Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Looking for a webcam to use as back-up cam
    Aug 2007
    Baltimore
    I am looking for a decent priced USB camera ( IR and good viewing angle) pretty good quaility and hgopefully no lag as I cant go composite although id love to due to my lilluput not havin auto -siwtch
    thanks
    Aug 2007
    Baltimore
    any1 any input?
    Jun 2006
    Ventura County
    There are a few threads on this but nothing conclusive about which cam is the best. Some people go for the license plate attached spycam type cameras and a few others have tried USB based webcam versions.
    Again, nothing really conclusive on any of them. A lot of people with Xenarc screens like the license plate cams since the Xenarcs automatically switch to the camera when power is applied. Normally they are connected to the reverse lights so when you back out of your driveway the cam turns on automatically.
    Do a few searches on this and you'll see several examples of what people are currently using.
    You do however get what you pay for so the $20/ebay webcams dont give you the picture quality of the $100 dedicated backup camera. The issue with these are ease of installation since they can require a modified housing or hole in your trunk.
    Which ones are you looking at?
    Aug 2007
    Baltimore
    http://cgi.ebay.com/NEW-6-LED-Night-...QQcmdZViewItem
    I know this is extrelemly cheap but maybe this will provide sufficient quality?
    Dec 2007
    Quote Originally Posted by ukraini9mofo View Post
    The Ebay item has finished, but looking at the vendor's store I see a camera boasting 54degree viewing angle. This is NOT good for a backup camera.
    MP3car store has a 110degree camera, I would go for this as a minimum.
    Aug 2007
    Baltimore
    well the angle is 60 so I am guessing it is not enough
    any1 know of any usb night vision cameras with angle of 100+?
    Newbie blckwdw's Avatar
    Apr 2006
    Lansing, Michigan
    have not seen any
    "Toilets scare the crap of of me..."
    May 2008
    look around for internet / computer security cameras. Then generally able to record at very low light levels. Make sure it has good res and frame rate since that is a general weakness in security cams
    Aug 2007
    The problem I have found with my cheapass USB camera is that it is too bright outside for it to work. The image is completely white.
    What can you expect for $12 delivered...
    Feb 2008
    I've been skulking around to find a good reverse camera as well and it really doesn't look like anything usb is going to work very well especially in low-light conditions.
    CCD, component video with built-in IR illuminators are really probably all that will get a good quality video resolution in all weather conditions.
    How are you planning on switching to the reverse camera's view within your front end? Seemlessly switching from the front end's current screen (whatever it may be) to the reverse camera when you actually put your car in reverse (like OEM equipment does) seems like it might be quite a task.
  1. Cam Plugin
    By hari-bhari in forum Centrafuse
    Last Post: 02-04-2007, 05:34 AM
  2. Webcam For A Backup Cam?
    By we87 in forum General MP3Car Discussion
    Last Post: 01-30-2007, 12:23 AM
  3. Any special requirements for backup cam?
    By showson1 in forum StreetDeck
    Last Post: 10-27-2006, 06:32 PM
  4. CAM plug-in suggestion
    By SOS in forum CF Plugins
    Last Post: 09-08-2006, 05:04 PM
