Results 1 to 4 of 4
Thread: USB help please?
    May 2007
    USB help please?
    My car pc is not picking up on the usb touchscreen or usb gps antenna all the time. I usually put it in hibernation instead of shutting it down, but sometimes I shut it down instead. Anyways, the usb picks up half the time and it doesn't pick up the other half the time. Is there any way to refresh all the usb ports with out restarting or something I can try to make them pick up?
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Are you using a hub?
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    May 2007
    I'm using a hub on the screen but not the gps and both have the same problem
    Aug 2006
    Sun Diego
    Hmm...might want to check your USB drivers...
  1. Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 04-22-2012, 07:03 PM
  2. Core Duo / Core 2 Duo Mini-ITX boards
    Last Post: 10-03-2010, 11:30 PM
  3. Newbie build-up: Ampie CarPC
    By EEEEeeee36 in forum Newbie
    Last Post: 03-28-2008, 10:03 PM
  4. Via Epia Mii10000 USB
    By buurin in forum General Hardware Discussion
    Last Post: 07-22-2006, 03:52 PM
  5. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
