Results 11 to 20 of 23
Thread: Terratec Cinergy Piranha USB DVB-T TV And DAB Radio Tuner
  1. #11
    Nov 2005
    Hi
    Yes I have pushed the button "Scan" (lower left corner) in the Settings --> Scan menu that pops up when the program starts. I push the button, it's scans and then after a while (aprox. 1 min) shows me nothing :-( There are no TV or DAB channels after the scan... :-( It just shows me a blank white screen and then i choose the setting menu again and I have no channels/stations to add.
    I think it's a bad device. I know I have reception, because my old Nova-T works. But I want this because it has both dab and dvb-t.
    I think I will call the support line and ask for help. It's wired, because I know alot about hardware and software as I´m educated IT-engineer, but this little device just don't work...argh
  2. #12
    Nov 2005
    Sorry the scan takes aprox 5 min with these settings:
    Device: Cinergy Piranha - DVB-T Tuner
    Filter: No Filter
    Scan mode: Scan by region
    Region: All
    Scan intensity: Normal
    But I have tryed ALL settings i ALL compinations and it just doesn't work. I have also tryed with a BIG antenna from my house...it doesn't work
  3. #13
    Nov 2005
    Okay I have talk to the terratec support and they sad that the device was defect and should send it back. So that's why I couldn't get it to work ;-)
    Thanks anyway for the help.
    Best regards Kenneth
  4. #14
    Jun 2006
    how did anyone get on with this? is it any good in a car?
  5. #15
    Nov 2005
    Hi
    I'm now waiting to get a device that works ;-)
    So I will proceed this project (http://forums.fluxmedia.net/showthread.php?t=2491) when I get the device.
  6. #16
    Jun 2006
    i bought one in the end, the reception with the included antenna is a bit suspect. reception with an external aerial is fine though.
  7. #17
    Jan 2006
    Quote Originally Posted by nrgizerbunny View Post
    Is this inside a house or in a car or what you're referring too?
    Do think it would be possible to modify a car antenna cable, and change the connector to a type that fits in the piranhas connector for external antenna? If so, it would be possible to have a permanent connection to an external antenna, trough the carradio-antenna.
  8. #18
    Jun 2006
    the reception with an external car antenna is fine. no problems at all. I'd say it was as good as a headunit although the sound doesn't sound as good as FM, sounds a bit harsher but there is no static even on the move.
    I bought a blaupunkt window aerial for the car and its really good, just plugs in using RF connectors (I they are sma but can't remember off the top of my head)
  9. #19
    Newbie xn02558's Avatar
    Apr 2008
    Hessen Germany
    RR Skin integration
    Hi folks, this sounds very promising. Has anyone integrated the Terratec Cinergy Piranha in a RR Skin yet?
    ________________________________________
    Researching to beef up my loved M6 with a CarPC
  10. #20
    Aug 2007
    this: TerraTec Cinergy Piranha (DTT, DAB, T-DMB, DVB-T)
    is radio + tv?
    is compatible in CF 1.47?
    thanks
  1. Has anyone (UK) got DAB radio or mabe even Digital Terrestrial TV in carpc?
    By mutilator in forum General Hardware Discussion
    Last Post: 08-23-2004, 02:11 PM
