Results 1 to 8 of 8
Thread: My Griffin Powermate install
    Jan 2008
    I had no idea where I was going to put my Griffin Powermate in my Audi TT when I received it. It was larger than any other button/knob in my car and stood out (which I didn't want) due to its huge silver base.
    After a few days of work (not knowing what I was doing) I got it mounted. So, where is it?
    FLAC -zip-'s Avatar
    Ontario/Canada
    The hazzard button? Very nicely done! Good steath install no matter where it is.
    Sound Stage
    Eclipse|MTX|Infinity
    Tainted Love Cris's Avatar
    Romania
    Now that is sweet!
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    LOL! nice.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Variable Bitrate quantum's Avatar
    Sep 2005
    Very cool indeed!
    How about a quick write up on what you did, how it works, what modifications were necessary, etc? Orther pics perhaps?
    I for one would love to emulate ya'
    Jan 2008
    It's the left most, blank, black button. My car didn't come equipped with heated seats so I had those two black buttons available. It took a lot of trial and error as acutally mounting the button in there was NOT easy.
    1) I had to cut the original black spacer a couple of times. First I cut off just the front of it enough so the cuts would not be exposed once mounted like it is.
    2) I used the silicon/plastic piece that came inside of the Griffin Powermate knob
    3) I still had to use the back of the original black spacer because that is part of what locks that whole row of buttons in place. I could only cut it back to a certain point without ruining the integrity of it so I had to then cut off part of the Powermates metal "D" shaft so it was shorter.
    4) I then had to grind away part of the silicon/base that I super glued to the back of the black knob because I needed the shaft to sit further into the knob. Without doing that, the black knob stuck out about 1/8 - 1/4" too far (I never actually measured anything)
    5) I then superglued the back of the PCB to the black base that I mentioned in #3 and then pressed the original aluminum ring from my car over the knob and the PCB to create a sandwich (it was a perfect fit between the ring, powermate PCB, and the black base behind it).
    It's hard to describe if you've never seen the spacer I'm talking about. Not many people with TTs even have since most of them came with heated seats - in which case this wouldn't have worked since those buttons are completely different internally.
    Here are some pictures: http://www.brandonauch.com/TTEUER/Gr...Powermate.html
    They aren't very good but they may help explain what I mean... The only tools I used were a Dremel and ... Super Glue if you would call that one.
    Sep 2005
    Very good explination, love the pics
    You still have the ability to spin the little knob and/or push it? I'm guessing you would spin it with your fingertip on the edge?
    TY!
    Jan 2008
    Yep, it spins easily and it pushes in just like before. It's easy to spin, the dimples on the side of the plastic knob make it easy to just spin it with your finger tip.
  1. AMP and Griffin Powermate
    By thanassius in forum AMP
    Last Post: 04-17-2008, 08:27 AM
  2. FS/FT: Griffin Powermate Silver
    By xdjxklusivex in forum Classified Archive
    Last Post: 04-13-2006, 01:23 AM
  3. WTB: Griffin Powermate
    By acura cl in forum Classified Archive
    Last Post: 08-22-2005, 12:50 AM
  4. The Griffin Powermate
    By tejohnson in forum General Hardware Discussion
    Last Post: 02-21-2003, 05:48 AM
  5. XMMS "General Plugin" for Griffin Powermate Control
    Last Post: 10-27-2002, 02:26 PM
