Results 1 to 6 of 6
Thread: Mini-Pac Wiring questions, electrical advice needed!
    Variable Bitrate VmtSquad's Avatar
    May 2007
    Montréal, Quebec, Canada
    Hi guys,
    So here's my wiring question....
    I now have this device in hand http://www.ultimarc.com/minipac.html
    It's a tiny board that sends custom commands to a Mac or PC...it has buttons and joysticks possibility...
    Here's the diagram:
    I wanted to know how should I connect my buttons? I'm usually good with wiring and electrical stuff but there's something I don't get with this device.
    I know it can achieve what I wan't which is reroute some custom buttons to my MAC, pretty straight forward!
    Thanks in advance!!
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
    May 2007
    bump?
    Final Install
    CarPC progress: 95%
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    It looks like it's designed for common ground, so connect ground to one side of each button, then work up from the bottom of J1, connecting brown to the other side of button 1, then red orange yellow to 2, 3, 4...
    May 2007
    Thanks I'll try this out when I get home !!
    Final Install
    CarPC progress: 95%
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Yah, looks like you connect one side of the switch to the header pin and the other side to the ground. Since there's only one ground on the board, they sell you a daisy chain harness that connects to that ground and then each of the connectors on the daisy chain go to the other side of the switch.
    You can do the same by using a terminal block with a bus bar from Rat Shack. You connect the bus bar side to the ground on the mini-pac and then each switch has a lead that goes to the bus bar.
    They use spade connectors on the daisy chain because the arcade switches they sell have lug connectors on them. You won't need that, depending on the switches you are using.
    BTW - you can test all this out by using a short piece of wire like a paperclip bent into a U shape. One end on the ground header and and touch the other to the switch header pin to simulate closing the switch.
    Want to:
    May 2007
    Thanks for the input guys, I think I get the point.
    I have a testing board at home maybe I could use it to test my buttons
    Thanks I'll keep you guys updated with the development.
    Final Install
    CarPC progress: 95%
  1. Electrical advice needed
    By VmtSquad in forum General MP3Car Discussion
    Last Post: 12-21-2009, 07:43 AM
  2. Replies: 8
    Last Post: 07-15-2009, 09:22 PM
  3. Need advice on LCD wiring..
    By Divine_Madcat in forum LCD/Display
    Last Post: 05-31-2004, 02:58 AM
  4. Some Electrical Questions
    By Kayos Frawg in forum General Hardware Discussion
    Last Post: 04-16-2004, 02:56 PM
  5. System Proposal and Questions - Advice Needed
    By Doodsmack in forum Newbie
    Last Post: 10-08-2003, 10:35 PM
