Results 11 to 20 of 29
Thread: Need Alpine wired remote control pinout.
  1. #11
    Jul 2009
    Wow thank you so much for that information!
    Any chance you would share your source code?
  2. #12
    Apr 2009
    FordNoMore thanks heaps for the alpine codes and the guide.
    i ended up programing an arduino to take the input signal from my commodore steering wheel buttons and sending them through to the alpine head unit. it all works a charm but there are a few commands that i wish i knew the alpine codes for.
    at the moment all the buttons do what they say but a double press on mode is source on the alpine.
    i will attach my arduino code soon.
  3. #13
    Jul 2009
    Quote Originally Posted by JC_JC View Post
    I would love to see your code and how you got this to work.
  4. #14
    Apr 2009
    //please excuse the lack of comments
    // this works with a simgle button and has the correct timings
    // adding the send of signals to stereo.. simulating by sending to serial
    #define CHECK_MS 5
    #define DOUBLE_MS 400
    #define HOLD_MS 1200
    #define NO_B 839 //nothing pressed
    #define MODE_B 662 // MODE
    #define NXTU_B 509 // NEXT UP
    #define NXTD_B 380 // NEXT DOWN
    #define MUTE_B 273 // MUTE
    #define VOLU_B 180 // VOLUME UP
    #define VOLD_B 105 // VOLUME DOWN
    #define alpPin 7
    boolean volUp[48] = {1,1,0,1,0,1,1,1, 1,1,0,1,1,0,1,1, 1,0,1,0,1,0,1,1, 1,1,0,1,1,0,1,1, 1,1,0,1,0,1,1,0, 1,1,0,1,0,1,0,1};
    boolean volDn[48] = {1,1,0,1,0,1,1,1, 1,1,0,1,1,0,1,1, 1,0,1,0,1,0,1,1, 0,1,1,0,1,1,0,1, 1,1,1,1,0,1,1,0, 1,1,0,1,0,1,0,1};
    boolean mute[48] = {1,1,0,1,0,1,1,1, 1,1,0,1,1,0,1,1, 1,0,1,0,1,0,1,1, 1,0,1,0,1,1,0,1, 1,1,1,0,1,1,1,0, 1,1,0,1,0,1,0,1};
    boolean pstUp[48] = {1,1,0,1,0,1,1,1, 1,1,0,1,1,0,1,1, 1,0,1,0,1,0,1,1, 1,0,1,0,1,0,1,1, 1,1,1,0,1,1,1,1, 0,1,0,1,0,1,0,1};
    boolean pstDn[48] = {1,1,0,1,0,1,1,1, 1,1,0,1,1,0,1,1, 1,0,1,0,1,0,1,1, 0,1,0,1,0,1,0,1, 1,1,1,1,1,1,1,1, 0,1,0,1,0,1,0,1};
    boolean source[48] = {1,1,0,1,0,1,1,1, 1,1,0,1,1,0,1,1, 1,0,1,0,1,0,1,1, 1,0,1,1,0,1,1,1, 1,1,0,1,1,0,1,1, 0,1,0,1,0,1,0,1};
    boolean trkUp[48] = {1,1,0,1,0,1,1,1, 1,1,0,1,1,0,1,1, 1,0,1,0,1,0,1,1, 1,0,1,1,1,0,1,1, 1,1,0,1,1,0,1,0, 1,1,0,1,0,1,0,1};
    boolean trkDn[48] = {1,1,0,1,0,1,1,1, 1,1,0,1,1,0,1,1, 1,0,1,0,1,0,1,1, 0,1,0,1,1,1,0,1, 1,1,1,1,1,0,1,0, 1,1,0,1,0,1,0,1};
    boolean power[48] = {1,1,0,1,0,1,1,1, 1,1,0,1,1,0,1,1, 1,0,1,0,1,0,1,1, 0,1,1,1,0,1,1,1, 1,1,1,0,1,0,1,1, 0,1,0,1,0,1,0,1};
    boolean entPlay[48] = {1,1,0,1,0,1,1,1, 1,1,0,1,1,0,1,1, 1,0,1,0,1,0,1,1, 0,1,0,1,0,1,1,1, 1,1,1,1,1,1,0,1, 0,1,0,1,0,1,0,1};
    boolean bandProg[48] = {1,1,0,1,0,1,1,1, 1,1,0,1,1,0,1,1, 1,0,1,0,1,0,1,1, 0,1,1,0,1,0,1,1, 1,1,1,1,0,1,1,1, 0,1,0,1,0,1,0,1};
    boolean spFlag = 0;
    boolean dpFlag = 0;
    boolean hpFlag = 0;
    int button = 0;
    int spbutton = 0;
    0-none
    1-mode
    2-track +
    3-track -
    4-mute
    5-vol+
    6-vol-
    void setup() {
    Serial.begin(9600);
    pinMode(7, OUTPUT);
    void loop() {
    static unsigned long oldTime = 0;
    int switchStatus = 0;
    if (millis() >= oldTime + CHECK_MS) {
    oldTime = millis();
    switchStatus = CheckSwitch();
    if (switchStatus == 0) {
    //no button press
    } else if (switchStatus == 1) {
    // single press
    switch (spbutton) {
    case 0: // no butto, why are wh here
    break;
    case 1: // mode
    modeSend();
    break;
    case 2: // next up
    trkUpSend();
    break;
    case 3: // next down
    trkDnSend();
    break;
    case 4: // mute
    muteSend();
    break;
    case 5: // vol up
    volUpSend();
    break;
    case 6: // vol down
    volDnSend();
    break;
    } else if (switchStatus == 2) {
    //double press
    switch (spbutton) {
    break;
    case 1: // mode
    sourceSend();
    break;
    case 2: // next up
    trkUpSend();
    break;
    trkDnSend();
    break;
    case 4: // mute
    muteSend();
    break;
    case 5: // vol up
    volUpSend();
    break;
    case 6: // vol down
    volDnSend();
    break;
    } else if (switchStatus == 3) {
    //hold
    switch (spbutton) {
    break;
    case 1: // mode
    modeSend();
    break;
    case 2: // next up
    trkUpSend();
    break;
    trkDnSend();
    break;
    case 4: // mute
    muteSend();
    break;
    case 5: // vol up
    volUpSend();
    break;
    case 6: // vol down
    volDnSend();
    break;
    // Service routine called by a timer interrupt
    int CheckSwitch() {
    static uint16_t State = 0; // Current debounce status
    static int curTime = 0;
    State=(State<<1) | !RawKeyPressed() | 0xe000;
    if (!spFlag) {
    if (hpFlag) {
    if (State == 0xe000) {
    return 3;
    } else {
    hpFlag = 0;
    if (State==0xf000) {
    spFlag = 1;
    hpFlag = 1;
    dpFlag = 1;
    curTime = 0;
    spbutton = button;
    return 0;
    if (hpFlag && State != 0xe000) {
    hpFlag = 0;
    if (spFlag && hpFlag && curTime > HOLD_MS/CHECK_MS) {
    spFlag = 0;
    dpFlag = 0;
    return 3;
    } else if (spFlag && dpFlag && State == 0xf000 && curTime < DOUBLE_MS) {
    spFlag = 0;
    hpFlag = 0;
    dpFlag = 0;
    return 2;
    } else if (spFlag && !hpFlag && curTime > DOUBLE_MS) {
    spFlag = 0;
    hpFlag = 0;
    dpFlag = 0;
    return 1;
    } else {
    curTime = curTime + CHECK_MS;
    return 0;
    boolean RawKeyPressed() {
    int anaPin = 0;
    anaPin = analogRead(0);
    if (anaPin > NO_B - 20) {
    button = 0;
    return 0;
    } else if (anaPin > MODE_B - 20 && anaPin < MODE_B + 20 ) {
    button = 1;
    return 1;
    } else if (anaPin > NXTU_B - 20 && anaPin < NXTU_B + 20 ) {
    button = 2;
    return 1;
    } else if (anaPin > NXTD_B - 20 && anaPin < NXTD_B + 20 ) {
    button = 3;
    return 1;
    } else if (anaPin > MUTE_B - 20 && anaPin < MUTE_B + 20 ) {
    button = 4;
    return 1;
    } else if (anaPin > VOLU_B - 20 && anaPin < VOLU_B + 20 ) {
    button = 5;
    return 1;
    } else if (anaPin < VOLD_B + 20 ) {
    button = 6;
    return 1;
    } else {
    button = 0;
    return 0;
    //-----------SOURCE------------------
    void sourceSend() {
    //first send 8ms high
    digitalWrite(alpPin, HIGH);
    delay(8);
    // send 4.5ms low
    digitalWrite(alpPin, LOW);
    delayMicroseconds(4500);
    for (int i = 0; i <= 47; i++) {
    //send bit for 0.5ms
    if (source[i] == 1 ) {
    } else {
    delayMicroseconds(500);
    // wait 0.5ms
    // send 41ms low
    delay(41);
    //---------MODE-----------------------------------------------
    void modeSend() {
    delay(8);
    // send 4.5ms low
    if (entPlay[i] == 1 ) {
    } else {
    // wait 0.5ms
    // send 41ms low
    delay(41);
    //---------NEXT UP-----------------------------------------------
    void trkUpSend() {
    delay(8);
    // send 4.5ms low
    if (trkUp[i] == 1 ) {
    } else {
    // wait 0.5ms
    // send 41ms low
    delay(41);
    //---------NEXT DOWN----------------------------------------------
    void trkDnSend() {
    delay(8);
    // send 4.5ms low
    if (trkDn[i] == 1 ) {
    } else {
    // wait 0.5ms
    // send 41ms low
    delay(41);
    //---------MUTE---------------------------------------------------
    void muteSend() {
    delay(8);
    // send 4.5ms low
    if (mute[i] == 1 ) {
    } else {
    // wait 0.5ms
    // send 41ms low
    delay(41);
    //---------VOL UP-----------------------------------------------
    void volUpSend() {
    delay(8);
    // send 4.5ms low
    if (volUp[i] == 1 ) {
    } else {
    // wait 0.5ms
    // send 41ms low
    delay(41);
    //---------VOL DOWN-----------------------------------------------
    void volDnSend() {
    delay(8);
    // send 4.5ms low
    if (volDn[i] == 1 ) {
    } else {
    // wait 0.5ms
    // send 41ms low
    delay(41);
  5. #15
    Apr 2009
    if you have questions just ask.
  6. #16
    Oct 2009
    FordNoMore and JC_JC nice work. You guys rock! I installed a JVC KD-AVX77 in my Porsche 911 (993) a few months ago that had a Sony radio with a converted tiptronic steering wheel that I had modified to the Sony wired remote frequencies for volume and tracks.
    I want to change the steering wheel over for the new JVC stereo and realize after seeing this that I’ll need to create an interface like discussed in this thread. From what I understand is that the new remote jacks for JVC, Alpine, and Kenwood are now sending digital signals instead of interpreting frequencies.
    The first thing I’ll have to find out is if the signals are the same between JVC, Alpine, and Kenwood. The second thing I’ll need to find is someone to code a PIC as I don’t have anything to do this although it doesn’t look that expensive to get a programmer. I’m guessing this is a PIC16F84. This would also be a first for me so I was wondering if anyone here could help me out on this venture.
  7. #17
    Dec 2005
    Sweden
    Hi all.
    I know that this is a kind of bump of the old thread but I have searched for codes for my Alpine CDE-9880R and have founded this thread.
    The idea is to do interface between Peugeot 406 steering wheel controls and Alpine but these codes from FordNoMore have worked a bit, not all of them, but I got idea to build Arduino code scanner for Alpine.
    I'm sure it can be used for other HU's as well.
    Here is a link
    with pictures, sketch (source code) file, codes that I have founded and description for everything.
    If you have any questions I will be happy to help.
  8. #18
    Low Bitrate pulsarsimon's Avatar
    Nov 2009
    Melbourne Australia
    The Wired input is exactly the same signal that comes from the IR remote.
    I made a wired interface for a guy a while ago by butchering a remote, and connecting the wires from the remote's LED to the ring and tip of the plug to the unit.
    details in here -->http://www.mobileelectronics.com.au/...howtopic=69181
    MacMini in an Alfa? - Why not!
  9. #19
    Oct 2009
    In other words use the remote as the interface. Makes total sense and simple too. I'll give it a go.
  10. #20
    Dec 2005
    Sweden
    Quote Originally Posted by pulsarsimon View Post
    Hmm, that might be true, but I think it's a bit more complicated than that because I have found several combinations for same function as well as some functions that doesn't exist on IR remote.
  1. Remote control laptop start up
    By vqstatesman in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 09-20-2009, 09:57 AM
  2. Replies: 17
    Last Post: 01-16-2009, 10:48 AM
  3. ...
    By Jantsa in forum Input Devices
    Last Post: 08-21-2008, 10:23 AM
  4. Question about XM & Girder & Remote Control
    By juve021 in forum Road Runner
    Last Post: 04-27-2005, 09:38 PM
  5. Great ir remote to control mp3car
    By rcpirate in forum General Hardware Discussion
    Last Post: 10-16-2002, 01:01 AM
