Results 21 to 30 of 33
Like Tree1Likes
Thread: Need Alpine wired remote control pinout.
  1. #21
    Low Bitrate pulsarsimon's Avatar
    Nov 2009
    Melbourne Australia
    The Alpine IR protocol has over 50 different codes for all the multimedia functions.
    Sure, there's codes which don't have buttons on the standard remote, but get a DVD or iPod unit and there's plenty more options.
    MacMini in an Alfa? - Why not!
  2. #22
    Oct 2005
    HI and sorry at first...
    I found also no more info than this topic.
    Im about to buy KENWOOD DNX9240BT to my Subaru Forester 2006 an i have problem with Steerinwheel controls.
    There is somekind of wired remote connection but kenwood doesent make SWC adapters this old cars...
  3. #23
    Nov 2005
    Quote Originally Posted by VDORepair View Post
    FordNoMore and JC_JC nice work. You guys rock! I installed a JVC KD-AVX77 in my Porsche 911 (993) a few months ago that had a Sony radio with a converted tiptronic steering wheel that I had modified to the Sony wired remote frequencies for volume and tracks.
    I want to change the steering wheel over for the new JVC stereo and realize after seeing this that I’ll need to create an interface like discussed in this thread. From what I understand is that the new remote jacks for JVC, Alpine, and Kenwood are now sending digital signals instead of interpreting frequencies.
    The first thing I’ll have to find out is if the signals are the same between JVC, Alpine, and Kenwood. The second thing I’ll need to find is someone to code a PIC as I don’t have anything to do this although it doesn’t look that expensive to get a programmer. I’m guessing this is a PIC16F84. This would also be a first for me so I was wondering if anyone here could help me out on this venture.
    I installed a Sony RM-X4S in my car since my car didn't come with steering wheel audio controls. I had a Sony head unit, but upgraded to a Pioneer head unit. Fortunately, the Pioneers work with the Sony RM-X4S. I've now upgraded to a JVC KD-AVX77, but would still like to be able to use the Sony RM-X4S.
    I don't have electronics experience so working on wires and resistors is a no for me.
    Is there any way to get the RM-X4S working with the JVC-KD-AVX77? Maybe somehow modify the RM-X4S so that something like the PAC SWI-JACK recognizes the RM-X4S as a generic Toyota steering wheel remote?
  4. #24
    Mar 2006
    Hi,
    Did anyone get a remote working with a JVC head unit? I'm installing a JVC AVX1 in my kitchen, and want a waterproof remote outside on the patio to control it. Im hoping to use some waterproof push buttons, and thought it was going to be as simple as using different resistors for each function.
    Following on from the post about using the IR remote as an interface, would I be able to put a IR receiver connected to the jack plug outside and then just use the IR remote? Any one got a circuit for it? I did a little bit with IR a while bcak in college, but it was more a detector than a signal transmittor. Would it just be as simple as wiring up something like this http://www.google.co.uk/imgres?imgur...ed=0CA8Q9QEwAw ?
    Thanks Gareth
  5. #25
    Apr 2010
    France
    Hello!So,nobody found the "protocol" for kenwood?
  6. #26
    Apr 2010
    Quote Originally Posted by JC_JC View Post
    if you have questions just ask.
    JC_JC, I'am trying to implement your variant with Arduino and Forester'09 wheel drive control for my Alpine IVA505. What nominal of resistors did you use in circuit from wheel drive control. I've measured resistance from pressed controls buttons - it's approximatly from 4,7k ohm to 140 ohms and tried to fit resistor, but unsuccessfully. If I use resistor with 3k homs - voltage is between 2-3 volts.
    Thanks.
  7. #27
    Oct 2005
    Lincolnshire
    My dad has decided that he wants to put steering wheel controls in his car, he has bought buttons and two Arduino boards and a wireless transmitter and receiver. We are going to code the two modules, on in the steering wheel and on near the head unit. We will send a code over the airwaves and then send it out into the head unit.
    For those that are interested here are the codes that I have written. I havent coded for 8 years now since I was at college so go steady. Will need to refine the code no doubt when it goes "live"
    Transmitter module - 8 buttons are to be installed in the wheel and connected to the Arduino
    Code:
    //Steering wheel - transmitter side
    //constant loop which monitors all switches, once a switch is depressed it sends a byte to reciever and starts the loop again
    #include "SoftwareSerial.h"  //software libary for using a software serial
    //DEFINE PINS THAT ARE TO BE USED
    #define txPin 3        //pin for transmitting via RF transmitter
    #define rxPin 2        //pin not used defined for coding only
    #define ledPin 13      //pin for onboard led
    #define mutePin 22     //pin for mute button
    #define volupPin 23    //pin for volume up button
    #define voldwnPin 24   //pin for volume down button
    #define sourcePin 25   //pin for source select button
    #define upPin 26       //pin for up button
    #define downPin 27     //pin for down button
    #define leftPin 28     //pin for left button
    #define rightPin 29    //pin for right button
    // set up a new serial connection for communicating with RF transmitter
    // (this also frees up Arduino's built in serial port for PC communication)
    SoftwareSerial rfSerial =  SoftwareSerial(rxPin, txPin);
    byte val = 0;        //makes a byte for information to be sent
    byte offState = 01;  //sends a code to the reciever that it will ignore
    byte mute = 99;      //sends a code to the reciever that will be transfed into the bianary to control headunit in the reciever
    byte volup = 98;     //sends a code to the reciever that will be transfed into the bianary to control headunit in the reciever
    byte voldwn = 97;    //sends a code to the reciever that will be transfed into the bianary to control headunit in the reciever
    byte source = 96;    //sends a code to the reciever that will be transfed into the bianary to control headunit in the reciever
    byte up = 95;        //sends a code to the reciever that will be transfed into the bianary to control headunit in the reciever
    byte down = 94;      //sends a code to the reciever that will be transfed into the bianary to control headunit in the reciever
    byte left = 93;      //sends a code to the reciever that will be transfed into the bianary to control headunit in the reciever
    byte right = 92;     //sends a code to the reciever that will be transfed into the bianary to control headunit in the reciever
    void setup() {  //setup pins and serial
      pinMode(ledPin, OUTPUT);      // declare led as output
      pinMode(mutePin, INPUT);      //declare mutePin as input      MUTE BUTTON ON WHEEL
      pinMode(volupPin, INPUT);     //declare volupPin as input     VOLUME UP BUTTON ON WHEEL
      pinMode(voldwnPin, INPUT);    //declare voldwnPin as input    VOLUME DOWN BUTTON ON WHEEL
      pinMode(sourcePin, INPUT);    //declare msourcePin as input   SOURCE BUTON ON WHEEL
      pinMode(upPin, INPUT);        //declare upPin as input        UP BUTTON ON WHEEL
      pinMode(downPin, INPUT);      //declare downPin as input      DOWN BUTTON ON WHEEL
      pinMode(leftPin, INPUT);      //declare leftPin as input      LEFT BUTTON ON WHEEL
      pinMode(rightPin, INPUT);     //declare rightPin as input     RIGHT BUTTON ON WHEEL
      rfSerial.begin(2400); // RF Link is a 2400 baud model? (!!!!! check this!!!!!)
      // start by blinking high and then low so we can tell the setup routine has been completed
      digitalWrite(ledPin,HIGH);
      delay(1000);
      digitalWrite(ledPin,LOW);
    //SETUP COMPLETE
    void loop(){  //start of loop
    START:  //  label for goto start
      //MUTE BUTTON PRESSED
      val = digitalRead(mutePin);
      if ( val == HIGH ) {         // check if the input is HIGH (button pressed)
        rfSerial.print(mute, BYTE); // OK send it to the RF transmitter
      val = offState;    //byte cleared for use next time
     goto START;         //returns to the start of the loop
      }//byte sent, restart loop
      else {
        goto VOLUP;
    VOLUP: //label for goto volup
    //VOLUME UP BUTTON PRESSED
      val = digitalRead(volupPin);
        rfSerial.print(volup, BYTE); // OK send it to the RF transmitter
      else {
        goto VOLDWN;
    VOLDWN: //label for goto voldwn
    //VOLUME DOWN BUTTON PRESSED
      val = digitalRead(voldwnPin);
        rfSerial.print(voldwn, BYTE); // OK send it to the RF transmitter
      else {
        goto SOURCE;
    SOURCE:  //label for goto source
    //SOURCE BUTTON PRESSED
      val = digitalRead(sourcePin);
        rfSerial.print(source, BYTE); // OK send it to the RF transmitter
      else {
        goto UPBUTTON;
    UPBUTTON:  //label for goto UPBUTTON
    //UP BUTTON PRESSED
      val = digitalRead(upPin);
        rfSerial.print(up, BYTE); // OK send it to the RF transmitter
      else {
        goto DOWNBUTTON;
    DOWNBUTTON:  //label for goto DOWNBUTTON
      val = digitalRead(downPin);
        rfSerial.print(down, BYTE); // OK send it to the RF transmitter
      else {
        goto LEFT;
    LEFT:  //label for goto LEFT
      val = digitalRead (leftPin);
        rfSerial.print(left, BYTE); // OK send it to the RF transmitter
      else {
        goto RIGHT;
    RIGHT: // label for goto RIGHT
      else {
        goto START;
    } // end of loop
    Receiver - connected to the head unit via a jack plug
    Code:
    Read from a RF Link receiver module and output through the ALP PIN
    #define rxPin 3  //pin for the reciever to be plugged into   PIN 3
    #define txPin 2  //tx pin not used, defined for coding only
    #define ledPin 13 //onboard led
    #define alpPin 7   //pin to be connect to the tip of the lead that is plugged into headunit   PIN 7
    // set up a new serial connection for communicating with RF receiver
    void setup() {
      // set up the input and output pins
      pinMode(rxPin, INPUT); // set up pins for serial comm. with RF receiver
      pinMode (alpPin, OUTPUT);
      // serial comms
      rfSerial.begin(2400); // begin serial connection with RF Link unit
      Serial.begin(2400); // begin serial communication over USB to the computer
      // blink LED on and then off just to let us know the setup routine is complete
      digitalWrite(ledPin,HIGH); // turn on LED
      delay(1000);
      digitalWrite(ledPin,LOW); // turn off LED
    void loop()
      int code = '0'; //sets up an integer for us to store recieved code untill it is processed
    START:  //label for goto START
      code = rfSerial.read(); // read whatever the RF Link has to offer
      if (code == 01) {
        goto START;  //01 is an off code, if recieved goto start to keep loop running
      if (code == 99) {
        mute();  //99 is the mute code, if recieved go to the MUTE label
      if (code == 98) {
        volup ();  //98 is the volume up code, if recieved go to the VOLUP label
      if (code == 97) {
        voldwn ();  //97 is the volume down code, if recieved go to the VOLDWN label
     if (code == 96) {
        source ();  //96 is the source code, if recieved go to the SOURCE label
      if (code == 95) {
        up() ;  //95 is the up code, if recieved go to the UP label
      if (code == 94) {
        down ();  //94 is the down code, if recieved go to the DOWN label
      if (code == 93) {
        left ();  //93 is the left code, if recieved go to the LEFT label
      if (code == 92) {
        right ();  //92 is the right code, if recieved go to the RIGHT label
        else {
        Serial.print("nothing"); // send message to computer for testing, REMOVE ON FINAL DEPLOYMENT
        goto START; //no buttons have been pressed, return to the start of the loop to keep listing for button presses
    void mute() {
    //send start command
    //first send 8ms high
    digitalWrite(alpPin, HIGH);
    delay(8);
    // send 4.5ms low
    digitalWrite(alpPin, LOW);
    delayMicroseconds(4500);
    //start command sent
    //send mute command
    // binary for the mute command  1 0 1 0 1 1 0 1 1 1 1 0 1 1 1 0 1
    digitalWrite(alpPin, HIGH);     //   1   sending high
    delayMicroseconds(500);        //   1   for 500 microseconds
    digitalWrite(alpPin, LOW);      //   1   sending low
    delayMicroseconds(1000);       //   0 leave the pin low for 100 micro seconds
    // MUTE COMMAND SENT
    //SEND END COMMAND
    //end command binary 1010101
    //END COMMAND SENT
    loop ();//COMMAND SENT TO HEADUNIT GO TO START TO LISTEN FOR FURTHER BUTTON PRESSED COMMANDS
    void volup()
    delay(8);
    // send 4.5ms low
    //send volume up command
    //binary for volume up 11011011110101101
    // volume up command send
    //SEND END COMMAND
    //END COMMAND SENT
    loop ();//COMMAND SENT TO HEADUNIT GO TO LOOP TO LISTEN FOR FURTHER BUTTON PRESSED COMMANDS
    void voldwn ()
    delay(8);
    // send 4.5ms low
    //send volume down command
    //binary for volume down 0 1 1 0 1 1 0 1 1 1 1 1 0 1 1 0 1
    //volume down command sent
    //SEND END COMMAND
    //END COMMAND SENT
    loop() ;//COMMAND SENT TO HEADUNIT GO TO START TO LISTEN FOR FURTHER BUTTON PRESSED COMMANDS
    void source()
    delay(8);
    // send 4.5ms low
    //send source command
    //source command binary 1 0 1 1 0 1 1 1  1 1 0 1 1 0 1 1 0
    //source command sent
    //SEND END COMMAND
    //END COMMAND SENT
    void up ()
    delay(8);
    // send 4.5ms low
    //send up command
    //up command binary 1 0 1 0 1 0  1 1 1 1 1 0 1 1 1 1 0
    //up command sent
    //SEND END COMMAND
    //END COMMAND SENT
    void down ()
    delay(8);
    // send 4.5ms low
    //send down command
    //down command binary 0 1 0 1 0 1 0 1 1 1 1 1 1 1 1 1 0
    //down command sent
    //SEND END COMMAND
    //END COMMAND SENT
    void right ()
    delay(8);
    // send 4.5ms low
    //send right command
    //left command binary 1 0 1 1 1 0 1 1 1 1 0 1 1 0 1 0 1
    //right command sent
    //SEND END COMMAND
    //END COMMAND SENT
    void left ()
    delay(8);
    // send 4.5ms low
    //send left command
    //left command binary 0 1 0 1 1 1 0 1 1 1 1 1 1 0 1 0 1
    //left command sent
    //SEND END COMMAND
    //END COMMAND SENT
  8. #28
    Apr 2008
    Wow! You are basically my electronic life saver! Thank you!
    I'm currently trying to wire up an alpine (cda-105) with 3.5mm input jack to my s2000 dash controls (which pretty much work exactly the same as steering wheel controls you listed)
    I know, this thread is almost 1.5 years old, but I would love some pointers If OP could get a chance.
  9. #29
    Aug 2005
    OMG, this is so useful. Does anyone know if it will work for a Clarion HU?
    Is there some sort of repository for these 'codes'?
  10. #30
    May 2012
    Quote Originally Posted by roibix View Post
    I have the kenwood protocol here: http://baggertech.com/forum/showthre...ad-Glide-Hacks
  1. Remote control laptop start up
    By vqstatesman in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 09-20-2009, 08:57 AM
  2. Replies: 17
    Last Post: 01-16-2009, 09:48 AM
  3. ...
    By Jantsa in forum Input Devices
    Last Post: 08-21-2008, 09:23 AM
  4. Question about XM & Girder & Remote Control
    By juve021 in forum Road Runner
    Last Post: 04-27-2005, 08:38 PM
  5. Great ir remote to control mp3car
    By rcpirate in forum General Hardware Discussion
    Last Post: 10-16-2002, 12:01 AM
