Results 1 to 7 of 7
Thread: Steering Wheel Control Input - VW?
    Jun 2009
    I have a 2009 Tiguan and i am starting to gather information on parts i need to get the PC installed. My car came equipped with steering wheel controls. I have an adapter from connect2 that converts the controls into a 8mm plug for the pioneer radios. is there anything out there like this that i can get that will allow me to control track blue tooth mute volume controls. At this point it is the only thing i am unsure about.
    May 2009
    There is a way to use steering wheel remote contorls on car PC.
    [media]http://www.youtube.com/watch?v=Zvl34tMm1_o[/media]
    Variable Bitrate csfile's Avatar
    Feb 2009
    I'm not sure what type of steering wheel controls the Tiguan has (resistance wire, voltage, through CAN). There are many solutions. You can look into rcjoycon or fusion brain (which I am currently using)
    Jun 2009
    mine is a can system
    Jun 2009
    http://www.connects2.com/Instructions/SVW002.pdf
    that is how mine is connected. the Connect2 puts the wires out into 3 wires i believe then inside converts it to the can. so what ever the signal the pioneer radios use will work with this. i would just need a interface that would go between that unit and the autoPC
    May 2009
    As the document(SVW002.pdf), your steering wheel remote controls are CANBUS.
    You can use CAN interface.
    Or you can modify it into resistance output.
    This is the example of AUDI steering wheel remote controls.
    http://rcjoycon.com/base_3/menu_11.p...m_board_page=&
    Jun 2009
    I have a email out to connect2 trying to find out how the interface works that i have from them. I think it takes the resistance type interface from the radio and converts it too canbus. I do not really want to mess with the controls.
  1. Ford steering wheel control interface...
    By WuNgUn in forum CF Plugins
    Last Post: 12-30-2007, 09:53 AM
  2. Steering wheel control and durability
    By bimmerpc in forum General Hardware Discussion
    Last Post: 11-01-2005, 03:01 PM
  3. PC with VW steering wheel controls '02+
    By EuroFan in forum Car Audio
    Last Post: 10-28-2005, 06:02 AM
  4. Steering Wheel Control
    By Micv in forum Hardware Development
    Last Post: 07-13-2005, 12:45 PM
  5. Wireless control for steering wheel
    By DodgeCummins in forum General MP3Car Discussion
    Last Post: 02-15-2002, 02:14 PM
