Results 1 to 10 of 18
Thread: Need Options for powered usb hub
    Variable Bitrate nitropwd's Avatar
    Sep 2003
    bloomington,mn / moss point,ms
    I need some options on getting a powered usb and how it should be powered. I currently have a unpowered 1.1 in the front of my car and looking to upgrade.
    Oh, by the way i already have a Carnetix POL to start. Thanks.
    Motherboard: Epox MATX
    Power: M2-ATX
    Storage: 120gb 3.5"
    Optical: Slim Slot cdrw/dvd
    Audio: SB Audigy 2
    GPS: BU-353 & iGuidance 4
    OS: Win FLP (Fundamentals)
    Frontend: Roadrunner (DFX 3 & 4)
    Elsewhere
    Check the power supply for the powered hub. You want one that takes 5vDC.
    Then you can use the Carnetix POL or take 5v from a HDD molex connector to power the USB hub.
    How about the Wiki?
    Sep 2003
    Thanks DP, I appreciate the response but what i need is a couple of makes and model of what people are actually using in their installs so that i have something to go off of.
    Power: M2-ATX
    Storage: 120gb 3.5"
    Audio: SB Audigy 2
    Elsewhere
    You can't go into a computer store and look at power supplies of USB hubs?
    Ummm. OK.
    How about the Wiki?
    Sep 2003
    Good point...my bad. Anyway i picked up a 7 port with a 5V @ 2.2A. i think should be ok. Please let me know if i'm missing something.
    Power: M2-ATX
    Storage: 120gb 3.5"
    Audio: SB Audigy 2
    Variable Bitrate Phatsacks's Avatar
    May 2007
    Springfield, Va
    Looking for the same thing. Yesterday I went by the shop that is doing my install and while we got everything working, windows gave "there was a surge on the usb" blah blah, and basically the DVD drive I think just pulled too much from what the on board usb could provide.
    I found an old powered usb hub, and the power adapter reads:
    Input 100-240 - 0.3A MAX
    Output: +5v 1.2A
    So from what Darque has said, I need that top line to say: 5vDC ?
    I'm obviously not well versed on any of this yet, but I was thinking, since the output of this hub is the +5v 1.2A (0.3A per 4 of the usb's), that I can simply cut the power wire, and connect it to a 4-pin molex connector off the PSU. Then I confused myself, because I thought the 4-pin molex connectors are 12v (which is what is powering my LCD)
    Any direction is appreciated!
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Post Molex drive connector voltages
    Quote Originally Posted by Phatsacks View Post
    Output: +5v 1.2A
    The Molex four pin connectors that are for powering disk drives have both 5V and 12V. The wiring is:
    Red --> +5V
    Yellow --> +12V
    Black(X2) --> Gnd
    You should also power your USB optical drive directly from the molex instead of letting it draw from the USB ports.
    ~Jimmy
    May 2007
    Springfield, Va
    Thanks JimmyFitz, so was I correct then? (minus my lack of fully understanding the cables)
    I can splice a 4pin, use the red+black, and connect it to the power cord of the usb hub I described, and it should work?
    Edit:
    You suggested powering the USB Optical directly from the molex. This may negate the need for me to even need this USB hub (although I'd still like a confirmation, just in case I need it down the road).
    It's a laptop optical drive, usb powered. How can I power it directly from a molex connector, instead of it using the USB hub, without splicing open the usb cable?
    Nov 2005
    Austin, Texas
    Edit:
    Did the optical drive come with a wall wart for use at home? If so, see if that is 5V output. If it is, you can cut the cable from it and wire that to your molex 5V (or get another coaxial connector for the drive.)
    ~Jimmy
    May 2007
    Springfield, Va
    They came with an AC plug attached to another USB/PS2 cable. I threw those worthless things away. I mean, who would ever need alternate power? Hahahaha seriously, what a worthless cable...never to be needed haha oh :supersadface:
    Well, back to the USB hub idea I guess. So, the hub I described will work when splicing into red+black? Looks like it to me, but I'm not as savy as you and others.
  1. Opus 320 and 2 StarTech.com 7 Port USB 2.0 Hub
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 01-07-2008, 04:42 PM
  2. WTB: M2-atx, USB 2.0 hub, USB 2.0 pci card, etc
    By CavityCr33p in forum Classified Archive
    Last Post: 01-30-2006, 06:57 PM
  3. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  4. USB HUB problems????
    By chuckctv in forum Input Devices
    Last Post: 10-08-2004, 12:38 PM
  5. Powering an unpowered USB hub?
    By Squiddy in forum Input Devices
    Last Post: 09-02-2004, 05:37 PM
