Results 1 to 8 of 8
Thread: microphone
    Nov 2009
    microphone
    What type of microphone are you using with your mobile phone software?
    Nov 2009
    bump
    Constant Bitrate NoTec's Avatar
    Jan 2009
    South Florida
    Search. Alot of us are using the one from the mp3car.com store
    Nov 2009
    Ok, I have spent over an hour searching now and have not found what I am looking for. Let me explain my issue better. I am using a computer microphone connected via my pci sound card. The microphone is plugged into the microphone port on the card. The microphone works fine and sound is fine (a little quite (people say it sounds like I am on speaker phone - go figure)). My issue is the microphone stays on all the time. Not just when using the mobile phone plug in .net Bluetooth Mobilephone Plugin in RideRunner Elite Lite skin.
    Is there a setting that needs to be changed? Does everybody elses microphone stay on all the time? Do I need to add/change some code somewhere? I just need to know if the microphone is suppose to be on all the time or just when using the plugin
    May 2008
    I think the question here is What do you mean by "on all the time"? Most computer microphones are always "active" in the sense that a program can connect to them and record sound. What, exactly, is yours doing that you perceive this to be a problem?
    Nov 2009
    ok i would think the mic would be muted all the time except when using the mobile phone app. My mic says unmuted all the time.
    May 2008
    Nope, that's perfectly normal. Unless you have your mic-in routed to your audio out, causing echo, you should be OK.
    Constant Bitrate tom_rosenback's Avatar
    Oct 2006
    Finland
    There are separate settings for Playback and Recording, mute MIC in the playback MIC settings and check the "Select" box on MIC in the recording settings. I donīt know what OS you are using but on XP you double-click on the speaker icon in the taskbar, now you should see the audio settings. Default it is showing Playback settings, mute MIC. Select Properties from the Options menu, select recording, and now make sure you have the MIC selected for recording.
    By doing this you shouldnīt get any echo...
  1. One microphone or three?
    By stonestatue in forum Wireless Communications
    Last Post: 06-19-2008, 03:46 AM
  2. Logitech "noise-cancelling" microphone
    By evandude in forum Input Devices
    Last Post: 10-24-2007, 06:08 PM
  3. Basic: Swap Line In & Microphone
    By Nerd2 in forum Car Audio
    Last Post: 02-26-2007, 03:35 PM
  4. iBug Logitech Microphone Install (pics)
    By Bugbyte in forum Input Devices
    Last Post: 05-02-2005, 01:29 PM
  5. hooking up a microphone [[REALLY DUMB QUESTION]]
    By holden_frost in forum General Hardware Discussion
    Last Post: 01-31-2003, 08:36 PM
