Bus: 0x5d, Address: 3, Endpoint: 3, (in)  reqCount: 8
    05305.663 <-   Controller::Interrupt End      (0x05649000) error 0x0, (completion timeout: 0, noData timeout: 0)
    05305.664     HID::RearmInterruptRead        (0x057cd200) returning error 0x0
    This log is the controller connected, usbtracer running and me pressing the "A" key on the chatpad over and over... as you can see there's a lot of other traffic in the system
    (the controller is bus 0x1a)(look for things like this)
    I suppose i can take extensive logs and then filter them out with scripts or in excel or something.. i try to do that fairly soon....
  8. #318
    Dec 2008
    so i spent 5 more minutes looking at those logs and noticed that the information at least matches previous discoveries in the sense that endpoint 6 on the controller is the chatpad, A is 0x37 etc etc.... look at this bit of log file
    Code:
    0588.114 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00588.114 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00588.115 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00588.115 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00588.125     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00588.128     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00588.132     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    00588.132     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00588.191 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00588.198 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00588.203 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00652.078    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00652.113 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00652.115     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00652.117 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00652.117 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00652.118 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00652.118 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00652.128     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00652.131     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00652.134     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00000000 0x00ff0000
    00652.135     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00652.218 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00652.226 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00652.230 <-  UHCI::End HandleInterrupt      (0x0564c000)
    00680.966 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00680.966 <-  Controller::Return Isoc Done Q End (0x0564c000)
    00680.967 -> Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00680.967 <-  Controller::Return Isoc Done Q End (0x0564c000)
    00700.076    UHCI::FilterInterrupt          (0x0564c000) active interrupts 0x0001
    00700.107 -> UHCI::Begin HandleInterrupt    (0x0564c000)
    00700.108     UHCI::HandleInterrupt          (0x0564c000) Processing interrupt USBSTS = 0x0000
    00700.110 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb200 pTD 0x0
    00700.110 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00700.111 ->  Controller::Return Isoc Done Q Start (0x0564c000) pEP 0x59eb280 pTD 0x0
    00700.111 <-   Controller::Return Isoc Done Q End (0x0564c000)
    00700.121     Controller::Complete           (0x0564c000) completion: 0x925106, status:  0x0
    00700.122     Controller::Interrupt Complete (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  actual: 5, status: 0x0
    00700.126     Controller::Interrupt Complete Data (0x00000000) Bus: 0x1a, Address: 3, Endpoint: 6  (in)  length: 5, data: 0x00003700 0x00ff0000
    00700.126     Controller::Complete           (0x0564c000) completion: 0xfd9db6, status:  0x0
    00700.208 ->  Controller::Interrupt Start    (0x0564c000) Bus: 0x1a, Address: 3, Endpoint: 6, (in)  reqCount: 32
    00700.215 <-   Controller::Interrupt End      (0x0564c000) error 0x0, (completion timeout: 0, noData timeout: 0)
    00700.219 <-  UHCI::End HandleInterrupt      (0x0564c000)
    it roughly seems to contain 1 "a" then 0x0000000 then another "a"
    i need to learn more about usb to figure about the interrupts etc. but.... anyway... hopefully someone is still looking at this thread.
  9. #319
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    The majority of that is generic USB chatter.....
    I have custom hardware arriving tomorrow that should let me cook something up for windows pretty easily.
  10. #320
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Hattiesburg, Mississippi
    I miss my chatpad...
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
  1. PDA Mini Keyboard
    By BriansNSane in forum Input Devices
    Last Post: 02-08-2006, 07:17 PM
  2. FS....Super Mini Electron luminescent Keyboard
    By Letsride in forum Classified Archive
    Last Post: 06-13-2005, 02:18 AM
  3. Industrial mini keyboard -ebay
    By g60 in forum Classified Archive
    Last Post: 04-18-2001, 06:51 PM
  4. Backlit Keyboard
    By Caviar in forum General Hardware Discussion
    Last Post: 04-03-2001, 09:35 PM
  5. backlit keyboard
    By blkdragon6 in forum General Hardware Discussion
    Last Post: 12-03-1999, 11:47 PM
