If your volume knob is infinite then it's not a pot. It is an encoder. A pot can not be infinite.
Hey guys, have been searching here and google for hours. I want to take the volume control knob from my stock radio and integrate its function over usb to control the master volume on my carpc.
I checked out hacking a mouse, and other rotary encoders - was hoping to find a way to do it direct from the stock radio.
The radio volume is a potentiometer but is infinite (i.e. can keep turning it continuously, there is no set stop).
Checking it with a voltmeter it appears when you turn the dial it transiently raises the resitatance.
Has anyone ever found a way to take this output, convert to usb and have control the volume??
Thanks.,
Well if it puts out resistance, then it doesnt matter what it is. You can use a FB and a second resistor to make a voltage divider and read in the value.
1.9in x 2.9in -- 47mm x 73mm
