i got a question, where did you mount the sensor. Is it in contact with a constant airflow, or sealed ?
Hi. I bought a couple of temperature sensors along with a 8/8/8 board from phidgets a while back. I am not pleased with these sensors, they are not accurate enough (jumping up and down maybe 1.5-3C when the temperature varies) and not fast enough (it takes maybe 45 mins after the car is warm and comfy before the temperature shows the same). Can I buy another sensor which would be fast enough to show the actual temperature in the care while the car is warming up, and maybe be accurate enough to show 0.1C pressision? Where would I get a sensor like this, and would the 8/8/8 be accurate enough to handle the information?
It's mounted in the right rearview mirror, so it's not in contact with constant airflow. The inside temperature is mounted in the roof.
