Results 1 to 10 of 10
Thread: mapping ctrl-alt-del and alt-tab to F6,F7,tc.
    Jul 2006
    i've got one of those mini keyboards that is missing buttons like shift,alt, tab, etc. i was wondering is there any software that i can use to map something like f5 or f6 to functions like alt-tab and ctrl-alt-delete?
    Variable Bitrate daclothe's Avatar
    Dec 2004
    i use a program called hot keyboard pro. great little software, but it's pay...i don't know if there are freeware apps that do the same thing tho. probbably, but i have been using it for about 5 years now for various purposes and am kind of used to it.
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Autoit can do it, and it's free.
    Constant Bitrate almera's Avatar
    Aug 2004
    Mar 2004
    Quote Originally Posted by almera View Post
    I was going to post this. It's pretty light weight and easy to use
    Jul 2006
    i read something about not being able to map 3 key combinations with this though. is that true?
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    I believe ctrl+alt+del is impossible to recreate with software because that key combination is picked up by the hardware which triggers an interrupt which tells windows to do whatever. Windows doesn't actually see this combination, just the interrupt sent by the hardware. I've never been able to find a way to recreate this interrupt, but I never looked that hard either. If you just want the Task Manager that comes up when you hit ctrl+alt+del, you can use that autohotkey program referenced above to open "taskmgr.exe". That will give you the Task Manager.
    Jul 2006
    yup, thats what i ended up doing. or leave taskmgr running in the background (and disable always on top) and then use alt-tab to get to it.
    Dec 2004
    free is better!
    Feb 2006
    West Lafayette, IN
    Quote Originally Posted by daclothe View Post
    free is better!
    Cheeseburgers are best!
  1. FIX: CTRL ALT DEL with "MinLogon"
    By frodobaggins in forum WinNT Based
    Last Post: 03-05-2009, 05:34 AM
  2. NTLDR MISSING Press Ctrl Alt Del
    By tiburonputer in forum General Hardware Discussion
    Last Post: 11-28-2005, 12:05 PM
  3. minlogon ctrl alt del problem..
    By syfenx in forum WinNT Based
    Last Post: 01-22-2005, 03:31 PM
