Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: got a problem, please check the pictures i added 7"lilliput
  1. #21
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Try grounding the second battery to the same location as the first. Ground loops and noise are introduced by variations in resistance as electricity flows back to ground. Despite the fact that everything may be grounded to the car chasis, it isn't a perfect circuit. See if that helps at all.
    Want to:
  2. #22
    Variable Bitrate vincenttor's Avatar
    Nov 2008
    Netherlands
    ok thanks for the tip, i will try that and post here te results
  3. #23
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    seems to me that your car battery output voltage is consistently low, or getting weak.
  4. #24
    Nov 2008
    Netherlands
    bugbyte, i have tried hat what u said but that didnt worked
    and it could be indeed a low battery issue because my battery was empty a while ago , i will hook it up to the battery loader
    hope its gone then
    thnx
  5. #25
    Sep 2008
    I'm having the same problem, nothing I do helps!
    When i ground the computer case, It gets a little better, but does not go away!
    I even got highgrade grounding wire, not sure what guage but is as thick as a nickel lol.
    That didn't do much either. However I am running it off an inverter.
    I wanna go for dc-dc powersupply, but after reading countless posts about screen flicker and noise I do not think that it will fix my problem.
    If you ever find a soloution let me know!
  6. #26
    Nov 2008
    Netherlands
    @ dmand, i was filled with hope
    but that was sadly not the problem low battery's
    @ stylz,
    well i got the stipes almost gone
    but when the background is dark/black
    with a movie or something its terrible to watch
    i use the light skin in centrafuse otherwise it sucks
    when i have found the prob i will post the solution here ofcourse
  7. #27
    Jun 2008
    Seattle, WA
    I'm also having the same problem. I'm powering my monitor from the M2-ATX. Let us know if you find a solution.
  8. #28
    FLAC WuNgUn's Avatar
    Sep 2007
    Jeez, I can't believe I got into an argument with someone DEFENDING the M2/M4...
    I know what pieces of **** they are.
    Let Mini-Box know!
  1. Chuck's Skins lots of pics Update 7-16-07
    By Chuck in forum RR Released Skins
    Last Post: 11-10-2011, 07:22 PM
  2. Not your typical flicker problem
    By JPuma in forum LCD/Display
    Last Post: 05-30-2007, 09:28 AM
  3. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 11:50 AM
  4. Added more detail on ebay ad, please check again
    By srafx in forum Classified Archive
    Last Post: 11-26-2003, 10:20 AM
