What happens when you attempt to calibrate it?
i have a used lilliput LCD monitor with the touch screen function, i can get the touchscreen to work, but i cant calibrate it, any ideas? the screen is removed from the casing because the casing was used in its previous mounting, and broke while i was trying to remove it
