Results 1 to 10 of 11
Thread: Mouse as volume control - A cheap new concept
    Newbie shreyasma's Avatar
    Jan 2008
    India
    Hi Friends,
    I have an idea to use an additional mouse as a volume control in the carpc.
    There is a bit of dismantling required.
    I know you all guys can do this more effeciently than I.
    Here's the idea......
    Whats needed is a cheap usb or ps2 mouse with the scroll wheel.
    Dismantle the mouse completely.
    Extend the scroll wheel shaft and we need to fix a new knob for our volume control at the end of the shaft. (Probably a wheel of a toy car or an old music system)
    Refer picture Below
    We can place the circuit board of the mouse behind the dashboard and make a provision for just the shaft to come out as below. We can mount the knob on the end of the shaft.
    Now connect the new volume control to the PC by USB or PS2.
    Download Volumouse software from Here
    Install this software.
    Run Volumouse and make changes exactly as indicated in the below picture.
    You guys can still make further modifications to the program settings as per your need.
    This should not cost you more than 15$
    You are the best when it comes to ideas.
    Please post your feedback, questions and suggestions.
    Constant Bitrate bl3nd3r's Avatar
    Jun 2006
    Pickering, Ontario, Canada
    I am actually doing this same thing as I saw it in this post:
    $10 volume knob fabbed
    One extra thing I am going to try and do is put a button at the end of shaft to maintain the function of pushing down the scroll wheel on a mouse. I think this will be helpful as a mute button but may be difficult to implement.
    Low Bitrate jumbodogs's Avatar
    May 2007
    CT
    Might want to check out this thread. This will cost more then $15 but will give you more options then just volume and probably easier to do.
    Variable Bitrate quantum's Avatar
    Sep 2005
    I did something similar as well, worked it into my non-functioning factory car phone for a "clean" look.
    Volumophonstar
    Jan 2008
    India
    Try
    Quote Originally Posted by bl3nd3r View Post
    You may also try the below setting in Volumouse.
    But i think you can also try finding a driver for the mouse and configure the scroll button to mute/unmute
    Jun 2006
    Quote Originally Posted by shreyasma View Post
    If I could determine a way to put a button on the end of the shaft it would work great. However, extending the shaft creates the problem as you no longer have the same angel to push down the scroll wheel.
    I just got the idea of using the insides of a click pen and will let you know how it turns out.
    Jan 2008
    India
    Sure man, keep updating as you progress
    Constant Bitrate ronjon228's Avatar
    Dec 2005
    Grand Blanc, MI
    Couldn't you just make a slotted hole for the extended shaft to stick out of? Then just make sure the slot in the hole gives you enough play to push down on the shaft enough to engage the button click. Seems like it would work...
    CarPC:
    1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
    Sound System:
    Phoenix Gold RSD 65cs 6.5" Drivers, Infinity Tweets, Pioneer 305DVC 12", PPI Sedona 630IX, Alpine MRP-M500
    Jan 2008
    India
    slotted hole
    Quote Originally Posted by ronjon228 View Post
    Slotted hole is not really efficient in a long run
    Mar 2006
    Colorado, but Canadian!
    Why not just solder 2 leads to the pushbutton below the wheel and voila connect that to your mute button...
    1.9in x 2.9in -- 47mm x 73mm
