Results 1 to 7 of 7
Thread: Griffin AirClick on CF, Media plugin
    Constant Bitrate agniusm's Avatar
    Oct 2006
    Lisburn
    Here is the plugin to make airclick usable in centrafuse, probably in other FE. I have tested with centrafuse 2.0. Download the file below, extract, install, restart airclick software, select multimedia plugin. Only annoing thing is OSD. Does any one know how to disable it?
    http://forums.fluxmedia.net/general-...-airclick.html
    Aug 2008
    i have decompiled the winamp plugin using Lutz Roeders .Net Reflector into c# source. it wasnt my idea, found it in a post on another forum. once you do that anyone with some c knowledge should be able to make a plugin to use windows messaging and control the osd themselves with custom text or no display at all.
    I did this for my custom frontend and it works well. pm me in a couple of days if you dont understand how and i should be able to knock you up a plugin.
    Oct 2006
    Lisburn
    Here is the source of the plugin
    Attached Files Attached Files
    Aug 2008
    sorry it took soo long, just finished work for this block. 14 hour days put me off programming between them. all good though only a 2 minute job to sort out. havent tested it but if there are any problems just let me know.
    Oct 2006
    Lisburn
    hi mate and thank you so much. I have downloaded microsoft visual C# express 2008 and it looks that i just have to change OSD.DisplayGraphic.something into none. Is that correct. then i go F6 to build solution and i get error: The type or namespace name 'Airclick' could not be found (are you missing a using directive or an assembly reference?)
    As i said i am not programer but for future reference how would i compile to something usable?
    Cheers
    Oct 2006
    Lisburn
    Me again. Have tested the rebuild plugin and its dog's balls . Thank you so much. This has to be sticky
    Aug 2008
    thanks, you came very close to compiling it yourself. your right about the OSD lines being all you need to comment out.
    the only thing you missed is in the left panel there is references tab. click it and you will see Airclick with a funny logo on it. all you need to do is right click references. click add reference and then browse to the airclick.exe file.
    once thats done your code will compile. if you have any questions just ask.
  1. CF and EEEPC
    By mickwheelz in forum Centrafuse
    Last Post: 03-12-2008, 09:50 PM
  2. Replies: 4
    Last Post: 04-09-2006, 03:09 AM
  3. XP on CF II Drive
    By NOS TANG in forum Software & Software Development
    Last Post: 11-30-2004, 01:20 PM
  4. Does Any Winamp Plugin Work With Media Car ?
    By ccsnet in forum MediaCar
    Last Post: 11-23-2003, 01:39 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 05:39 AM
