Results 1 to 6 of 6
Thread: in dash touchscreen - the mouse is not working.
    poz
    poz is offline
    Aug 2008
    Wink in dash touchscreen - the mouse is not working.
    hi!
    i have a carpc in progress,
    7' lilliput in dash touchscreen that worked great for 2 months
    one day the usb "mouse" of the touchscreen stop working
    it looks like windows cant even detect it
    i dont know what seems to be the problem
    any ideas what to check?
    thanks, nir
    Nov 2008
    i have the same problem with with mine as the touch part of it wont work or even recognize in windows....i have checked all cables on the monitor and all ribbon cables inside it
    poz
    poz is offline
    Aug 2008
    and you didnt find any solution?
    my problem started after i accidentally switched the + - connections in my carpc power supplier,
    the 25amp fuse built inside the supllier melt so i fixed the connections and replaced the fuse, the computer started normaly, the screen looks good, normal mouse is working, keyboard is working,GPS is working,
    but like in your case when i connect the screen usb cable into the computer i dont see any msg\warning or any sign, and its not working.
    still looking for an answer
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by poz View Post
    You probably fried the USB Controller. You can get new controllers only for about $50.
    Just need to be more careful with your connections...
    1.9in x 2.9in -- 47mm x 73mm
    poz
    poz is offline
    Aug 2008
    how can i check its really the reason?
    where can i order a new controller for this screen?
    and its something i can do myself?
    thanks
    poz
    poz is offline
    Aug 2008
    i opened the case and i think the controller is part of the board, so how i can replace it? :O
    the model is 701 in dash
  1. lilliput 7" touchscreen part is not working.
    By petb in forum LCD/Display
    Last Post: 01-04-2008, 03:26 AM
  2. I screwed up - touchscreen not working
    By turboman in forum LCD/Display
    Last Post: 09-30-2007, 08:51 PM
  3. Help! Lilliput Touchscreen stopped working!
    By tigergibb in forum LCD/Display
    Last Post: 09-16-2007, 02:18 PM
  4. LCD Touchscreen was working
    By ericw7748 in forum LCD/Display
    Last Post: 02-28-2007, 12:42 AM
  5. Help! Touchscreen stopped working
    By Qwicker in forum LCD/Display
    Last Post: 02-17-2007, 01:06 PM
