If I remember correctly the green cover has a minute metal tab under it that when presses against the PCB completes the circuit. If you're even a novice at soldering, you could solder some wires to the two tabs I pointed at and buy a momentary switch from your local/internet electronic parts store and put it anywhere you want.
LinkBack URL
About LinkBacks
