Results 1 to 3 of 3
Thread: 8 pin din to 8 pin mini din:
    Mar 2008
    Hello, first i would like to say thanks for letting me join here. looks great around here...i searched long enough & finally (i hope) found a place that maybe can help me. i have a Peripheral PXDP (ver:1.4.1 mini din) that i am needing to hook up a PX2X (regular din) for second input to OEM Bose system on a 99 Corvette. talked with Peripheral & they said the newer versions w/mini are connected the same internally as the older PXDPs w/reg din. i asked if they made an adapter/connector to work & of course, NOT! i have bought the connectors to convert this & am here to see if someone can help me figure this out....Thanks in advance...
    Constant Bitrate cMags's Avatar
    Jun 2005
    Marietta, GA
    If you can find out (or already know) what pins go to what, you can pick up the proper DIN and mini-DIN connectors at someplace like mouser.com or digikey.com and make your own adapter. It will require the two connectors, a bit of 8-pin wire (try serial cable or cat-5), and a bit of solder. Good luck!
    CarPC v2.5 up and running - all hardware installed, skin configured, and iG tweaked like crazy. Now for OBD-II, and voice control, and camera plugin, and... :nutz: - it never ends!
    Apr 2002
    orlando
    UMPC built in to dash.
    Winamp, game emulators, Touchpad built in to car, DVD player built in to dash, GPS gamrmin moble pc. IR remote for use of a remote control. ps2 supper mini keyboard for when needed.
  1. Replies: 118
    Last Post: 10-22-2010, 04:05 PM
  2. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 04:05 AM
  3. Panasonic CQ-DF583U Head Unit (CD Changer DIN Pin out?)
    By AustnJPR in forum General Hardware Discussion
    Last Post: 02-01-2004, 12:26 PM
  4. Help me understand PC in a DIN chassis
    By cproaudio in forum General Hardware Discussion
    Last Post: 06-11-2003, 11:51 AM
  5. 13 Pin DIN Connector
    By UncoCow in forum General Hardware Discussion
    Last Post: 11-21-2002, 06:46 PM
