Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Griffin Powermate as only input device?
  1. #21
    Maximum Bitrate Kimota's Avatar
    Nov 2006
    Fort Lauderdale ,Florida
    Quote Originally Posted by parksgm View Post
    I don't think a touchpad is the ideal solution either, because you still must look at the screen and navigate the cursor (a small visual target) to the appropriate button while contending with the natural motion of the car. A touchscreen does not have this problem, since you touch the visual element that you want to select directly.
    Although not ideal nor do I believe there is any ideal solution, just what is best suited to your needs. The touchpad is a simple elegant solution provided it is placed where it can be easily accessed. The cursor size can be changed making it much easier to see, also when using StreetDeck gestures can be performed much easier on the touch pad than on a touch screen even without looking. You can even bind right click to a function, I have right click bound to a function and simply tap the upper right hand corner of touchpad to toggle voice command (also without looking). The vertical right side of the touch pad is a slider that in can StreetDeck be used to scroll up and down or volume control depending on what you set mouse wheel to in StreetDeck. Not to mention you will never have fingerprints or smudge marks on your screen using a touchpad.
    No matter what input device you choose occasionally you will have to take your eyes off the road (even when just using the touch screen) but a good input device will keep this to a minimum
  2. #22
    Aug 2006
    Thanks for all the replies!
    This is definatley a tricky one, currently the best two options are looking like the 3dconnexions SpaceNavigator or a Touchpad..
    My only issue with a touchpad is the pointer always being on screen.. I've played around with RR and found I can use gestures on the touchpad for use without looking at the screen.
    Is there any way to have the pointer only appear when the mouse is moving? and then auto hide once it isn't ?
    If so it looks like this would be the best method for me!
    Cheers
  3. #23
    Nov 2005
    what type of touchpads are you using. taken from an old notebook? how could one connect such a thing to a normal pc?
  4. #24
    Oct 2007
    google search usb touchpads. find your preference by size or functions. I use
    http://www.tigerdirect.com/applicati...598&CatId=1919
    has hotkeys that can preset functions.
  5. #25
    Nov 2005
    thx autockr.
    sounds very promising to use touchpad as input device. touchscreen is to dangerous while driving (to much focussed during navigation) and too far away to reach quietly with fingers (with the slighest bumps).
    still the question remains open if it is possible to use notebook touchbad via usb/serial device and software? anybody knows?
    if not where can i get one shipped europe (switzerland) not paying the same amount as for device?
  6. #26
    Nov 2005
    to above: saw friends new i-drive stick in brand new bmw. wow this is easy to handle.
    can we get something similar to this for pc usage?
    http://www.autointell.de/europaeisch...t-Detailsm.jpg
    omg how do i love german cars!
  7. #27
    Variable Bitrate tigergibb's Avatar
    Nov 2006
    Snellville, GA
    i got a wireless ps3 controllor which im currently trying to map hotkeys with but iguidance is giving me problems
    2003 Nissan Xterra Worklog
    Total amount spent so far: $1196.64
    You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
    2003 Nissan Xterra - Modifications
  1. Griffin Powermate pics - let's see 'm guys!
    By R32 JUhl in forum Input Devices
    Last Post: 06-11-2008, 08:57 AM
  2. Fresh Install on New PC, Rebooting
    By phc in forum StreetDeck
    Last Post: 12-23-2007, 09:33 AM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 08:55 AM
  4. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 08:56 PM
  5. Canīt get DirectX to work
    By Linde in forum Software & Software Development
    Last Post: 10-19-2007, 07:35 AM
