Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: UPDATE - Xbox thumbstick media control
    Constant Bitrate sergatiuk's Avatar
    Mar 2006
    UPDATE - see page 2 for attaching additional buttons
    the xbox controller is a very versatile piece of hardware, it can be configured in just about any way.
    heres the way i configured it:
    1. i removed everything from the controller board.
    2. then soldered an extension wire for the left thumbstick (about 1')
    3. soldered a USB cable instead of the original cable (just match the colors)
    4. then install the xbcd drivers to recognize the controller as a joystick.
    5. and the last stem is a program thats called JOYTOKEY.
    6. bind the thumbstick to send multimedia keyboard signals.
    LEFT-0xB1 (next track)
    RIGHT-0xB0 (previous track)
    UP-0xAF (master volume up) repeat 16 times/sec (steps)
    DOWN-0xAE (master volume down) repeat 16 times/sec (steps)
    Button 9 (thumbstick press) - 0xB3 (play/pause)
    7. then under advanced - set threshold to 50% to make it less sensitive, and send the signals when its moved half way in the assigned directions.
    thats it.
    also this controller can provide much greater functionality. later on im going to bind the toggle fullscreen keys for centrafuse.....
    Newbie Z_Rukia_Z's Avatar
    Aug 2007
    MA
    This looks pretty interesting! Good luck with the future functionality, I will keep my eye on this thread because I feel as though it's something that I can use/integrate into my car.
    Obtain components [-------------------X] 100%
    Obtain touchscreen [-------------------X] 100%
    Configuration [-----------------X--] 90%
    Wiring [------------------X-] 95%
    Install [------------------X-] 95%
    -You're never really done with these projects!
    Mar 2006
    this is what the final product looks like (o;'
    notice the thumbstick to the left of the monitor.
    all it needs now is a backlight ring...
    Mar 2006
    okk so i made a few adjustments to Xbox joystick setup.
    the thumbstick next to the monitor operates as a mouse.
    and volume and next/prev tracks thumbstick is right at the fingertips while driving (o;'
    Low Bitrate SoulR's Avatar
    Aug 2007
    Very nice, great idea i like it.
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Very good hack .
    Is the button as , if i understand, 2 axes and 1 push function ?
    Newbie Fuegomp3's Avatar
    Feb 2009
    Bs As, Argentina
    Hello, pardon my English, this is translated by google:
    I built this with a USB joystick like playstation:
    http://www.fuegomp3.com.ar/inicio/in...&limitstart=11
    The configuration is like your analog control, I give you a tip, in Joy2Key you got the ability to create multiple profiles, and assign a button to switch profiles in profile, with this you can use the lever and the button for several more functions.
    http://www.mp3car.com/vbulletin/atta...1&d=1253106040
    I hope you understand what I wrote.
    Greetings,
    Nelson.
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    Quote Originally Posted by pierrotm777 View Post
    Very good hack .
    @sergatiuk
    i would like to know the same thing
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
    Mar 2006
    Very good hack .
    yes that is correct, Y - volume, X - next/previous track, push - play/pause
    Mar 2006
    Quote Originally Posted by Fuegomp3 View Post
    thats a good point, one might want to use the same analog stick as a mouse as well and switch the profiles by pushing on the analog stick. and yes that is very easy to achieve in joy2key
    in my case i just used 2 thumbsticks, but in cars with not much space to mount a second one this would be a great idea, in case you want to use a cursor for web browsing or other external apps in centrafuse or RR
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. FS: Modded Xbox with 250GB HD - Xbox Media Center
    By ckny in forum Classified Archive
    Last Post: 09-28-2006, 01:16 PM
  3. Selling Complete Xbox Car System w/ Xenarc LCD!
    By JBCrash in forum Classified Archive
    Last Post: 05-11-2005, 02:51 AM
  4. winamp or media player IR remote control for 9 pin serial port $11
    By sfrechet in forum General Hardware Discussion
    Last Post: 08-10-2002, 12:02 PM
