Page 35 of 40 FirstFirst ... 25262728293031323334353637383940 LastLast
Results 341 to 350 of 400
Thread: xbox360 chatpad, awsome backlit mini keyboard
  1. #341
    Newbie halfroboy's Avatar
    May 2010
    justchat_1, is there software that i can use with my 360 wired controller than could help you? I don't have a seperate usb device but i want to try and help
  2. #342
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by halfroboy View Post
    You would be looking at the same thing I am...
  3. #343
    Dec 2008
    ok sorry about the long time to reply but i was moving and got very busy
    here are some packets I got from pressing the A key on the controller repeatedly
    Code:
    07745.758    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    07745.797 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    07745.800    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    07745.823    Controller::Complete           (0x0463f000) completion: 0x34a55124, status:  0x0
    07745.828    Controller::Interrupt Complete (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  actual: 20, status: 0x0
    07745.835    Controller::Interrupt Complete Data (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 1  (in)  length: 20, data: 0x00140000 0x0000b7fb
    07745.836    Controller::Complete           (0x0463f000) completion: 0x350611d4, status:  0x0
    07745.873 -> Controller::Interrupt Start    (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  reqCount: 32
    07745.892 <- Controller::Interrupt End      (0x0463f000) error 0x0, (completion timeout: 0, noData timeout: 0)
    07745.899 <- UHCI::End HandleInterrupt      (0x0463f000)
    07749.731    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    07749.761 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    07749.763    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    07749.783    Controller::Complete           (0x0463f000) completion: 0x34a55124, status:  0x0
    07749.786    Controller::Interrupt Complete (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  actual: 20, status: 0x0
    07749.791    Controller::Interrupt Complete Data (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 1  (in)  length: 20, data: 0x00140000 0x0000b7fb
    07749.792    Controller::Complete           (0x0463f000) completion: 0x350611d4, status:  0x0
    07749.822 -> Controller::Interrupt Start    (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  reqCount: 32
    07749.839 <- Controller::Interrupt End      (0x0463f000) error 0x0, (completion timeout: 0, noData timeout: 0)
    07749.845 <- UHCI::End HandleInterrupt      (0x0463f000)
    07793.757    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    07793.807 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    07793.809    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    07793.831    Controller::Complete           (0x0463f000) completion: 0x34a55124, status:  0x0
    07793.835    Controller::Interrupt Complete (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  actual: 20, status: 0x0
    07793.843    Controller::Interrupt Complete Data (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 1  (in)  length: 20, data: 0x00140010 0x0000b7fb
    07793.844    Controller::Complete           (0x0463f000) completion: 0x350611d4, status:  0x0
    07793.881 -> Controller::Interrupt Start    (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  reqCount: 32
    07793.899 <- Controller::Interrupt End      (0x0463f000) error 0x0, (completion timeout: 0, noData timeout: 0)
    07793.906 <- UHCI::End HandleInterrupt      (0x0463f000)
    07801.757    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    07801.806 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    07801.807    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    07801.826    Controller::Complete           (0x0463f000) completion: 0x34a55124, status:  0x0
    07801.829    Controller::Interrupt Complete (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  actual: 20, status: 0x0
    07801.835    Controller::Interrupt Complete Data (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 1  (in)  length: 20, data: 0x00140010 0x0000b7fb
    07801.836    Controller::Complete           (0x0463f000) completion: 0x350611d4, status:  0x0
    07801.864 -> Controller::Interrupt Start    (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  reqCount: 32
    07801.881 <- Controller::Interrupt End      (0x0463f000) error 0x0, (completion timeout: 0, noData timeout: 0)
    07801.888 <- UHCI::End HandleInterrupt      (0x0463f000)
    07833.770    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    07833.817 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    07833.819    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    07833.840    Controller::Complete           (0x0463f000) completion: 0x34a55124, status:  0x0
    07833.844    Controller::Interrupt Complete (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  actual: 20, status: 0x0
    07833.852    Controller::Interrupt Complete Data (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 1  (in)  length: 20, data: 0x00140000 0x0000b7fb
    07833.853    Controller::Complete           (0x0463f000) completion: 0x350611d4, status:  0x0
    07833.891 -> Controller::Interrupt Start    (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  reqCount: 32
    07833.909 <- Controller::Interrupt End      (0x0463f000) error 0x0, (completion timeout: 0, noData timeout: 0)
    07833.917 <- UHCI::End HandleInterrupt      (0x0463f000)
    I'm trying to capture the traffic when I connect the controller hopefully I'll be able to do it tonight
    good luck ya'll
    -j
  4. #344
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by jeduars View Post
    Code:
    good luck ya'll
    -j
    Ah Ha....so it is showing up as a separate device. Now if only I could get windows to find it..
  5. #345
    Dec 2008
    ok i think i found something that might be useful to anybody more USB knowledgeable than me,
    THIS IS A LOOOONG file. it's basically the first time i could find bus 1d (the controller in my particular system, on the log files)
    I think that is what happens when you connect the controller, I copied all traffic until I found the first A button looking packet. hopefully it works.
    THIS IS WITH THE CHATPAD ATTACHED, I'll try to do the same without the chatpad attached.
    Code:
    EHCI::Begin PollInterrupts     (0x043ed800) _errorInterrupt 0 _completeInterrupt 0 _portChangeInterrupt 4
    03422.685    EHCI::PollInterrupts           (0x043ed800) Port Change Interrupt
    03422.694    OutstandingIO::HubIncrement    (0x04537000) IO: 2
    03422.708    EHCI::PollInterrupts           (0x043ed800) Frame Rollover Interrupt
    03422.708 <- EHCI::End PollInterrupts       (0x043ed800)
    03422.737    OutstandingIO::HubDecrement    (0x04537000) serial #: 463, IO: 1, needInterruptRead: no
    03444.309    OutstandingIO::HubIncrement    (0x04537000) IO: 2
    03444.310    Controller::CheckForRootHubChanges (0x043ed800) stopping timer and calling complete
    03444.312    Controller::RootHubStopTimer   (0x043ed800)
    03444.319    Controller::Complete           (0x043ed800) completion: 0x34a55124, status:  0x0
    03444.322    Controller::Interrupt Complete (0x043ed800) Bus: 0xfd, Address: 1, Endpoint: 1, (in)  actual: 0, status: 0x0
    03444.323    Controller::Complete           (0x043ed800) completion: 0x34b13844, status:  0x0
    03444.324    Hub::InterruptReadHandler      (0x04537000) status: 0x0, bufferSizeRemaining: 0
    03444.333    OutstandingIO::HubIncrement    (0x04537000) IO: 3
    03444.335    OutstandingIO::HubIncrement    (0x04537000) IO: 4
    03444.337    OutstandingIO::HubDecrement    (0x04537000) serial #: 464, IO: 3, needInterruptRead: no
    03444.342    OutstandingIO::HubDecrement    (0x04537000) serial #: 465, IO: 2, needInterruptRead: no
    03444.455    OutstandingIO::HubIncrement    (0x04537000) IO: 3
    03444.456    Enumeration::ProcessStatusChanged (0x04537000) Bitmap 0x2
    03444.459    OutstandingIO::HubIncrement    (0x04537000) IO: 4
    03444.476    OutstandingIO::HubDecrement    (0x04537000) serial #: 466, IO: 3, needInterruptRead: yes
    03444.479    OutstandingIO::HubDecrement    (0x04537000) serial #: 467, IO: 2, needInterruptRead: yes
    03444.504    Enumeration::PortStatusChangeHandler (0x044f6c00) Port 1:  Status: 0x0501, Change: 0x0001
    03446.483    OutstandingIO::HubDecrement    (0x04537000) serial #: 468, IO: 1, needInterruptRead: yes
    03514.514    EHCI::Primary Interrupt        (0x04511000) enabledInterrupts 0x0000001f activeInterrupts 0x00000008, Frame: 2042880, microframe: 1
    03544.687    Enumeration::DefaultConnectionChangeHandler (0x044f6c00) Port 1 of Hub at 0xfd000000
    03544.699    Enumeration::PortStatusChangeHandler (0x044f6c00) Port 1:  Status: 0x0501, Change: 0x0000
    03544.705    OutstandingIO::HubDecrement    (0x04537000) serial #: 469, IO: 0, needInterruptRead: yes
    03544.709    OutstandingIO::HubIncrement    (0x04537000) IO: 1
    03544.733 -> Controller::Interrupt Start    (0x043ed800) Bus: 0xfd, Address: 1, Endpoint: 1, (in)  reqCount: 1
    03544.737 -> Controller::RHQInterruptRead Start (0x043ed800) buffer 4551b00 bufferlength 1
    03544.738    Controller::RootHubStartTimer32 (0x043ed800) Polling Rate: 32
    03544.743 <- Controller::Interrupt End      (0x043ed800) error 0x0, (completion timeout: 0, noData timeout: 0)
    03544.756 -> Enumeration::AddDevice         (0x044f6c00) Port 1 of Hub at 0xfd000000
    03544.765    Controller::ProtectedDevZeroLock (0x043ed800) _devZeroLock available without commandSleep
    03544.766    Controller::ProtectedDevZeroLock (0x043ed800) setting _devZeroLock to true
    03544.773    Enumeration::AddDevice         (0x044f6c00) resetting Port 1 of Hub at 0xfd000000
    03559.000    Enumeration::EHCI Root Hub     (0x043ed800) Found full speed device, giving it to companion
    03559.020    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0004
    03559.048 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03559.050    UHCI::HandleInterrupt          (0x0463f000) ResumeDetected
    03559.068    EHCI::Primary Interrupt        (0x043ed800) enabledInterrupts 0x0000001f activeInterrupts 0x00000004, Frame: 1993664, microframe: 1
    03559.078    OutstandingIO::HubIncrement    (0x046ac600) IO: 1
    03559.117    UHCI::HandleInterrupt          (0x0463f000) deferring further processing until we are running again
    03559.118 <- UHCI::End HandleInterrupt      (0x0463f000)
    03559.135    OutstandingIO::HubDecrement    (0x046ac600) serial #: 470, IO: 0, needInterruptRead: no
    03559.216    UHCI::powerStateWillChangeTo   (0x0463f000) new state: 4
    03559.349 -> Controller::SetPowerState start (0x0463f000) powerStateOrdinal 4 whatDevice 0x463f000 myPowerState 3
    03559.359    UHCI::WakeControllerFromDoze   (0x0463f000)
    03560.071    Controller::ProtectedDevZeroLock (0x043ed800) setting _devZeroLock to false and calling commandWakeup
    03560.074 <- Enumeration::AddDevice         (0x044f6c00) Port 1 of Hub at 0xfd000000
    03560.092 -> EHCI::Begin PollInterrupts     (0x043ed800) _errorInterrupt 0 _completeInterrupt 0 _portChangeInterrupt 4
    03560.093    EHCI::PollInterrupts           (0x043ed800) Port Change Interrupt
    03560.096    OutstandingIO::HubIncrement    (0x04537000) IO: 2
    03560.123 <- EHCI::End PollInterrupts       (0x043ed800)
    03562.146    OutstandingIO::HubDecrement    (0x04537000) serial #: 471, IO: 1, needInterruptRead: no
    03576.829    OutstandingIO::HubIncrement    (0x04537000) IO: 2
    03576.830    Controller::CheckForRootHubChanges (0x043ed800) stopping timer and calling complete
    03576.831    Controller::RootHubStopTimer   (0x043ed800)
    03576.839    Controller::Complete           (0x043ed800) completion: 0x34a55124, status:  0x0
    03576.842    Controller::Interrupt Complete (0x043ed800) Bus: 0xfd, Address: 1, Endpoint: 1, (in)  actual: 0, status: 0x0
    03576.843    Controller::Complete           (0x043ed800) completion: 0x34b13844, status:  0x0
    03576.844    Hub::InterruptReadHandler      (0x04537000) status: 0x0, bufferSizeRemaining: 0
    03576.852    OutstandingIO::HubIncrement    (0x04537000) IO: 3
    03576.854    OutstandingIO::HubIncrement    (0x04537000) IO: 4
    03576.857    OutstandingIO::HubDecrement    (0x04537000) serial #: 472, IO: 3, needInterruptRead: no
    03576.861    OutstandingIO::HubDecrement    (0x04537000) serial #: 473, IO: 2, needInterruptRead: no
    03576.914    OutstandingIO::HubIncrement    (0x04537000) IO: 3
    03576.914    Enumeration::ProcessStatusChanged (0x04537000) Bitmap 0x2
    03576.917    OutstandingIO::HubIncrement    (0x04537000) IO: 4
    03576.934    OutstandingIO::HubDecrement    (0x04537000) serial #: 474, IO: 3, needInterruptRead: yes
    03576.936    OutstandingIO::HubDecrement    (0x04537000) serial #: 475, IO: 2, needInterruptRead: yes
    03578.943    OutstandingIO::HubDecrement    (0x04537000) serial #: 476, IO: 1, needInterruptRead: yes
    03579.463 <- Controller::SetPowerState End  (0x0463f000) myPowerState 4
    03579.523    UHCI::powerStateDidChangeTo    (0x0463f000) new state: 4
    03579.685    OutstandingIO::HubIncrement    (0x046ac600) IO: 1
    03579.739    OutstandingIO::HubDecrement    (0x046ac600) serial #: 477, IO: 0, needInterruptRead: yes
    03579.741    OutstandingIO::HubIncrement    (0x046ac600) IO: 1
    03579.754 -> Controller::Interrupt Start    (0x0463f000) Bus: 0x1d, Address: 1, Endpoint: 1, (in)  reqCount: 1
    03579.756 -> Controller::RHQInterruptRead Start (0x0463f000) buffer 46d4e80 bufferlength 1
    03579.757    Controller::RootHubStartTimer32 (0x0463f000) Polling Rate: 32
    03579.775    OutstandingIO::HubIncrement    (0x046ac600) IO: 2
    03579.775    Controller::CheckForRootHubChanges (0x0463f000) stopping timer and calling complete
    03579.776    Controller::RootHubStopTimer   (0x0463f000)
    03579.779    Controller::Complete           (0x0463f000) completion: 0x34a55124, status:  0x0
    03579.780    Controller::Interrupt Complete (0x0463f000) Bus: 0x1d, Address: 1, Endpoint: 1, (in)  actual: 0, status: 0x0
    03579.780    Controller::Complete           (0x0463f000) completion: 0x34b13844, status:  0x0
    03579.781    Hub::InterruptReadHandler      (0x046ac600) status: 0x0, bufferSizeRemaining: 0
    03579.785    OutstandingIO::HubIncrement    (0x046ac600) IO: 3
    03579.786    OutstandingIO::HubIncrement    (0x046ac600) IO: 4
    03579.787    OutstandingIO::HubDecrement    (0x046ac600) serial #: 478, IO: 3, needInterruptRead: no
    03579.789    OutstandingIO::HubDecrement    (0x046ac600) serial #: 479, IO: 2, needInterruptRead: no
    03579.790 <- Controller::Interrupt End      (0x0463f000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03579.797    OutstandingIO::HubDecrement    (0x046ac600) serial #: 480, IO: 1, needInterruptRead: no
    03579.800    OutstandingIO::HubIncrement    (0x046ac600) IO: 2
    03579.800    Enumeration::ProcessStatusChanged (0x046ac600) Bitmap 0x2
    03579.801    OutstandingIO::HubIncrement    (0x046ac600) IO: 3
    03579.806    OutstandingIO::HubDecrement    (0x046ac600) serial #: 481, IO: 2, needInterruptRead: yes
    03579.807    OutstandingIO::HubDecrement    (0x046ac600) serial #: 482, IO: 1, needInterruptRead: yes
    03579.819    Enumeration::PortStatusChangeHandler (0x044ef800) Port 1:  Status: 0x0101, Change: 0x0001
    03579.845    UHCI::powerStateDidChangeTo    (0x0463f000) from state (3) to state (4)
    03608.967    OutstandingIO::HubIncrement    (0x04537000) IO: 2
    03608.978    OutstandingIO::HubDecrement    (0x04537000) serial #: 483, IO: 1, needInterruptRead: yes
    03622.402    EHCI::Primary Interrupt        (0x043ed800) enabledInterrupts 0x0000001f activeInterrupts 0x00000008, Frame: 1993728, microframe: 1
    03639.530    UHCI::FilterInterrupt          (0x0452d000) active interrupts 0x0001
    03639.579 -> UHCI::Begin HandleInterrupt    (0x0452d000)
    03639.581    UHCI::HandleInterrupt          (0x0452d000) Processing interrupt USBSTS = 0x0000
    03639.585 -> Controller::Return Isoc Done Q Start (0x0452d000) pEP 0x4941a00 pTD 0x0
    03639.586 <- Controller::Return Isoc Done Q End (0x0452d000)
    03639.588 -> Controller::Return Isoc Done Q Start (0x0452d000) pEP 0x4941a80 pTD 0x0
    03639.588 <- Controller::Return Isoc Done Q End (0x0452d000)
    03639.598 <- UHCI::End HandleInterrupt      (0x0452d000)
    03641.066    OutstandingIO::HubIncrement    (0x04537000) IO: 2
    03641.074    OutstandingIO::HubDecrement    (0x04537000) serial #: 484, IO: 1, needInterruptRead: yes
    03673.150    OutstandingIO::HubIncrement    (0x04537000) IO: 2
    03673.160    OutstandingIO::HubDecrement    (0x04537000) serial #: 485, IO: 1, needInterruptRead: yes
    03677.008    Enumeration::PortStatusChangeHandler (0x044f6c00) Port 1:  Status: 0x0500, Change: 0x0011
    03677.041    Enumeration::PortStatusChangeHandler (0x044f6c00) Port 1:  Status: 0x0500, Change: 0x0000
    03677.061    OutstandingIO::HubDecrement    (0x04537000) serial #: 486, IO: 0, needInterruptRead: yes
    03677.065    OutstandingIO::HubIncrement    (0x04537000) IO: 1
    03677.089 -> Controller::Interrupt Start    (0x043ed800) Bus: 0xfd, Address: 1, Endpoint: 1, (in)  reqCount: 1
    03677.092 -> Controller::RHQInterruptRead Start (0x043ed800) buffer 4551b00 bufferlength 1
    03677.094    Controller::RootHubStartTimer32 (0x043ed800) Polling Rate: 32
    03677.098 <- Controller::Interrupt End      (0x043ed800) error 0x0, (completion timeout: 0, noData timeout: 0)
    03679.904    Enumeration::DefaultConnectionChangeHandler (0x044ef800) Port 1 of Hub at 0x1d000000
    03679.916    Enumeration::PortStatusChangeHandler (0x044ef800) Port 1:  Status: 0x0101, Change: 0x0000
    03679.921    OutstandingIO::HubDecrement    (0x046ac600) serial #: 487, IO: 0, needInterruptRead: yes
    03679.925    OutstandingIO::HubIncrement    (0x046ac600) IO: 1
    03679.943 -> Controller::Interrupt Start    (0x0463f000) Bus: 0x1d, Address: 1, Endpoint: 1, (in)  reqCount: 1
    03679.946 -> Controller::RHQInterruptRead Start (0x0463f000) buffer 46d4e80 bufferlength 1
    03679.947    Controller::RootHubStartTimer32 (0x0463f000) Polling Rate: 32
    03679.950 <- Controller::Interrupt End      (0x0463f000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03679.958 -> Enumeration::AddDevice         (0x044ef800) Port 1 of Hub at 0x1d000000
    03679.970    Controller::ProtectedDevZeroLock (0x0463f000) _devZeroLock available without commandSleep
    03679.971    Controller::ProtectedDevZeroLock (0x0463f000) setting _devZeroLock to true
    03679.979    Enumeration::AddDevice         (0x044ef800) resetting Port 1 of Hub at 0x1d000000
    03682.046    EHCI::Primary Interrupt        (0x04511000) enabledInterrupts 0x0000001f activeInterrupts 0x00000001, Frame: 2043047, microframe: 1
    03682.094 -> EHCI::Begin PollInterrupts     (0x04511000) _errorInterrupt 0 _completeInterrupt 1 _portChangeInterrupt 0
    03682.096    EHCI::PollInterrupts           (0x04511000) Completion Interrupt
    03682.101 -> Controller::Return Isoc Done Q Start (0x04511000) pEP 0x4fe0680 pTD 0x0
    03682.101 <- Controller::Return Isoc Done Q End (0x04511000)
    03682.110    Controller::Complete           (0x04511000) completion: 0x34a5736a, status:  0x0
    03682.115    Controller::Bulk Complete      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 1, (in)  actual: 1458, status: 0x0
    03682.124    Controller::Bulk Complete Data (0x00000000) Bus: 0xfa, Address: 2, Endpoint: 1  (in)  length: 1458, data: 0x0000aa05 0xab000000
    03682.125    Controller::Complete           (0x04511000) completion: 0x3549920a, status:  0x0
    03682.182 -> Controller::Bulk Start         (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 1, (in)  reqCount: 2048
    03682.201 <- Controller::Bulk End           (0x04511000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03682.328    EHCI::PollInterrupts           (0x04511000) Frame Rollover Interrupt
    03682.329 <- EHCI::End PollInterrupts       (0x04511000)
    03690.639    EHCI::Primary Interrupt        (0x04511000) enabledInterrupts 0x0000001f activeInterrupts 0x00000001, Frame: 2043056, microframe: 1
    03690.655 -> EHCI::Begin PollInterrupts     (0x04511000) _errorInterrupt 0 _completeInterrupt 1 _portChangeInterrupt 0
    03690.656    EHCI::PollInterrupts           (0x04511000) Completion Interrupt
    03690.659 -> Controller::Return Isoc Done Q Start (0x04511000) pEP 0x4fe0680 pTD 0x0
    03690.660 <- Controller::Return Isoc Done Q End (0x04511000)
    03690.664    Controller::Complete           (0x04511000) completion: 0x34a55124, status:  0x0
    03690.666    Controller::Interrupt Complete (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 5, (in)  actual: 8, status: 0x0
    03690.672    Controller::Interrupt Complete Data (0x00000000) Bus: 0xfa, Address: 2, Endpoint: 5  (in)  length: 8, data: 0x00000000 0x001edf42
    03690.672    Controller::Complete           (0x04511000) completion: 0x35499bb8, status:  0x0
    03690.683 -> Controller::Interrupt Start    (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 5, (in)  reqCount: 8
    03690.690 <- Controller::Interrupt End      (0x04511000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03690.826 <- EHCI::End PollInterrupts       (0x04511000)
    03750.321    OutstandingIO::HubIncrement    (0x046ac600) IO: 2
    03750.323    Controller::CheckForRootHubChanges (0x0463f000) stopping timer and calling complete
    03750.324    Controller::RootHubStopTimer   (0x0463f000)
    03750.333    Controller::Complete           (0x0463f000) completion: 0x34a55124, status:  0x0
    03750.335    Controller::Interrupt Complete (0x0463f000) Bus: 0x1d, Address: 1, Endpoint: 1, (in)  actual: 0, status: 0x0
    03750.337    Controller::Complete           (0x0463f000) completion: 0x34b13844, status:  0x0
    03750.338    Hub::InterruptReadHandler      (0x046ac600) status: 0x0, bufferSizeRemaining: 0
    03750.348    OutstandingIO::HubIncrement    (0x046ac600) IO: 3
    03750.350    OutstandingIO::HubIncrement    (0x046ac600) IO: 4
    03750.352    OutstandingIO::HubDecrement    (0x046ac600) serial #: 488, IO: 3, needInterruptRead: no
    03750.356    OutstandingIO::HubDecrement    (0x046ac600) serial #: 489, IO: 2, needInterruptRead: no
    03750.370    OutstandingIO::HubDecrement    (0x046ac600) serial #: 490, IO: 1, needInterruptRead: no
    03750.374    OutstandingIO::HubIncrement    (0x046ac600) IO: 2
    03750.375    Enumeration::ProcessStatusChanged (0x046ac600) Bitmap 0x2
    03750.378    OutstandingIO::HubIncrement    (0x046ac600) IO: 3
    03750.384    OutstandingIO::HubDecrement    (0x046ac600) serial #: 491, IO: 2, needInterruptRead: yes
    03750.386    OutstandingIO::HubDecrement    (0x046ac600) serial #: 492, IO: 1, needInterruptRead: yes
    03751.330 <- Enumeration::AddDevice         (0x044ef800) Port 1 of Hub at 0x1d000000
    03782.487    OutstandingIO::HubIncrement    (0x046ac600) IO: 2
    03782.499    OutstandingIO::HubDecrement    (0x046ac600) serial #: 493, IO: 1, needInterruptRead: yes
    03814.567    OutstandingIO::HubIncrement    (0x046ac600) IO: 2
    03814.576    OutstandingIO::HubDecrement    (0x046ac600) serial #: 494, IO: 1, needInterruptRead: yes
    03846.617    OutstandingIO::HubIncrement    (0x046ac600) IO: 2
    03846.625    OutstandingIO::HubDecrement    (0x046ac600) serial #: 495, IO: 1, needInterruptRead: yes
    03850.479    Enumeration::PortStatusChangeHandler (0x044ef800) Port 1:  Status: 0x0103, Change: 0x0010
    03850.492 -> Enumeration::AddDeviceResetChangeHandler (0x044ef800) Port 1 of Hub at 0x1d000000 with error 0x0
    03860.558 -> Controller::DoCreateEP Start   (0x0463f000) hub 1 port 1 transferType 0
    03860.564 <- Controller::DoCreateEP End     (0x0463f000) error 0x0
    03860.646    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03860.652 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 0, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0100, wIndex: 0x0000, wLength: 0x0008
    03860.716 <- Controller::Control End        (0x0463f000) error 0x0
    03862.467    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03862.531 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03862.532    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03862.560    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03862.562 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 0, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03862.564 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 0, Endpoint: 0 todo 0x60 status 0x0
    03862.566    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03862.567 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 0, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03862.568 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 0, Endpoint: 0 todo 0x40 status 0x0
    03862.569    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03862.570 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 0, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03862.579    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 0, Endpoint: 0  (out)  length: 8, data: 0x12010002 0xffffff08
    03862.590    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    03862.596 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 0, Endpoint: 0 todo 0x0 status 0x0
    03862.601 <- UHCI::End HandleInterrupt      (0x0463f000)
    03862.647 -> Controller::MakeDevice Start   (0x0463f000)
    03862.681    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03862.685 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 0, Endpoint: 0, (out)  bmRequestType: 0x00, bRequest: 0x05, wValue: 0x0002, wIndex: 0x0000, wLength: 0x0000
    03862.705 <- Controller::Control End        (0x0463f000) error 0x0
    03862.705    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03864.472    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03864.522 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03864.524    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03864.545    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03864.546 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 0, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03864.548 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 0, Endpoint: 0 todo 0x40 status 0x0
    03864.549    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03864.550 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 0, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03864.558    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    03864.563 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 0, Endpoint: 0 todo 0x0 status 0x0
    03864.568 <- UHCI::End HandleInterrupt      (0x0463f000)
    03864.606 <- Controller::MakeDevice End     (0x0463f000) new device c9c4e00
    03864.651    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03867.692    Controller::ProtectedDevZeroLock (0x0463f000) setting _devZeroLock to false and calling commandWakeup
    03867.715 -> Pipe::InitToEndpoint start     (0x05d77e00) ed 0xc9c4e76 speed 1 address 0x2
    03867.718    Pipe::InitToEndpoint           (0x05d77e00) _controller 0x463f000 _endpoint.transferType 0 _endpoint.maxPacketSize 8
    03867.720 -> Controller::DoCreateEP Start   (0x0463f000) hub 1 port 1 transferType 0
    03867.722 <- Controller::DoCreateEP End     (0x0463f000) error 0x0
    03867.723 <- Pipe::InitToEndpoint end       (0x05d77e00)
    03867.809 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0100, wIndex: 0x0000, wLength: 0x0012
    03867.846 <- Controller::Control End        (0x0463f000) error 0x0
    03867.861    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03869.438    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03869.468 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03869.469    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03869.485    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03869.486 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03869.487 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    03869.488    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03869.489 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03869.489 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    03869.490    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03869.490 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03869.529    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 18, data: 0x12010002 0xffffff08
    03869.534    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    03869.543 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    03869.547 <- UHCI::End HandleInterrupt      (0x0463f000)
    03869.584 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0302, wIndex: 0x0409, wLength: 0x0002
    03869.609 <- Controller::Control End        (0x0463f000) error 0x0
    03869.623    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03869.652    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03871.468    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03871.520 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03871.521    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03871.546    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03871.549 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03871.550 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    03871.551    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03871.552 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03871.553 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    03871.555    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03871.555 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03871.562    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 2, data: 0x16030000 0x00000000
    03871.569    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    03871.576 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    03871.581 <- UHCI::End HandleInterrupt      (0x0463f000)
    03871.657 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0302, wIndex: 0x0409, wLength: 0x0016
    03871.672    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03871.716    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03871.745 <- Controller::Control End        (0x0463f000) error 0x0
    03873.459    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03873.480 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03873.481    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03873.505    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03873.507 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03873.508 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    03873.509    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03873.510 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03873.511 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    03873.512    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03873.512 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03873.518    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 22, data: 0x16034300 0x6f006e00
    03873.525    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    03873.529 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    03873.533 <- UHCI::End HandleInterrupt      (0x0463f000)
    03873.579 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0301, wIndex: 0x0409, wLength: 0x0002
    03873.618 <- Controller::Control End        (0x0463f000) error 0x0
    03873.638    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03873.665    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03875.452    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03875.467 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03875.468    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03875.477    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03875.478 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03875.478 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    03875.479    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03875.479 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03875.480 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    03875.480    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03875.481 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03875.483    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 2, data: 0x2e030000 0x00000000
    03875.486    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    03875.488 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    03875.492 <- UHCI::End HandleInterrupt      (0x0463f000)
    03875.509    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03875.511 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0301, wIndex: 0x0409, wLength: 0x002e
    03875.532    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03875.552 <- Controller::Control End        (0x0463f000) error 0x0
    03877.459    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03877.505 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03877.507    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03877.534    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03877.534 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03877.535 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    03877.536    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03877.536 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03877.537 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    03877.537    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03877.537 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03877.540    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 46, data: 0x2e03a900 0x4d006900
    03877.543    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    03877.545 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    03877.548 <- UHCI::End HandleInterrupt      (0x0463f000)
    03877.588 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0303, wIndex: 0x0409, wLength: 0x0002
    03877.591    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03877.611 <- Controller::Control End        (0x0463f000) error 0x0
    03877.615    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03879.472    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03879.525 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03879.526    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03879.551    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03879.553 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03879.554 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    03879.556    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03879.557 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03879.558 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    03879.559    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03879.560 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03879.566    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 2, data: 0x10030000 0x00000000
    03879.574    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    03879.579 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    03879.585 <- UHCI::End HandleInterrupt      (0x0463f000)
    03879.652 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0303, wIndex: 0x0409, wLength: 0x0010
    03879.667    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03879.711    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03879.726 <- Controller::Control End        (0x0463f000) error 0x0
    03881.477    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03881.521 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03881.522    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03881.551    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03881.553 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03881.554 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    03881.556    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03881.557 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03881.558 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    03881.559    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03881.560 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03881.565    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 16, data: 0x10033000 0x44003000
    03881.572    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    03881.577 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    03881.582 <- UHCI::End HandleInterrupt      (0x0463f000)
    03881.669    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03881.748    Enumeration::AddDeviceResetChangeHandler (0x044ef800) Calling registerService for Port 1 of Hub at 0x1d000000
    03881.814 <- Enumeration::AddDeviceResetChangeHandler (0x044ef800) Port 1 of Hub at 0x1d000000 with error 0x0
    03881.826    OutstandingIO::HubDecrement    (0x046ac600) serial #: 496, IO: 0, needInterruptRead: yes
    03881.830    OutstandingIO::HubIncrement    (0x046ac600) IO: 1
    03881.844 -> Controller::Interrupt Start    (0x0463f000) Bus: 0x1d, Address: 1, Endpoint: 1, (in)  reqCount: 1
    03881.846 -> Controller::RHQInterruptRead Start (0x0463f000) buffer 46d4e80 bufferlength 1
    03881.848    Controller::RootHubStartTimer32 (0x0463f000) Polling Rate: 32
    03881.852 <- Controller::Interrupt End      (0x0463f000) error 0x0, (completion timeout: 0, noData timeout: 0)
    03893.572    Device::ChangeGetConfigLock    (0x0c9c4e00) setting _GETCONFIGLOCK to true
    03893.608    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03893.613 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0200, wIndex: 0x0000, wLength: 0x0004
    03893.638 <- Controller::Control End        (0x0463f000) error 0x0
    03895.459    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03895.477 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03895.478    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03895.489    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03895.491 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03895.492 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    03895.493    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03895.493 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03895.493 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    03895.494    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03895.494 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03895.498    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 4, data: 0x09029900 0x00000000
    03895.503    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    03895.505 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    03895.509 <- UHCI::End HandleInterrupt      (0x0463f000)
    03895.610 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0200, wIndex: 0x0000, wLength: 0x0099
    03895.696 <- Controller::Control End        (0x0463f000) error 0x0
    03895.707    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03895.727    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03897.437    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03897.453 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03897.454    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03897.477    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03897.478 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03897.478 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    03897.481 <- UHCI::End HandleInterrupt      (0x0463f000)
    03898.468    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03898.518 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03898.519    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03898.624    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03898.626 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03898.628 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    03898.629    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03898.630 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03898.637    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 153, data: 0x09029900 0x040100a0
    03898.645    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    03898.651 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    03898.657 <- UHCI::End HandleInterrupt      (0x0463f000)
    03898.704    Device::ChangeGetConfigLock    (0x0c9c4e00) setting _GETCONFIGLOCK to false and calling commandWakeup
    03898.706    Device::GetFullConfig Desc     (0x0c9c4e00) (index 0) - returning configDescriptor 0xc454a00
    03898.734    Device::GetFullConfig Desc     (0x0c9c4e00) (index 0) - found cached configDescriptor 0xc454a00
    03898.735    Device::FindConfig             (0x0c9c4e00) config 1, returning 0xc454a00
    03898.749    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03898.782 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (out)  bmRequestType: 0x00, bRequest: 0x09, wValue: 0x0001, wIndex: 0x0000, wLength: 0x0000
    03898.786    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03898.822 <- Controller::Control End        (0x0463f000) error 0x0
    03899.465    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03899.513 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03899.514    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03899.535    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03899.536 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03899.537 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    03899.542 <- UHCI::End HandleInterrupt      (0x0463f000)
    03900.460    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03900.500 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03900.501    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03900.518    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03900.520 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03900.529    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    03900.534 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    03900.540 <- UHCI::End HandleInterrupt      (0x0463f000)
    03900.582    Device::GetFullConfig Desc     (0x0c9c4e00) (index 0) - found cached configDescriptor 0xc454a00
    03900.584    Device::FindConfig             (0x0c9c4e00) config 1, returning 0xc454a00
    03900.622    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03900.681    Device::GetFullConfig Desc     (0x0c9c4e00) (index 0) - found cached configDescriptor 0xc454a00
    03900.683    Device::FindConfig             (0x0c9c4e00) config 1, returning 0xc454a00
    03900.748    Device::GetFullConfig Desc     (0x0c9c4e00) (index 0) - found cached configDescriptor 0xc454a00
    03900.750    Device::FindConfig             (0x0c9c4e00) config 1, returning 0xc454a00
    03900.806    Device::GetFullConfig Desc     (0x0c9c4e00) (index 0) - found cached configDescriptor 0xc454a00
    03900.807    Device::FindConfig             (0x0c9c4e00) config 1, returning 0xc454a00
    03900.840 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0304, wIndex: 0x0409, wLength: 0x0002
    03900.849    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03900.863 <- Controller::Control End        (0x0463f000) error 0x0
    03902.440    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03902.496 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03902.497    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03902.522    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03902.523 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03902.523 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    03902.524    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03902.524 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03902.525 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    03902.525    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03902.525 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03902.529    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 2, data: 0xb2030000 0x00000000
    03902.532    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    03902.534 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    03902.537 <- UHCI::End HandleInterrupt      (0x0463f000)
    03902.572 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0304, wIndex: 0x0409, wLength: 0x00b2
    03902.578    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03902.599    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03902.669 <- Controller::Control End        (0x0463f000) error 0x0
    03904.472    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03904.520 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03904.521    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03904.623    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03904.625 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03904.626 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    03904.630 <- UHCI::End HandleInterrupt      (0x0463f000)
    03905.465    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    03905.506 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    03905.507    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    03905.626    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03905.627 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03905.628 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    03905.630    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    03905.631 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    03905.637    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 178, data: 0xb2035800 0x62006f00
    03905.644    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    03905.649 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    03905.654 <- UHCI::End HandleInterrupt      (0x0463f000)
    03905.733    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    03908.961 -> Controller::Return Isoc Done Q Start (0x0452d000) pEP 0x4941a00 pTD 0x0
    03908.962 <- Controller::Return Isoc Done Q End (0x0452d000)
    03908.963 -> Controller::Return Isoc Done Q Start (0x0452d000) pEP 0x4941a80 pTD 0x0
    03908.963 <- Controller::Return Isoc Done Q End (0x0452d000)
    04041.887    EHCI::Primary Interrupt        (0x04511000) enabledInterrupts 0x0000001f activeInterrupts 0x00000001, Frame: 2043407, microframe: 1
    04041.910 -> EHCI::Begin PollInterrupts     (0x04511000) _errorInterrupt 0 _completeInterrupt 1 _portChangeInterrupt 0
    04041.911    EHCI::PollInterrupts           (0x04511000) Completion Interrupt
    04041.914 -> Controller::Return Isoc Done Q Start (0x04511000) pEP 0x4fe0680 pTD 0x0
    04041.914 <- Controller::Return Isoc Done Q End (0x04511000)
    04041.918    Controller::Complete           (0x04511000) completion: 0x34a5736a, status:  0x0
    04041.920    Controller::Bulk Complete      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 1, (in)  actual: 1458, status: 0x0
    04041.923    Controller::Bulk Complete Data (0x00000000) Bus: 0xfa, Address: 2, Endpoint: 1  (in)  length: 1458, data: 0x0000aa05 0xab000000
    04041.923    Controller::Complete           (0x04511000) completion: 0x3549920a, status:  0x0
    04041.940 -> Controller::Bulk Start         (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 1, (in)  reqCount: 2048
    04041.948 <- Controller::Bulk End           (0x04511000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04042.050 <- EHCI::End PollInterrupts       (0x04511000)
    04050.634    EHCI::Primary Interrupt        (0x04511000) enabledInterrupts 0x0000001f activeInterrupts 0x00000001, Frame: 2043416, microframe: 1
    04050.656 -> EHCI::Begin PollInterrupts     (0x04511000) _errorInterrupt 0 _completeInterrupt 1 _portChangeInterrupt 0
    04050.657    EHCI::PollInterrupts           (0x04511000) Completion Interrupt
    04050.658 -> Controller::Return Isoc Done Q Start (0x04511000) pEP 0x4fe0680 pTD 0x0
    04050.659 <- Controller::Return Isoc Done Q End (0x04511000)
    04050.662    Controller::Complete           (0x04511000) completion: 0x34a55124, status:  0x0
    04050.663    Controller::Interrupt Complete (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 5, (in)  actual: 8, status: 0x0
    04050.665    Controller::Interrupt Complete Data (0x00000000) Bus: 0xfa, Address: 2, Endpoint: 5  (in)  length: 8, data: 0x00000000 0x001ee042
    04050.666    Controller::Complete           (0x04511000) completion: 0x35499bb8, status:  0x0
    04050.673 -> Controller::Interrupt Start    (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 5, (in)  reqCount: 8
    04050.677 <- Controller::Interrupt End      (0x04511000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04050.756 <- EHCI::End PollInterrupts       (0x04511000)
    04129.011    UHCI::FilterInterrupt          (0x0452b000) active interrupts 0x0001
    04129.038 -> UHCI::Begin HandleInterrupt    (0x0452b000)
    04129.038    UHCI::HandleInterrupt          (0x0452b000) Processing interrupt USBSTS = 0x0000
    04129.044 <- UHCI::End HandleInterrupt      (0x0452b000)
    04211.699    Device::GetFullConfig Desc     (0x0c9c4e00) (index 0) - found cached configDescriptor 0xc454a00
    04211.700    Device::FindConfig             (0x0c9c4e00) config 1, returning 0xc454a00
    04211.705    Device::GetFullConfig Desc     (0x0c9c4e00) (index 0) - found cached configDescriptor 0xc454a00
    04211.706    Device::FindConfig             (0x0c9c4e00) config 1, returning 0xc454a00
    04211.706    Device::GetFullConfig Desc     (0x0c9c4e00) (index 0) - found cached configDescriptor 0xc454a00
    04211.707    Device::FindConfig             (0x0c9c4e00) config 1, returning 0xc454a00
    04211.709 -> Pipe::InitToEndpoint start     (0x050b5c00) ed 0xc454a23 speed 1 address 0x2
    04211.713    Pipe::InitToEndpoint           (0x050b5c00) _controller 0x463f000 _endpoint.transferType 3 _endpoint.maxPacketSize 32
    04211.716 -> Controller::DoCreateEP Start   (0x0463f000) hub 1 port 1 transferType 3
    04211.721 <- Controller::DoCreateEP End     (0x0463f000) error 0x0
    04211.721 <- Pipe::InitToEndpoint end       (0x050b5c00)
    04211.723    Device::GetFullConfig Desc     (0x0c9c4e00) (index 0) - found cached configDescriptor 0xc454a00
    04211.724    Device::FindConfig             (0x0c9c4e00) config 1, returning 0xc454a00
    04211.725 -> Pipe::InitToEndpoint start     (0x04ec3b00) ed 0xc454a2a speed 1 address 0x2
    04211.726    Pipe::InitToEndpoint           (0x04ec3b00) _controller 0x463f000 _endpoint.transferType 3 _endpoint.maxPacketSize 32
    04211.727 -> Controller::DoCreateEP Start   (0x0463f000) hub 1 port 1 transferType 3
    04211.729 <- Controller::DoCreateEP End     (0x0463f000) error 0x0
    04211.729 <- Pipe::InitToEndpoint end       (0x04ec3b00)
    04211.730    Device::GetFullConfig Desc     (0x0c9c4e00) (index 0) - found cached configDescriptor 0xc454a00
    04211.730    Device::FindConfig             (0x0c9c4e00) config 1, returning 0xc454a00
    04211.794    Device::GetFullConfig Desc     (0x0c9c4e00) (index 0) - found cached configDescriptor 0xc454a00
    04211.795    Device::FindConfig             (0x0c9c4e00) config 1, returning 0xc454a00
    04211.798    Device::GetFullConfig Desc     (0x0c9c4e00) (index 0) - found cached configDescriptor 0xc454a00
    04211.799    Device::FindConfig             (0x0c9c4e00) config 1, returning 0xc454a00
    04211.799    Device::GetFullConfig Desc     (0x0c9c4e00) (index 0) - found cached configDescriptor 0xc454a00
    04211.800    Device::FindConfig             (0x0c9c4e00) config 1, returning 0xc454a00
    04211.801 -> Pipe::InitToEndpoint start     (0x084fb640) ed 0xc454a83 speed 1 address 0x2
    04211.802    Pipe::InitToEndpoint           (0x084fb640) _controller 0x463f000 _endpoint.transferType 3 _endpoint.maxPacketSize 32
    04211.803 -> Controller::DoCreateEP Start   (0x0463f000) hub 1 port 1 transferType 3
    04211.807 <- Controller::DoCreateEP End     (0x0463f000) error 0x0
    04211.808 <- Pipe::InitToEndpoint end       (0x084fb640)
    04211.809    Device::GetFullConfig Desc     (0x0c9c4e00) (index 0) - found cached configDescriptor 0xc454a00
    04211.809    Device::FindConfig             (0x0c9c4e00) config 1, returning 0xc454a00
    04211.849 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (out)  bmRequestType: 0x40, bRequest: 0xa9, wValue: 0xa30c, wIndex: 0x4423, wLength: 0x0000
    04211.865 <- Controller::Control End        (0x0463f000) error 0x0
    04211.881    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04213.468    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0003
    04213.539 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04213.540    UHCI::HandleInterrupt          (0x0463f000) Host controller error
    04213.542    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04213.566    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04213.568 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04213.570 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    04213.576    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0xe000404f
    04213.577 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0xe000404f bufferSizeRemaining 0
    04213.593    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0xe000404f
    04213.599 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0xe000404f
    04213.605 <- UHCI::End HandleInterrupt      (0x0463f000)
    04213.681 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (out)  bmRequestType: 0x40, bRequest: 0xa9, wValue: 0x2344, wIndex: 0x7f03, wLength: 0x0000
    04213.694    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04213.721 <- Controller::Control End        (0x0463f000) error 0x0
    04213.743    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04214.468    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04214.518 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04214.520    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04214.541    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04214.554 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04214.556 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    04214.561 <- UHCI::End HandleInterrupt      (0x0463f000)
    04215.480    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0003
    04215.530 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04215.530    UHCI::HandleInterrupt          (0x0463f000) Host controller error
    04215.532    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04215.556    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0xe000404f
    04215.559 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0xe000404f bufferSizeRemaining 0
    04215.576    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0xe000404f
    04215.582 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0xe000404f
    04215.587 <- UHCI::End HandleInterrupt      (0x0463f000)
    04215.658 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (out)  bmRequestType: 0x40, bRequest: 0xa9, wValue: 0x5839, wIndex: 0x6832, wLength: 0x0000
    04215.677    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04215.699 <- Controller::Control End        (0x0463f000) error 0x0
    04215.723    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04216.467    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04216.521 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04216.523    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04216.544    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04216.548 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04216.549 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    04216.554 <- UHCI::End HandleInterrupt      (0x0463f000)
    04217.472    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0003
    04217.518 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04217.518    UHCI::HandleInterrupt          (0x0463f000) Host controller error
    04217.520    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04217.541    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0xe000404f
    04217.542 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0xe000404f bufferSizeRemaining 0
    04217.557    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0xe000404f
    04217.561 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0xe000404f
    04217.566 <- UHCI::End HandleInterrupt      (0x0463f000)
    04217.634 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0xc0, bRequest: 0xa1, wValue: 0x0000, wIndex: 0xe416, wLength: 0x0002
    04217.649    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04217.698    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04217.698 <- Controller::Control End        (0x0463f000) error 0x0
    04218.472    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04218.520 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04218.521    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04218.542    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04218.543 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04218.545 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    04218.549 <- UHCI::End HandleInterrupt      (0x0463f000)
    04219.472    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04219.514 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04219.515    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04219.535    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04219.537 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04219.538 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    04219.539    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04219.540 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04219.547    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 2, data: 0x01000000 0x00000000
    04219.555    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    04219.559 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    04219.564 <- UHCI::End HandleInterrupt      (0x0463f000)
    04219.627 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (out)  bmRequestType: 0x40, bRequest: 0xa1, wValue: 0x0000, wIndex: 0xe416, wLength: 0x0002
    04219.644    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04219.648    Controller::ControlTxction     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out) length: 8, data: 0x01020000 0x00000000
    04219.686    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04219.692 <- Controller::Control End        (0x0463f000) error 0x0
    04221.023    EHCI::powerChangeDone          (0x04511000) from state (4) to state (4)
    04221.049 -> Controller::Control Start      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 0, (out)  bmRequestType: 0x42, bRequest: 0x01, wValue: 0x0044, wIndex: 0x0f00, wLength: 0x0004
    04221.069    Controller::ControlTxction     (0x00000000) Bus: 0xfa, Address: 2, Endpoint: 0  (out) length: 8, data: 0x00008000 0x00000000
    04221.100 <- Controller::Control End        (0x04511000) error 0x0
    04221.138    EHCI::Primary Interrupt        (0x04511000) enabledInterrupts 0x0000001f activeInterrupts 0x00000001, Frame: 2043586, microframe: 1
    04221.159 -> EHCI::Begin PollInterrupts     (0x04511000) _errorInterrupt 0 _completeInterrupt 1 _portChangeInterrupt 0
    04221.159    EHCI::PollInterrupts           (0x04511000) Completion Interrupt
    04221.162 -> Controller::Return Isoc Done Q Start (0x04511000) pEP 0x4fe0680 pTD 0x0
    04221.162 <- Controller::Return Isoc Done Q End (0x04511000)
    04221.166    Controller::Complete           (0x04511000) completion: 0x34a555f0, status:  0x0
    04221.166 -> Controller::PacketHandler      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04221.167 <- Controller::PacketHandler      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    04221.168    Controller::Complete           (0x04511000) completion: 0x34a555f0, status:  0x0
    04221.168 -> Controller::PacketHandler      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04221.168 <- Controller::PacketHandler      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    04221.169    Controller::Complete           (0x04511000) completion: 0x34a555f0, status:  0x0
    04221.169 -> Controller::PacketHandler      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04221.173    Controller::Complete           (0x04511000) completion: 0x34a5199b, status:  0x0
    04221.174 <- Controller::PacketHandler      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    04221.252 <- EHCI::End PollInterrupts       (0x04511000)
    04221.277    EHCI::powerChangeDone          (0x04511000) from state (4) to state (4)
    04221.299 -> Controller::Control Start      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 0, (out)  bmRequestType: 0x42, bRequest: 0x01, wValue: 0x0044, wIndex: 0x0f00, wLength: 0x0004
    04221.326    EHCI::powerChangeDone          (0x04511000) from state (4) to state (4)
    04221.357    Controller::ControlTxction     (0x00000000) Bus: 0xfa, Address: 2, Endpoint: 0  (out) length: 8, data: 0x00008000 0x00000000
    04221.385    EHCI::Primary Interrupt        (0x04511000) enabledInterrupts 0x0000001f activeInterrupts 0x00000001, Frame: 2043586, microframe: 1
    04221.417 <- Controller::Control End        (0x04511000) error 0x0
    04221.420 -> EHCI::Begin PollInterrupts     (0x04511000) _errorInterrupt 0 _completeInterrupt 1 _portChangeInterrupt 0
    04221.421    EHCI::PollInterrupts           (0x04511000) Completion Interrupt
    04221.422 -> Controller::Return Isoc Done Q Start (0x04511000) pEP 0x4fe0680 pTD 0x0
    04221.422 <- Controller::Return Isoc Done Q End (0x04511000)
    04221.424    Controller::Complete           (0x04511000) completion: 0x34a555f0, status:  0x0
    04221.424 -> Controller::PacketHandler      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04221.425 <- Controller::PacketHandler      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    04221.425    Controller::Complete           (0x04511000) completion: 0x34a555f0, status:  0x0
    04221.425 -> Controller::PacketHandler      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04221.426 <- Controller::PacketHandler      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    04221.426    Controller::Complete           (0x04511000) completion: 0x34a555f0, status:  0x0
    04221.427 -> Controller::PacketHandler      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04221.430    Controller::Complete           (0x04511000) completion: 0x34a5199b, status:  0x0
    04221.431 <- Controller::PacketHandler      (0x04511000) Bus: 0xfa, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    04221.437    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04221.508    EHCI::Primary Interrupt        (0x04511000) enabledInterrupts 0x0000001f activeInterrupts 0x00000001, Frame: 2043587, microframe: 1
    04221.510 <- EHCI::End PollInterrupts       (0x04511000)
    04221.512 -> EHCI::Begin PollInterrupts     (0x04511000) _errorInterrupt 0 _completeInterrupt 1 _portChangeInterrupt 0
    04221.512    EHCI::PollInterrupts           (0x04511000) Completion Interrupt
    04221.513 -> Controller::Return Isoc Done Q Start (0x04511000) pEP 0x4fe0680 pTD 0x0
    04221.513 <- Controller::Return Isoc Done Q End (0x04511000)
    04221.589 <- EHCI::End PollInterrupts       (0x04511000)
    04221.601 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04221.602    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04221.612    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04221.612 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04221.612 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    04221.613    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04221.613 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04221.614 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    04221.614    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04221.615 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04221.618    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    04221.619 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    04221.623 <- UHCI::End HandleInterrupt      (0x0463f000)
    04221.624    EHCI::powerChangeDone          (0x04511000) from state (4) to state (4)
    04221.692 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0xc0, bRequest: 0xa1, wValue: 0x0000, wIndex: 0xe416, wLength: 0x0002
    04221.704    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04221.713 <- Controller::Control End        (0x0463f000) error 0x0
    04221.825    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04223.438    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04223.465 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04223.466    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04223.476    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04223.477 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04223.477 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    04223.478    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04223.478 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04223.479 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    04223.479    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04223.479 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04223.482    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 2, data: 0x01020000 0x00000000
    04223.485    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    04223.487 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    04223.491 <- UHCI::End HandleInterrupt      (0x0463f000)
    04223.506 -> Controller::Interrupt Start    (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  reqCount: 32
    04223.513 <- Controller::Interrupt End      (0x0463f000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04223.516 -> Controller::Interrupt Start    (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 6, (in)  reqCount: 32
    04223.521 <- Controller::Interrupt End      (0x0463f000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04223.533 -> Controller::Interrupt Start    (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 2, (out)  reqCount: 3
    04223.534    Controller::Interrupt Start Data (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 2  (out)  length: 3, data: 0x01030000 0x00000000
    04223.534    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04223.540 <- Controller::Interrupt End      (0x0463f000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04223.693    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04223.694 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0301, wIndex: 0x0409, wLength: 0x0002
    04223.716 <- Controller::Control End        (0x0463f000) error 0x0
    04225.472    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04225.520 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04225.521    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04225.548    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04225.550 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04225.551 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    04225.553    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04225.554 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04225.555 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    04225.556    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04225.557 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04225.563    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 2, data: 0x2e030000 0x00000000
    04225.570    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    04225.576 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    04225.581 <- UHCI::End HandleInterrupt      (0x0463f000)
    04225.650 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0301, wIndex: 0x0409, wLength: 0x002e
    04225.663    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04225.706    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04225.764 <- Controller::Control End        (0x0463f000) error 0x0
    04227.472    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04227.523 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04227.525    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04227.598    Controller::Complete           (0x0463f000) completion: 0x34a55124, status:  0x0
    04227.600    Controller::Interrupt Complete (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 2, (out)  actual: 3, status: 0x0
    04227.603    Controller::Complete           (0x0463f000) completion: 0x35061204, status:  0x0
    04227.612    Controller::Complete           (0x0463f000) completion: 0x34a55124, status:  0x0
    04227.613    Controller::Interrupt Complete (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  actual: 3, status: 0x0
    04227.618    Controller::Interrupt Complete Data (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 1  (in)  length: 3, data: 0x01030e0c 0xffff0000
    04227.619    Controller::Complete           (0x0463f000) completion: 0x350611d4, status:  0x0
    04227.632 -> Controller::Interrupt Start    (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  reqCount: 32
    04227.649 <- Controller::Interrupt End      (0x0463f000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04227.652    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04227.652 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04227.654 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    04227.657    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04227.658 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04227.659 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    04227.660    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04227.661 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04227.666    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 46, data: 0x2e03a900 0x4d006900
    04227.673    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    04227.678 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    04227.684 <- UHCI::End HandleInterrupt      (0x0463f000)
    04227.768 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0302, wIndex: 0x0409, wLength: 0x0002
    04227.769    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04227.815    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04227.833 <- Controller::Control End        (0x0463f000) error 0x0
    04228.467    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04228.514 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04228.515    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04228.538    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04228.539 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04228.540 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    04228.545 <- UHCI::End HandleInterrupt      (0x0463f000)
    04229.439    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04229.485 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04229.486    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04229.509    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04229.510 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04229.512 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    04229.513    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04229.514 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04229.519    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 2, data: 0x16030000 0x00000000
    04229.526    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    04229.531 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    04229.537 <- UHCI::End HandleInterrupt      (0x0463f000)
    04229.603 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0302, wIndex: 0x0409, wLength: 0x0016
    04229.608    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04229.632 <- Controller::Control End        (0x0463f000) error 0x0
    04229.632    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04231.437    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04231.451 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04231.452    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04231.465    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04231.465 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04231.466 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    04231.467    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04231.467 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04231.468 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    04231.468    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04231.468 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04231.470    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 22, data: 0x16034300 0x6f006e00
    04231.473    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    04231.475 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    04231.478 <- UHCI::End HandleInterrupt      (0x0463f000)
    04231.507 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0303, wIndex: 0x0409, wLength: 0x0002
    04231.523    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04231.529 <- Controller::Control End        (0x0463f000) error 0x0
    04231.545    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04232.437    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04232.451 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04232.452    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04232.465    Controller::Complete           (0x0463f000) completion: 0x34a55124, status:  0x0
    04232.466    Controller::Interrupt Complete (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  actual: 3, status: 0x0
    04232.468    Controller::Interrupt Complete Data (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 1  (in)  length: 3, data: 0x0203000c 0xffff0000
    04232.469    Controller::Complete           (0x0463f000) completion: 0x350611d4, status:  0x0
    04232.474 -> Controller::Interrupt Start    (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  reqCount: 32
    04232.481 <- Controller::Interrupt End      (0x0463f000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04232.481    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04232.482 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04232.482 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    04232.486 <- UHCI::End HandleInterrupt      (0x0463f000)
    04233.436    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04233.451 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04233.451    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04233.460    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04233.460 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04233.461 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    04233.461    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04233.462 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04233.464    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 2, data: 0x10030000 0x00000000
    04233.467    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    04233.468 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    04233.472 <- UHCI::End HandleInterrupt      (0x0463f000)
    04233.490    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04233.491 -> Controller::Control Start      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0, (in)  bmRequestType: 0x80, bRequest: 0x06, wValue: 0x0303, wIndex: 0x0409, wLength: 0x0010
    04233.515    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04233.517 <- Controller::Control End        (0x0463f000) error 0x0
    04235.436    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04235.450 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04235.451    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04235.462    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04235.463 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04235.464 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x60 status 0x0
    04235.464    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04235.465 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04235.465 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x40 status 0x0
    04235.466    Controller::Complete           (0x0463f000) completion: 0x34a555f0, status:  0x0
    04235.466 -> Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 status 0x0 bufferSizeRemaining 0
    04235.468    Controller::Packet Handler     (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 0  (out)  length: 16, data: 0x10033000 0x44003000
    04235.471    Controller::Complete           (0x0463f000) completion: 0x34a5199b, status:  0x0
    04235.473 <- Controller::PacketHandler      (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 0 todo 0x0 status 0x0
    04235.476 <- UHCI::End HandleInterrupt      (0x0463f000)
    04235.528    UHCI::powerStateDidChangeTo    (0x0463f000) from state (4) to state (4)
    04236.436    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04243.781 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04243.782    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04243.791    Controller::Complete           (0x0463f000) completion: 0x34a55124, status:  0x0
    04243.793    Controller::Interrupt Complete (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  actual: 3, status: 0x0
    04243.796    Controller::Interrupt Complete Data (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 1  (in)  length: 3, data: 0x0303030c 0xffff0000
    04243.796    Controller::Complete           (0x0463f000) completion: 0x350611d4, status:  0x0
    04243.804 -> Controller::Interrupt Start    (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  reqCount: 32
    04243.811 <- Controller::Interrupt End      (0x0463f000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04243.814 <- UHCI::End HandleInterrupt      (0x0463f000)
    04248.437    UHCI::FilterInterrupt          (0x0463f000) active interrupts 0x0001
    04248.454 -> UHCI::Begin HandleInterrupt    (0x0463f000)
    04248.454    UHCI::HandleInterrupt          (0x0463f000) Processing interrupt USBSTS = 0x0000
    04248.463    Controller::Complete           (0x0463f000) completion: 0x34a55124, status:  0x0
    04248.464    Controller::Interrupt Complete (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  actual: 3, status: 0x0
    04248.466    Controller::Interrupt Complete Data (0x00000000) Bus: 0x1d, Address: 2, Endpoint: 1  (in)  length: 3, data: 0x0803000c 0xffff0000
    04248.466    Controller::Complete           (0x0463f000) completion: 0x350611d4, status:  0x0
    04248.472 -> Controller::Interrupt Start    (0x0463f000) Bus: 0x1d, Address: 2, Endpoint: 1, (in)  reqCount: 32
    04248.479 <- Controller::Interrupt End      (0x0463f000) error 0x0, (completion timeout: 0, noData timeout: 0)
    04248.483 <- UHCI::End HandleInterrupt      (0x0463f000)
    good luck!
  6. #346
    Dec 2008
    I'm a PC hardware engineer so I'm not used to dealing with software-level drivers and I have absolutely no idea how to code one but just a random thought. maybe you need to add certain description of the device in the driver's INF file...
    the author of the mac driver has a page with some information on the controller
    http://tattiebogle.net/index.php/Pro...roller/UsbInfo
    http://tattiebogle.net/index.php/Pro...x360Controller
    this is what mac os x reports the device as WITHOUT chatpad
    Code:
    Full Speed device @ 2 (0x1D100000): .............................................   Vendor-specific device: "Controller"
        Port Information:   0x001a
               Not Captive
               Attached to Root Hub
               External Device
               Connected
               Enabled
        Device Descriptor
            Descriptor Version Number:   0x0200
            Device Class:   255   (Vendor-specific)
            Device Subclass:   255   (Vendor-specific)
            Device Protocol:   255
            Device MaxPacketSize:   8
            Device VendorID/ProductID:   0x045E/0x028E   (Microsoft Corporation)
            Device Version Number:   0x0110
            Number of Configurations:   1
            Manufacturer String:   1 "\251Microsoft Corporation"
            Product String:   2 "Controller"
            Serial Number String:   3 "0D03587"
        Configuration Descriptor
            Length (and contents):   153
                Raw Descriptor (hex)    0000: 09 02 99 00 04 01 00 A0  FA 09 04 00 00 02 FF 5D
                Raw Descriptor (hex)    0010: 01 00 11 21 00 01 01 25  81 14 00 00 00 00 13 02
                Raw Descriptor (hex)    0020: 08 00 00 07 05 81 03 20  00 04 07 05 02 03 20 00
                Raw Descriptor (hex)    0030: 08 09 04 01 00 04 FF 5D  03 00 1B 21 00 01 01 01
                Raw Descriptor (hex)    0040: 83 40 01 04 20 16 85 00  00 00 00 00 00 16 05 00
                Raw Descriptor (hex)    0050: 00 00 00 00 00 07 05 83  03 20 00 02 07 05 04 03
                Raw Descriptor (hex)    0060: 20 00 04 07 05 85 03 20  00 40 07 05 05 03 20 00
                Raw Descriptor (hex)    0070: 10 09 04 02 00 01 FF 5D  02 00 09 21 00 01 01 22
                Raw Descriptor (hex)    0080: 86 07 00 07 05 86 03 20  00 10 09 04 03 00 00 FF
                Raw Descriptor (hex)    0090: FD 13 04 06 41 00 01 01  03
            Number of Interfaces:   4
            Configuration Value:   1
            Attributes:   0xA0 (bus-powered, remote wakeup)
            MaxPower:   500 ma
            Interface #0 - Vendor-specific
                Alternate Setting   0
                Number of Endpoints   2
                Interface Class:   255   (Vendor-specific)
                Interface Subclass;   93   (Vendor-specific)
                Interface Protocol:   1
                Raw Descriptor (hex)    0000: 11 21 00 01 01 25 81 14  00 00 00 00 13 02 08 00
                Raw Descriptor (hex)    0010: 00
                Endpoint 0x81 - Interrupt Input
                    Address:   0x81  (IN)
                    Attributes:   0x03  (Interrupt no synchronization data endpoint)
                    Max Packet Size:   32
                    Polling Interval:   4 ms
                Endpoint 0x02 - Interrupt Output
                    Address:   0x02  (OUT)
                    Max Packet Size:   32
                    Polling Interval:   8 ms
            Interface #1 - Vendor-specific
                Alternate Setting   0
                Number of Endpoints   4
                Interface Protocol:   3
                Raw Descriptor (hex)    0000: 1B 21 00 01 01 01 83 40  01 04 20 16 85 00 00 00
                Raw Descriptor (hex)    0010: 00 00 00 16 05 00 00 00  00 00 00
                Endpoint 0x83 - Interrupt Input
                    Address:   0x83  (IN)
                    Max Packet Size:   32
                    Polling Interval:   2 ms
                Endpoint 0x04 - Interrupt Output
                    Address:   0x04  (OUT)
                    Max Packet Size:   32
                Endpoint 0x85 - Interrupt Input
                    Address:   0x85  (IN)
                    Max Packet Size:   32
                    Polling Interval:   64 ms
                Endpoint 0x05 - Interrupt Output
                    Address:   0x05  (OUT)
                    Max Packet Size:   32
                    Polling Interval:   16 ms
            Interface #2 - Vendor-specific
                Alternate Setting   0
                Number of Endpoints   1
                Interface Protocol:   2
                Raw Descriptor (hex)   0000: 09 21 00 01 01 22 86 07  00
                Endpoint 0x86 - Interrupt Input
                    Address:   0x86  (IN)
                    Max Packet Size:   32
            Interface #3 - Vendor-specific ..............................................   "Xbox Security Method 3, Version 1.00, \251 2005 Microsoft Corporation. All rights reserved."
                Alternate Setting   0
                Number of Endpoints   0
                Interface Subclass;   253   (Vendor-specific)
                Interface Protocol:   19
            Raw Descriptor (hex)   0000: 06 41 00 01 01 03
    so far it doesn't seem to change WITH the chatpad connected.
  7. #347
    Newbie halfroboy's Avatar
    May 2010
    you guys are way over my head
  8. #348
    May 2010
    bump
  9. #349
    Jul 2010
    In response to the "bump" above.
    I've been chatting with Grumbel on IRC and hopefully we will make progress soon. I'll post again when I have more information.
    --Andy
  10. #350
    Jul 2010
    Xbox Chatpad Challenge
    Stellar, we are waiting your news!! a isuppose you know there is a chatpad challenge..
    CONTEST: Xbox Chatpad Driver Challenge
  1. PDA Mini Keyboard
    By BriansNSane in forum Input Devices
    Last Post: 02-08-2006, 07:17 PM
  2. FS....Super Mini Electron luminescent Keyboard
    By Letsride in forum Classified Archive
    Last Post: 06-13-2005, 02:18 AM
  3. Industrial mini keyboard -ebay
    By g60 in forum Classified Archive
    Last Post: 04-18-2001, 06:51 PM
  4. Backlit Keyboard
    By Caviar in forum General Hardware Discussion
    Last Post: 04-03-2001, 09:35 PM
  5. backlit keyboard
    By blkdragon6 in forum General Hardware Discussion
    Last Post: 12-03-1999, 11:47 PM
