+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Terratec Cinergy Piranha USB DVB-T TV And DAB Radio Tuner
    Newbie LeeVD's Avatar
    Nov 2007
    West London
    Hello
    Any one got one of these?
    The few reviews I've read state it aint half bad minus the Ģ70 price tag.
    I'm looking for digital radio and maybe a bit of TV but have read in the forum that these type of devices dont work all that great in a moving enviroment.
    Wondering if the DAB radio would have the same problems?
    Cheers
    Lee...
    "I rise, I travel, I fall / I Am That I Am"
    Jan 2006
    I'm into the same issue. Would like to know if anyone has any experience with this in a vechicle?
    (There is always the diversity model from Terratec where you can combine the the two antennas to a new improved signal, but as far as I know it doesn't support DAB.)
    http://tven.terratec.net/modules.php...rticle&sid=251
    Jan 2006
    bump...
    anyone with experience on this?
    ptk
    ptk is offline
    Singapore
    Hi
    I am running this adaptor. few comments
    1. the DVB-T reception is not fantastic on the move, but better than pinnacle one i used previously. both ran on external magnetic mounted antennae.
    2. the DAB is quite decent while on the move.
    3. neither the DVB/DAB does encrypted channels.
    4. HD DVB-T reception is a serious CPU hog. I can't get consistent output on a mobile 1.66GHz C2D.
    can't test the DMB as we don't have it in singapore, yet.
    CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
    Jan 2006
    Quote Originally Posted by ptk View Post
    Hi
    Thanks!
    Guess you are refering to the Piranha-model since you are mentioning DAB? Are you refering to on the move in a car? Did you mount the external magnetic antenna inside or outside the car?
    What's most important for me on the move is the DAB-reception, as watching tv on the move while driving a car is not what you should do!
    ptk
    ptk is offline
    Singapore
    Quote Originally Posted by popztarr View Post
    Thanks!
    Hi popztarr
    i am using an magnetic mount ext antenna (which is not included by the way). the DAB reception strength is 90% most of the time while on the move.
    sounds great btw
    the DVB reception is not so good when on the move. on standstill it's excellent.
    will post a picture when i get around to it.
    Jan 2006
    Hi popztarr
    sounds great btw
    Picture would be nice, but as said earlier it's DAB thats most important to me. 90 % sounds very good to me, the question is if the reception here in western norway with high mountains (known as a not to good FM-reception area) will be as good as yours.
    I would like to know more about this magnetic mount ext antenna that you are using. What brand and model is it, price, etc?
    (I'm wonder if anyone knows wheter it's possible to connect the PIRANHA to a standard outdoor car-antenna for FM-radio - the one that comes mounted on the car from the factory, if it would give the right kind of signal, etc?)
    Jan 2006
    bump?
    Nov 2005
    Hi
    I just got one of these and I can't get it to work. I have followed the quick quide, but donīt get the Windows Logo message (step 5). When it finished it just said something about the hardware may not work properly... etc.
    When I look in the Device manager, the drivers are installed correctly. These are the drivers:
    Under "Digital Video"
    - Cinergy Piranha - Digital Video Control
    - Cinergy Piranha - Digital Video Router
    - Cinergy Piranha - DVB-T Receiver
    In the Terratec Home Cinema program under Settings --> Scan I have two devices:
    - Cinergy Piranha - DVB-T Tuner
    - Cinergy Piranha - DAB/T-DMB
    So I think itīs installed correctly, I just don't get any stations under TV and Radio.
    Does anyone have the same problem or maybe help me out? ...please
    Best regards Kenneth
    ptk
    ptk is offline
    Singapore
    Have you run your scan yet? after scanning you have to add the stations you want into favourites.
+ Reply to Thread
  1. Has anyone (UK) got DAB radio or mabe even Digital Terrestrial TV in carpc?
    By mutilator in forum General Hardware Discussion
    Last Post: 08-23-2004, 02:11 PM
