Results 1 to 10 of 14
Thread: Connecting rear view camera
    Feb 2008
    I have this 10,4 screen from the gooddeals website:
    And I bought this camera:
    How do I connect the camera on my carpc?
    Just plug it in directly in my screen?
    Or buy a seperate card for in my pc?
    And can I use this camera in Centrafuse?
    Or must I switch manualy the screen to camera mode?
    Mar 2006
    Colorado, but Canadian!
    if you want to control the camera through the PC, then the camera has to go into a video input port on the PC. This usually means buying a tuner card.
    If you want the camera seperate from the computer, then just run it to the screen and manually switch between the modes. If you had bought a Xenarc, the screen would automatically switch inputs when a signal is present on the camera line for future reference.
    1.9in x 2.9in -- 47mm x 73mm
    Feb 2008
    hmm and I suppose I can't connect a tuner card on my JetwayVIA C7 motherboard in my voom2 case? (little room)
    Feb 2008
    bump
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by GreenBeauty View Post
    They sell USB tuner cards...... Here is a newer version of the one I use. http://www.aver.com/mpd/avertvusbmce.html
    Centrafuse was able to use it easily.... I am sure it will be easy to use the CAM feature also in CF. I took the card out because TV reception was bad when moving. That will not concern you though since your only using it for the CAM. Like toaster said, you should have went with a diffrent screen. I have a K-90 flip out, and it has the cable Toaster is describing. When I turn on my car, the screen turns on right away (did nto hook to the PC because I need to see in reverse right away) The camera's 12V plus is also hooked up to the acc 12v as the K-90 so both turn on. I then put the car in reverse and the monitor automatically switches, then when in drive goes to the PC screen.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Feb 2008
    thank you for your reply.
    When I buy the tv-tuner,
    Is it possible then to connect it to my reverse gear?
    Or is this only possible with specific screens?
    Feb 2008
    Feb 2008
    Which rear-view camera is that?
    I'd think if you had some kind of electronic switch device, you could just wire a relay into it so that when you go into reverse, it switches automatically.
    Feb 2008
    PLCM20
    Do you think I can connect the camera on this usb device?
    En use it in centrafuse
    Constant Bitrate krnpimpsta's Avatar
    Dec 2007
    DC Metro area
    just power your camera from your reverse lights (lights that go on in the back when your car is in reverse - every car has those lights). then when those lights are on, your camera will be on. if your display supports autoswitching of inputs, then you can make it switch inputs whenever the camera turns on.
  1. Rear view camera MBUC1 - disable autodimming feature? (from mp3car.com)
    By krnpimpsta in forum General Hardware Discussion
    Last Post: 02-24-2008, 10:00 PM
  2. Rear View Camera Suggestions
    By JohnWPB in forum Road Runner
    Last Post: 01-31-2007, 08:16 PM
  3. What to use for rear view monitor?
    By stonestatue in forum Newbie
    Last Post: 01-22-2007, 11:59 PM
  4. Have video camera for rear view - which program?
    By nxt125 in forum Software & Software Development
    Last Post: 08-15-2002, 12:25 AM
