Results 1 to 2 of 2
Thread: bmw help
    Aug 2008
    bmw help
    I have a 2003 bmw xi I want to put my sub in there but my radio don't have the rca inputs?? It's the stock radio can i hook up my amp and sub? if so how?
    I'm not sure if the car cam with a amp stock or not if it did I don't no where it is. Could someone please help me with this thanks...
    May 2007
    yes you can and yes you do have an amp. it will be located on the driver side in the trunk behind the molded carpet. If you have a HK system it will be a little different then the normal alpine amp so find out which you have and look up a wiring diagram for it to see which wires you need to tap to get your signal.
  1. Replies: 13
    Last Post: 03-19-2009, 08:57 AM
  2. Replies: 3
    Last Post: 02-06-2007, 05:40 PM
