Results 1 to 6 of 6
Thread: Touchscreen USB Keeps disconecting
    Jun 2008
    Half the time when I return from hibernation/restart in order to make the touchscreen work again I have to unplug it and replug it back into the hub. I know GPS's have this problem but I don't know what to do about my screen. Any suggestions or programs to fix this?
    Elsewhere
    Take the touchscreen off the hub and connect it to a USB port on the motherboard. Use a USB extension cable if you need to.
    It's the same reason GPS units have this problem.
    How about the Wiki?
    Jun 2008
    What's funny is my GPS is in the hub and its never had a problem coming out of hibernation but ill try it and let you know
    Aug 2007
    Yep, touchscreen really doesn't like being connected to a hub. Also make sure that inside Device Manager that power management isn't set to turn it off when not in use (inside the touchscreen devices Property page).
    Mar 2004
    Also, make sure you don't plug in the touch screen in the same root usb hub on the motherboard (USB plugs come in pairs off the motherboard, keep the touch screen and external hub in different pairs)
    When I first installed my carputer, I had my hub and touch screen on the same root hub and the touch screen would randomly stop working all the time. I switched USB plugs and it worked completely fine.
    Jun 2008
    Yeah it worked thanks!
  1. FAQ: Everything you need to know about your Xenarc
    By frodobaggins in forum LCD/Display
    Last Post: 10-12-2014, 09:58 PM
  2. Lilliput Touchscreen USB connector
    By halller in forum LCD/Display
    Last Post: 04-09-2008, 06:38 PM
  3. WTB: USB Touchscreen Controller Board
    By freudie1 in forum Classified Archive
    Last Post: 11-18-2006, 01:30 PM
  4. KZL K300 series LCD Touchscreen USB problem.
    By dmaudio4life in forum LCD/Display
    Last Post: 07-27-2006, 06:47 AM
  5. USB Lilliput touchscreen in Win98
    By globbits in forum Input Devices
    Last Post: 03-31-2004, 07:03 AM
