Page 38 of 40 FirstFirst ... 28293031323334353637383940 LastLast
Results 371 to 380 of 400
Thread: xbox360 chatpad, awsome backlit mini keyboard
  1. #371
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by w239 View Post
    I have decided to just post anything I find that may be of interest regarding the Chatpad driver.
    A guy is trying to create a windows 7 driver(link below), pretty recent posts. 1st and last post the are most interesting.
    http://www.autoitscript.com/forum/in...owtopic=116941
    Cheers
    Its not an HID device....so no you certainly can't create a script for it using autoit
  2. #372
    Aug 2009
    Quote Originally Posted by Stateamuse View Post
    I Found Something that Maybe of help, Just Download the object and read the spin with notepad or an editor, it states that you have to keep telling the pad to stay on.
    http://obex.parallax.com/objects/510/
    It also contains scan codes a hardware examples.
    Hope this helps!
    This is actually rather useful, as they've figured out the communication protocol. ie.
    - Send 87,02,8C,1F,CC,00 to initialise and await a 12 byte response
    - Send 87,02,8C,1B,D0,00 as a keep alive every 2 seconds
    - When awake it sends an 8 byte status message every 70mS
    - When a key is pressed it sends an 8 byte message, beginning B4, C5 that contains the keycode
  3. #373
    Nov 2007
    Excellent!! This keep alive must be the missing puzzle piece that stumped the folks who got it to work for 1 keypress.
    I wonder if you need to constantly send keep alive's to teh chatpad or would you just send the keep alive before sending a key so you don't waste the battery when idle?
  4. #374
    Jun 2008
    Quote Originally Posted by CrazyIvan View Post
    A little to early to celebrate. That the pad needs keep alive messages is already known, in the case of an original Xbox360 it will send 1F, 1E, 1F, 1E, ... each second, 1B is used to activate keyboard input and a bunch of other commands can be used to make the LEDs light up. The problem is that the whole controller dies (i.e. will not respond to anything and will need a usb reset to be brought back to live) whenever you try to send those keep alive messages. This might be a Linux specific problem or maybe it needs some specific timing or such, which is why it would be rather useful if somebody would try to write a Windows driver with the given knowledge to see what the pad does in Windows.
  5. #375
    Nov 2007
    Quote Originally Posted by Grumbel View Post
    Gotcha. Have you tried sending the 1B keepalive at least every 2 seconds like the parallax guys say?
  6. #376
    Jun 2008
    If I send 1F, 1E, ... like the real Xbox360 the controller dies, if I send 1F, 1B, 1B, ... the controller stays alive, but doesn't send more then the very first keypress, only toggling the LEDs works after that.
  7. #377
    Aug 2009
    The fact the XB sends 1E / 1F alternately every second may be significant, timing may well be an issue.
    Also, although the wValue* entry is mostly known (1E / 1F etc), what's the wIndex value for? I've seen various analyzer logs where the wIndex value is different - is that significant?
    What are the full 8 byte Setup Packets you're sending? The XB trace uses a bmRequestType of 41 (ie Direction: Host to Device, Type: Vendor, Recipient: Interface) and yet the code on the previous page uses 87 (ie Direction: Device to Host, Type: Standard, Recipient: Device, Interface, Endpoint). They can't both be right as they're going in different directions.
    * USB Setup 8 byte Packet:
    0 - bmRequestType
    1 - bRequest
    2/3 - wValue
    4/5 - wIndex
    6/7 - wLength
  8. #378
    Jun 2008
    Quote Originally Posted by sirbod View Post
    I am sending:
    reqtype: LIBUSB_REQUEST_TYPE_VENDOR | LIBUSB_RECIPIENT_INTERFACE
    request: LIBUSB_REQUEST_GET_STATUS
    value: <here goes the 1e, 1f, 1b, etc.>
    index: 0x02
    data: 0
    length: 0
    I think in raw bytes that should be something like (if I didn't mess up the endianess):
    0x41 0x0 {value} 0x00 0x02 0x00 0x00 0x00
  9. #379
    Sep 2010
    possible?
    I have followed the work some of you have put down in this project.
    Cant honestly say I understand much. Is it a possibility that someone is near a solution?
    Great work u guys, thanks.
  10. #380
    Nov 2010
    hey, i found this OSX driver:
    http://tattiebogle.net/index.php/Pro...ller/OsxDriver
    ChatPad
    I have got the Microsoft ChatPad working with my wired controller. The latest release of the driver includes support, and I'll be updating the USB information section of this website shortly. I've not yet checked the wireless receiver for compatibility.
    source is available, so maybe this helps
  1. PDA Mini Keyboard
    By BriansNSane in forum Input Devices
    Last Post: 02-08-2006, 07:17 PM
  2. FS....Super Mini Electron luminescent Keyboard
    By Letsride in forum Classified Archive
    Last Post: 06-13-2005, 02:18 AM
  3. Industrial mini keyboard -ebay
    By g60 in forum Classified Archive
    Last Post: 04-18-2001, 06:51 PM
  4. Backlit Keyboard
    By Caviar in forum General Hardware Discussion
    Last Post: 04-03-2001, 09:35 PM
  5. backlit keyboard
    By blkdragon6 in forum General Hardware Discussion
    Last Post: 12-03-1999, 11:47 PM
