Results 1 to 4 of 4
Thread: Toyota Steering Wheel Control Question
    Feb 2007
    Dear all,
    I have got a Toyota Yaris hatchback that comes with standard CD player, but no steering wheel audio controls.
    Now I got given an OEM steering wheel controlled Bluetooth Handsfree for the new Yaris, but I know that it requires the steering wheel audio buttons to function properly.
    Does anyone know the schematic of the Toyota steering wheel audio control buttons? And where they connects to?
    There are 5 buttons, Mode/vol+/vol-/Up/Down. I am hoping to build a small panel with 5 push buttons and mount it somewhere on the dash (or hidden) and hook it up just like the standard steering wheel controls.
    I have found the wiring connection:
    http://www.castulucci.com/projects/carpc/o...tors/index.html
    There is a 20 pin plug contains 3 wires that comes from the steering wheel control buttons:
    Pin 6: GND (Ground from Steering wheel audio controls) - Neither Input nor Output - Connected
    Pin 7: SW1 (Seek+/-, Vol+/- Inputs from Steering wheel audio controls) - Input - Connected
    Pin 8: SW2 (Mode input from Steering wheel audio controls) - Input - Connected
    Now the question is... can someone with the steering wheel control buttons on their car be so kind to measure the resistance of each button when they are pressed (and when they are not pressed, in case there is a particular resistance in the steady state)?
    And if you know that the 5 control commands is not as simple as "difference in resistance", could you please tell me how to make this work?
    Thanks in advance! And if I am successful in building a 5 button panel to simulate the buttons on the steering wheel controls, I will write up a very detailed DIY instructions!!!
    Feb 2007
    This is the diagram I have in mind (pure guess), the values of the resistors is what I am after.
    Please could someone help me out on this? Many Thanks!
    Newbie vitecd's Avatar
    Oct 2007
    RU/Novosibirsk
    hi
    how are you planed divide key between car music and carPC?
    simply interface can be attached to Joystik port, MIDI
    bad RU$$ian auto moDDer
    Dec 2008
    Quote Originally Posted by 205GTi View Post
    I found this updated shcematic with resistor values: http://s98.photobucket.com/albums/l260/YarisGLS
    So I guees you figured out the correct resistor values?
  1. Replies: 77
    Last Post: 12-23-2008, 08:29 AM
  2. Replies: 3
    Last Post: 05-06-2008, 09:25 AM
  3. Using steering wheel controls to control mini mac?
    By brandondente in forum MacCar
    Last Post: 05-12-2005, 10:50 AM
  4. RF keyfob remotes for adhoc steering wheel controls?
    By archimense in forum Input Devices
    Last Post: 12-23-2004, 05:27 AM
  5. Pioneer steering remote with IRman question
    By magnetik in forum General Hardware Discussion
    Last Post: 12-08-2001, 02:47 AM
