On the setups I've seen, the buttons don't switch a particular resistance to ground, but they do switch a particular resistance between two of the wires. Have you tried checking resistance between gray and brown for instance? Also, usually there is still some resistance value even when no buttons are pressed (i.e., they don't generally go open circuit) so that's normal.
Good luck!
LinkBack URL
About LinkBacks
