Results 1 to 10 of 18
Thread: powering the screen
    Jul 2007
    powering the screen
    Ok so the screen came with a power kit that plugs into the cigarette lighter. Is there anyway to directly connect the power to the car so when the car turns on, the screen turns on so I don't have to plug it in through the cigarette lighter?
    anyone have diagram for this?
    Elsewhere
    Cut off the cig lighter plug and connect it to 12v switched line & ground.
    How about the Wiki?
    Jul 2007
    well i still want an open cigarette lighter, I dont want to completely cut it off. Maybe there is a way I can splice into it? Behind the console?
    Maximum Bitrate customaudioman's Avatar
    Oct 2005
    east coast
    Quote Originally Posted by jnthn205 View Post
    after cutting off the end of the power cord, just keep the lighter end, so that later you can heat shrink it back together.
    Oct 2005
    east coast
    just tap into your headunit 12v wire. Use a blue t-tap connector. just look up the color code.thats what I did and I have a xenarc 7''tsv monitor. but to get no buzz or faint lines in the screen and years of good performance, better to use a little power supply. Which im going to get a opus p.o.l 15watt. I think it around $30.00. multiple monitors or 10'' monitors or bigger, you have to have one.
    Elsewhere
    I think you misunderstood.
    Cut off the cigarette lighter plug on the LCD power cord, not the cig lighter in your ride.
    The t-taps (or vampire taps) that someone else mentioned will work just fine. Tap into any switched 12v power line.
    How about the Wiki?
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    Quote Originally Posted by customaudioman View Post
    reading the specs on the opus pol it says the input voltage must be 1.5V higher than the output voltage. when my car's engine is running, the alternator puts out around 14V but when the engine is off, the battery only puts out around 12V. does this mean that if i hook up a screen through this thing, the screen will not power up when the engine is off?
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
    Jul 2007
    Ok, and let me make sure before I go cutting wires. all i do is , cut the cig lighter end on screen with wire cutters. Strip it so wire is showing, attach it to 12v line?
    is that how I use one of those vampire cutter things?
    Or is it simpler?
    Oct 2005
    east coast
    Or is it simpler?
    yes cut off the cig lighter plug to the monitor. and attach it to 12v line.when you find the line, you can tap into it w/t-tap. or strip the 12v line wire back, twist the + wire from the monitor wire around the 12v line in the radio harness.
    Jul 2007
    Ok so I dont have to deal with negative and positive? I can just attach wire to wire?
    Screen lighter cord -----> 12v cig lighter in dash
    WIRE---------------------> WIRE
  1. 2007 Mazda 3 Dash Screen looks OEM
    By Splash-X in forum Show off your project
    Last Post: 05-04-2009, 06:29 PM
  2. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 01:23 PM
  3. 7" Dynamix (LinITX) LCD - white screen problem
    By xraycat in forum LCD/Display
    Last Post: 10-22-2007, 01:43 PM
  4. Constantly removing the screen 7" lilliput advice
    By steveb in forum LCD/Display
    Last Post: 04-17-2007, 11:56 AM
  5. Playing full screen video only to rear screen
    By yossisibi in forum Centrafuse
    Last Post: 10-29-2006, 07:06 AM
