Results 1 to 10 of 10
Thread: Moving head unit in glove box will it be ok
    Jun 2008
    I have a pioneer head unit that I want to mount in the glove box. Will the remote be able to work with the unit with the glove box closed.
    Mar 2006
    Colorado, but Canadian!
    If it is an IR remote it needs line of sight. If it is radio based, then it will be distance limited, and metals will interfere.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2008
    Ok. I dont have room on my dash for the head unit because im installing a LCD in the double din area. So im trying to find a place for my head unit.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I have my Pioneer HU in the glove, but I don't use the remote.
    And from memory the remotes are IR so you may have to move the sensor out of the faceplate and put it in the dash somehow.
    However there is a unit that allows the PC to communicate with some pioneer HU's
    http://www.mp3car.com/vbulletin/inpu...ce-car-pc.html
    Variable Bitrate rijk's Avatar
    Feb 2007
    netherlands
    yes they are IR
    You mean this one?, thought they where also meant for the radio to controle the cpc.
    Jun 2005
    chicago, Illinois
    Easy answer. You should pick up a device by Peripheral, model PVIRT, which is an inferred extender.
    Simple explination: It has an IR receiver that you install in plain sight, dash, that you point the remote at. It then takes that signal and replicates that in a isolated location, glovebox, where the IR emitter is also postioned towards the device you wish to control is located.
    PROGRESS:
    Jun 2008
    Ill check out that IR extender.
    Newbie dencker's Avatar
    Jun 2008
    Aalborg, Denmark
    Quote Originally Posted by fikedemon12 View Post
    Well, if you don't have space for the HU you could start doin' some modifications to your center console if you still want your HU in the dash. If you have the courage to do this, you could start a thread in the Fabrication forum, posting an image of your center console, and I'm sure somebody will be glad to help ya' out with your project.
    Looking forward to picking up a '99 Ford Focus and stuffing a CarPC into it! I'm going for the OEM look. If anyone has tips or are willing to help me, please feel free to contact me!
    Jun 2008
    Well
    I decided that Ill buy a under dash radio kit and install it under my dash. That way my remote can control the head unit without any problems.
    Jan 2008
    Norton, MA
    those IR extenders work pretty good. We used them in a home theater install, had a big massive radio remote that could run anything and everything (including the lights) but much of the equipment used IR. Ended up getting something similar to the extender that would take signals from the radio remote and then relay them through IR to a little emitter that stuck onto the component just over the IR receiver.
    As for my install in my truck I opted to go with an under dash mount like you mentioned. I had to make my own install spot though. Currently working on it but its coming out good so far.
    2005 Ford F-350 crew cab 4x4 6.0L SRW LWB
    Planning:
    [|||||||||-] 95%
    Parts Aquisition:
    [||||||----] 60%
    Install:
    [|||||||||-] 90%
    Finally getting Built
  1. Problem with my head unit.
    By Ederfico in forum Car Audio
    Last Post: 02-24-2007, 03:51 PM
  2. Taking internal amp out of head unit.
    By stonestatue in forum Car Audio
    Last Post: 01-19-2007, 01:28 PM
  3. CarPC radio reception: PC tuner or head unit?
    By xraycat in forum Car Audio
    Last Post: 01-18-2007, 06:57 PM
  4. Head Unit: Sony/Panasonic?
    By OdoyleRules in forum Car Audio
    Last Post: 02-25-2006, 06:03 AM
  5. Motorizing my glove box...how?
    By SuperMatty in forum Classified Archive
    Last Post: 08-14-2002, 09:53 PM
