Results 1 to 2 of 2
Thread: Car2pc problem with Acura TL
    Variable Bitrate VmtSquad's Avatar
    May 2007
    Montréal, Quebec, Canada
    Here what the problem is:
    Once I installed the car2pc, it was flawless.
    I had to do some testings, so I simply turned off the car to simulate a real life situation. When I turned my car back ON, I never had the chance to change to the AUX (cd changer) input anymore, also Im loosing my CD player display ????
    I tried unplugging it to see if my display was in problem, but no. My display was acting perfectly without the Car2Pc plugged in. I choose to give it another try, once I plugged the car2pc device, it was once again working WITH THE DISPLAY. But, once I turned the car OFF, and turned it back on. NOTING!! Cannot get PC sound and no display from the OEM stereo display.
    Heres my setup:
    car2pc item: HON1P (Mentioned on the web site that it works with acura TL 04)
    Car: Acura TL 04
    Head Unit: Canadian HeadUnit version,No Navi, No XM only Auxiliary input(CD CHANGER)
    I would appreciate if you guys could help me on this!!
    Vmt
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
    Sep 2007
    West Springfield, MA
    I've had times when my Axxess CD-changer to AUX input adapter doesn't work right on my 03 Accord. I can't select a CD changer to play my CarPCs sounds. Usually starting the car after shutting it off fully does the trick. I don't know what causes it to happen.
  1. Acura TL owners - LCD help
    By FiSKARZ in forum LCD/Display
    Last Post: 08-03-2010, 05:07 PM
  2. 2005 Acura TL with Navigation
    By hsetty in forum Show off your project
    Last Post: 04-04-2008, 05:29 PM
  3. Weird 04' Acura TL Alpine OEM Nav video feed?
    By EggrollXpress61 in forum Newbie
    Last Post: 01-27-2007, 09:11 PM
  4. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 12:50 PM
  5. Install in a 99 Acura TL
    By codelogic in forum Show off your project
    Last Post: 04-12-2004, 04:39 PM
